Datsun 1200 uses a common wheel bolt-pattern: 4 bolt holes on 4-1/2 inch circle (aka 4-on-4.5). Nissan engineers specified this in inches. In metric this is equivalent to a 4 x 114.3 PCD (Pitch Circle Diameter). Stock Datsun 1200 wheels are 12 inch diameter, 4J (4 inches wide). All models, even GX models and 1994 Sunny Truck models, used 12" wheels. Only the Datsun 1200 SSS used a special wheel. Wheels up to 18x7 will fit under the stock bodywork.
Stock Wheels
- 12" diameter
- 4-inch wide
| wheels | B110 | 1977 US B210 A14 | 1980 NA B310 |
| size | 4 J-12 | 4-1/2 J-13 | 4-1/2 J-13 5 J-13 (aluminum) Canada w/A12A: 4J-12 |
| offset | 30 mm | 30mm offset | 30mm 25 mm (aluminum) |
| tire size | 6.00-12 155SR-12 | 155SR-13 | 6.00-12 155SR13 175/70SR13 |
| balance | 10gr or less (0.35 oz) | 11gr or less | 10gr or less |
| lugnut torque | 8-9kg-m (58-65 ft-lb) | 8-9kg-m | 8-10 |
NOTE: 1976-1978 B210 large-brake wheels are 13" but have 4mm extra diameter inside, possibly for clearance of the large brakes. These wheels are same as Datsun 610 and can be identified by six thin slots on the face.
Datsun Option Wheels
Datsun Sunny B310 factory OPTION B & OPTION C wheels: 13" x 5"
- 40300-N5825 WHEEL SET-ROAD ALUMINIUM, B TYPE (5JX13)
- 40300-W6625 WHEEL SET-ROAD ALUMINIUM, C TYPE (5JX13)
- Also used on 200SX (S10 silvia) 1977-1979
B310 Wheels
NOTE: These do not fit the B110 front hubs due to the shape of the wheel.
ホイール
Compatible Wheels
Any wheel that is 4-bolt on 4.5 inch circle fits will bolt onto the Datsun 1200, depending on the offset. Fitment also includes the tire sizes, as taller tires may hit the bodywork.
- Rear-wheel drive Toyota
- Chevrolet Corvair (5 x 13)
- pefect for the rear
- may need a 1/4 inch spacer on fronts to clear the brake caliper
- Datsun 240Z wheels -- 14"
- Uni-lug alloy wheels
- Hyundai Excel
- Ford Laser (KA to KH)
- Rear-wheel-drive Mitsubishi
- Early SAAB (5.5 inch wide)
What WONT work:
- Honda
- Isuzu/Holden Gemini
- Ford Escort/Cortina
- early Mazda
- Subaru
- Newer SAAB (900 Turbo)
Also same as Nissan Pintara. These are 14" wheels. aka "Pursuit" or "chaser" style rims as they are similar to police car (plain) steel wheels.
Don't pay more than $15 per steel wheel
The 5.5 wide R31 steelies should fit.
The stock 6" and 7" wide Sillouettes won't fit the B110 or early B210 disc-brake strut. If you run Stanza or 240K struts, then no worries.
TRX Wheels
Alloy wheels from Datsun 910 "Bluebird Series II" Australia TRX package work nicely on a Datsun 1200.
Discussion: will trx 15"rims fit straight onto 1200 ute without flaring?
"If I see another 1200 with TRX rims I'm going to smack you across the face!"
On standard Datsun 1200 struts they will require fairly low profile tyres, and quite large spacers for the front and it will need to stay at standard height. Even then you might find they are a tight fit and might grab the guard a bit if you hit any speed humps too quick or take corners quick.
If it is lowered at all you will need to roll the guards for sure!
With Stanza and other similar struts they fit no problem with 195/50R15 tyres and will only need to cut the front bottom corner out of the front guards for clearance when turning.
With Sunny (B310) struts on front and 195/50R15 tyres, it requires to roll all the guard lips, and run spacers on rear as they were scrubbing the inner guard and on all wheel arches the sharp lip all around the guard was tearing into the tyre slightly so rolled it right up.
Lug Nuts
M12x1.25 thread
- B210: 13/16" lug nuts
See main article Wheel Studs
Torque
- 8.0-9.0 kg/m (58-65 ft-lb)
Wheel Balance
Wheel Offset
The stock wheel is 4 inches wide with 30 mm positive offset (mounting face is 30mm outboard of the wheel's center line). It can fit the stock 155-width tire or a wider 165-width tire. 175-width requires a 5" wide wheel.
STOCK = 30 mm offset
The offset doesn't mean much without knowing the tire width. All offset will tell you is if the tires will be offset towards the vehicle centerline (+ offset) or away from the vehicle centerline (- offset). But it doesn't say how far the edge of the tire will be -- for that you need to know the tire width along with the offset.
Stock Offset| model | Wheel type | Offset | wheel width | Tire width |
| B110 | steel | 30 mm (1.18 in) | 4" wide wheel | 155 mm |
| B210/B310 | steel | 30 mm (1.18 in) | 4.5" | 155 mm |
| B210/B310 | aluminum | 25 mm (0.98 in) | 5" wide wheel | 175 mm |
- Using B210 wheels on B110 results in a 10mm (~1/2 inch) wider overall width (measured from outside-sidewall to outside-sidewall). NOTE: These still fit under unmodifed B110 fenders.
- B210/B310 Factory Steel vs. Aluminum wheels may have different widths, but have close to the the same overall width as installed. The wheels are 1/2" wider (13mm), but offset on each side is 5mm less. So the outside edges as-installed are less than 2mm further apart from each other than the narrower steel wheels.
Choosing Wheel Offset
- Stock +30 offset works with up to 175-width tires (requiring 5" to 6.5" wide wheels).
The rear wheel mounting face (face of the drum brake) is offset -30mm from the center of the wheelwell. So using a +30mm offset wheel perfectly centers the tire in the wheelwell. Just like the stock wheels (+30 offset). Those clever Datsun engineers!
Even so, some Here reports by club members indicate other offsets will work. Many of these place the wheel face outside of the fenders.
- Zero offset works well up to 6"-wide wheels.
- 6.5 and 7" wheels need to be tucked inside a a little more and so require +10 to +15 offset.
- 8" wheels need to be tucked outside to fit, so require -5 or more negative offset and will stick out past the bodywork.
Negative Offset "Deep dish" old-school wheels have lots of negative offset
Positive Offset FWD wheels typically have lots of positive offset Datsun 1200 stock wheels have a mild amount of postive offset
wheel offset and backspace diagram
Measuring Offset
Wheel Offset is the difference between the flange and the wheel centerline. You don't need to know the width to measure Offset.
- Lay wheel flat on the ground (outside face down). You can also do this with tire mounted if it is aired up.
- Lay straitedge or straight sawn lumber piece across it, measure to the ground.
- Measure down to the flange back face
- Subtract the two measurements
offset = (distance to flange) - (1/2 width)
Centerline = 1/2 width
- Zero Offset: The wheel is centered exactly over the hub face
- + Offset: The wheel is offset towards the inside of the car
- - Offset: The wheel is offset towards the outside of the car
Scrub Radius
Largest Sizes to Fit 1200
17-inch diameter wheels easily fit the 1200. The key is: width of the tyre and overall height of the tyre. Even 18" wheels are being used on 1200s with stock bodywork, if a low-profile tire is used.
The wheel mainly positions the tire within the wheelwell. The tire is the part that will rub on the fender or rub on the spring.
The wider the wheel, the less offset is needed. To make maximum use of the wheelwell width, zero offset generally works well with Datsun 1200.
Rear
- 7": 13x7 with 0 offset and they fill the gaurds perfectly
- 9": 13 x 9 zero offset, tire 215/50r13
Ute Rear
There is more room under the rear of the Datsun 1200 pickup model, compared to the sedans, wagons and coupes.
Wheel Adapters
Wheel Spacers
If the offset is too negative, they will fit the fenders (guards) and there is nothing you can do except cut out the bodywork, perhaps fitting large flares.
Suppliers
Wreckers are your best bargain here ... lots of 13, 14, 15, 16 and 17" wheels, even some 12s. Lots of 12s avaiable in US junk yards.
- http://classicdatsun.com has Panasports
Manufacturers
- Konig makes a retro-style wheel with the proper offset for RWD application. Konig Rewind
Mail order
- tirerack.com
- Minilite Wheels - The real deal! alloy racing wheels 12x5 only $159 each in Silver, Black, White. Gold and Anthracite also available.
Also see: Wheel Weights
