Starting with the A14 engines, the Hitachi D4A points-type distributor replaced the older D4n type (D40/D41). The D4A features a larger cap for improved spark isolation and resistance to crossfiring. The same body casting was later used for the D4F and D4K Electronic Ignition versions.
Models
NORTH AMERICA B210
22145-89900 SET-CONTACT 1075- 2 22145-U6002 * 22145-U6002 SET-CONTACT 0875-0975 2 22145-U6001 ** 22145-U6001 SET-CONTACT -0775 22102-U6003 CONDENSER 0877- 2 22102-U6002 * 22102-U6002 CONDENSER -0777 22403-H7200 ASSY-TERMINAL 0877- 2 22403-U6001 * 22403-U6001 ASSY-TERMINAL -0777 22119-H5000 SET-PISTON/PINION 22157-B8900 ROTOR-HEAD 0876- 0 22157-U6001 22157-U6001 ROTOR-HEAD -0776 22162-U6001 ASSY-CAP 22165-30101 ASSY-CARBON POINT 22130-A5500 PACKING 08360-61226 BOLT-HEX WITH WASHER M6 22180-71200 O RING-DIST.SUPPORT
1974 A13 0673-0874 22100-H6201 ASSY-DISTRIBUTOR 4CYL. HITACHI D42 22108-H6200 SET-SHAFT 22160-M0800 SET-WASHER THRUST 22109-U6001 GOVERNOR-WEIGHT (2) 22110-H6200 SET-SPRING GOVERNOR 22132-H6200 SET-CAM 22136-U6001 ASSY-BRAKER PLATE 22182-U6001 ASSY-WIRE,EARTH 22301-H6200 ASSY-VACUUM CONTROL 22750-U6001 KIT-SCREW
FED MT 1975-1976 A14 0974-0777 053A 22100-H7201 ASSY-DISTRIBUTOR (D4A5-04) A14FED(MANUAL) 0875-0776 0 22100-H7200 22100-H7260 ASSY-DISTRIBUTOR (D4A5-13DS) A14FED(MANUAL) 0876-0777 0 22100-H7201 22100-H7263 ASSY-DISTRIBUTOR (D4A6-04) A14CAN(MANUAL) 0876-0777 0 22100-H7201 22100-H7601 ASSY-DISTRIBUTOR (D4A7-02) A14CAN(MANUAL) 0877- 0 22100-H7263 22100-H7200 ASSY-DISTRIBUTOR (D4A4-02) A14FED(MANUAL) -0775 22108-M5600 SET-SHAFT A14FED(MANUAL) -0777 22108-M5600 SET-SHAFT A14CAN(MANUAL) 0877- 0 22108-M5600 22160-M5600 SET-THRUST WASHER A14FED(MANUAL) 22109-A5500 GOVERNOR WEIGHT A14FED(MANUAL) (2) 22110-H7200 SET-GOVERNOR SPRING A14FED(MANUAL) -0775 22110-M5601 SET-GOVERNOR SPRING A14FED(MANUAL) 0875-0777 0 22110-H7200 22110-H7601 SET-GOVERNOR SPRING A14CAN(MANUAL) 0877- 0 22110-M5601 22132-M5600 SET-CAM A14FED(MANUAL) -0777 22132-H7601 SET-CAM A14CAN(MANUAL) 0877- 0 22132-M5600 22136-M5600 ASSY-BREAKER PLATE A14FED(MANUAL) 22182-M5600 ASSY-EARTH WIRE A14FED(MANUAL) 22301-H7200 ASSY-VACUUM CONTROL A14FED(MANUAL) -0775 22301-H7201 ASSY-VACUUM CONTROL A14CAN(MANUAL) 0875-0777 70 22301-H7200 22301-M2361 ASSY-VACUUM CONTROL A14CAN(MANUAL) 0877- 2 22301-H7201 22301-H7201 ASSY-VACUUM CONTROL A14FED(MANUAL) 0875-0776 22301-H7360 ASSY-VACUUM CONTROL A14FED(MANUAL) 0876- 0 22301-H7201 22160-M5600 SET-THRUST WASHER A14FED(MANUAL) 22750-M5600 SCREW KIT A14FED(MANUAL) 22167-N6005 SET-CAP CLAMP A14FED(MANUAL) (2) 0377- 22309-M5600 EARTH TERMINAL A14CAN(MANUAL) 0877-
