Starting with the A14 engines, the Hitachi D4A points-type distributor replaced the older D4n type (D40/D41). The D4A features a larger cap for improved spark isolation and resistance to crossfiring. The same body casting was later used for the D4F and D4K Electronic Ignition versions.
Models
These listings are cumulative.
NORTH AMERICA B210
POINTS SET
22145-89900 SET-CONTACT 1075- 2 22145-U6002 * 22145-U6002 SET-CONTACT 0875-0975 2 22145-U6001 ** 22145-U6001 SET-CONTACT -0775 22102-U6003 CONDENSER 0877- 2 22102-U6002 * 22102-U6002 CONDENSER -0777
COMMON PARTS
22403-H7200 ASSY-TERMINAL 0877- 2 22403-U6001 * 22403-U6001 ASSY-TERMINAL -0777 22119-H5000 SET-PISTON/PINION 22157-B8900 ROTOR-HEAD 0876- 0 22157-U6001 22157-U6001 ROTOR-HEAD -0776 22162-U6001 ASSY-CAP 22165-30101 ASSY-CARBON POINT 22130-A5500 PACKING 08360-61226 BOLT-HEX WITH WASHER M6 22180-71200 O RING-DIST.SUPPORT
A13 for 1974
A13 0673-0874 1974 Model year 22100-H6201 ASSY-DISTRIBUTOR 4CYL. HITACHI D42 22108-H6200 SET-SHAFT 22160-M0800 SET-WASHER THRUST 22109-U6001 GOVERNOR-WEIGHT (2) 22110-H6200 SET-SPRING GOVERNOR 22132-H6200 SET-CAM 22136-U6001 ASSY-BRAKER PLATE 22182-U6001 ASSY-WIRE,EARTH 22301-H6200 ASSY-VACUUM CONTROL 22750-U6001 KIT-SCREW
A14 D4A POINTS TYPE
22100-H7606 ASSY-DISTRIBUTOR (D4A7-03) A14 CAN(AUTO) 0877- 22100-H7601 ASSY-DISTRIBUTOR (D4A7-02) A14CAN(MANUAL) 0877- 22100-H7268 ASSY-DISTRIBUTOR (D4A6-05) A14 CAN(AUTO) 0876-0777 22100-H7263 ASSY-DISTRIBUTOR (D4A6-04) A14CAN(MANUAL) 0876-0777 22100-H7260 ASSY-DISTRIBUTOR (D4A5-13DS) A14FED(MANUAL) 0876-0777 22100-H7206 ASSY-DISTRIBUTOR (D4A5-05) A14 CAN(AUTO) 0875-0776 22100-H7206 ASSY-DISTRIBUTOR (D4A5-05) A14 FED(AUTO) 0875-0777 22100-H7205 ASSY-DISTRIBUTOR (D4A4-03) A14 FED(AUTO) -0775 22100-H7201 ASSY-DISTRIBUTOR (D4A5-04) A14FED(MANUAL) 0875-0776 22100-H7200 ASSY-DISTRIBUTOR (D4A4-02) A14FED(MANUAL) -0775 22108-M5600 SET-SHAFT 22160-M5600 SET-THRUST WASHER 22109-A5500 GOVERNOR WEIGHT (2) 22110-H7200 SET-GOVERNOR SPRING A14FED -0775 22110-M5601 SET-GOVERNOR SPRING A14FED 0875-0777 22110-H7601 SET-GOVERNOR SPRING A14CAN 0877- 22132-M5600 SET-CAM -0777 22132-H7601 SET-CAM 0877- 0 22132-M5600 22136-M5600 ASSY-BREAKER PLATE 22182-M5600 ASSY-EARTH WIRE 22301-H7360 ASSY-VACUUM CONTROL A14FED(MANUAL) 0876- 22301-H7205 ASSY-VACUUM CONTROL A14 FED(AUTO) 0974-0777 22301-H7200 ASSY-VACUUM CONTROL A14FED(MANUAL) -0775 22301-M2361 ASSY-VACUUM CONTROL A14CAN(MANUAL) 0877- 2 22301-H7201 22301-H7201 ASSY-VACUUM CONTROL A14CAN(MANUAL) 0875-0777 22301-H7201 ASSY-VACUUM CONTROL A14FED(MANUAL) 0875-0776 22160-M5600 SET-THRUST WASHER 22750-M5600 SCREW KIT 22167-N6005 SET-CAP CLAMP (2) 0377- 22309-M5600 EARTH TERMINAL 0877-
A14 D4F EI TYPE
Electronic ignition distributor. Uses parts listed above for D4A and COMMON PARTS except as listed below.
22100-H7265 DISTRIBUTOR ASSY(D4F6-03) FED(AUTO) 0877- 22100-H7360 DISTRIBUTOR ASSY(D4F5-03) FED(MANUAL) 0877- 22100-H7680 DISTRIBUTOR-ASSY (D4F7-01) FED(GFU) 0877- 22100-H7280 DISTRIBUTOR-ASSY (D4F6-01) FED(GFU) 1276-0777 22100-H7365 ASSY-DISTRIBUTOR (D4F5-05) CAL(AUTO) 0876- 22100-H7306 ASSY-DISTRIBUTOR (D4F4-02) CAL(AUTO) -0776 22100-H7360 ASSY-DISTRIBUTOR (D4F5-03) CAL(MANUAL) 0876- 22100-H7302 ASSY-DISTRIBUTOR (D4F5-01) CAL(MANUAL) 0875-0776 22100-H7301 ASSY-DISTRIBUTOR (D4F4-01) CAL(MANUAL) -0775 22110-H7301 SET GOVERNOR SPRING (2) FED 0877- 22110-H7300 SET-GOVERNOR SPRING CAL(MANUAL) -0775 22110-H7301 SET-COVERNOR SPRING CAL(MANUAL) 0875- 22110-H7780 SET-GOVERNOR SPRING FED(GFU) 0877- 22110-H7280 SET-GOVERNOR SPRING FED(GFU) 1276-0777 22132-H7280 ROTOR SHAFT-ASSY FED(GFU) 1276-0777 22132-H7780 ROTOR SHAFT-ASSY FED(GFU) 0877- 22132-H7300 ASSY-ROTOR SHAFT CAL 22132-H7300 ASSY-ROTOR SHAFT FED 0877- 22301-H7205 VACUUM CONTROL ASSY FED(AUTO) 0877- 22301-H7360 VACUUM CONTROL ASSY FED(MANUAL) 0877- 22301-H7680 VACUUM CONTROL-ASSY FED(GFU) 0877- 22301-H8300 VACUUM CONTROL-ASSY FED(GFU) 1276-0777 22301-H7200 ASSY-VACUUM CONTROL CAL(MANUAL) -0775 22301-H7201 ASSY-VACUUM CONTROL CAL(MANUAL) 0875-0776 22301-H7360 ASSY-VACUUM CONTROL CAL(MANUAL) 0876- 22301-H7205 ASSY-VACUUM CONTROL CAL(AUTO) -0776 22301-H7365 ASSY-VACUUM CONTROL CAL(AUTO) 0876-
EI GUTS 22115-H7300 SET-RELUCTOR 22136-N4200 ASSY-BRAKER PLATE 22229-N4302 SET-PICK UP 2 22229-N4301 22229-N4301 SET-PICK UP 22145-N4200 CONTACTOR 22116-N4200 CAP-SETTER 01211-00111 NUT-FOR TERMINAL 01211-00121 NUT-FOR TERMINAL 01321-00051 WASHER-LOCK 01321-00041 WASHER-LOCK 08360-61226 BOLT DIST TO BLOCK FED 0877-
