Vacuum Control
Revision as of 11:22, 7 January 2012; view current revision
See:
Distributor
Carburetor
Emission Controls
B110 RAW LIST
11810-A3500 ASSY-CONTROL VALVE CRANK CASE EMISSIO
11826-H1000 HOSE-ROCKER COVER TO AIR CLEANER
11826-H1900 HOSE-ROCKER COVER TO AIR CLEANER
11826-H3900 HOSE-ROCKER COVER TO AIR CLEANER
11828-H1001 HOSE-PIPE CONNECTOR TO CONTROL VALV [PCV]
16439-10802 CLAMP-HOSE
16572-10801 CLAMP-HOSE
16572-H7260 CLAMP-HOSE
16572-H1000 CLAMP-HOSE
11830-H1001 CONNECTOR-PIPE
11830-H1900 CONNECTOR-PIPE
11830-H1901 CONNECTOR-PIPE
14920-H1906 ASSY-VALVE CONTROL
14920-H1902 ASSY-VALVE CONTROL
14920-H7101 ASSY-VALVE CONTROL
14920-H7100 ASSY-VALVE CONTROL
14920-H7001 ASSY-VALVE CONTROL
14920-H7000 ASSY-VALVE CONTROL
14920-H1903 ASSY-VALVE CONTROL
14920-H1901 ASSY-VALVE CONTROL
14920-H1908 ASSY-VALVE,CONTROL
14920-H1907 ASSY-VALVE,CONTROL
14920-H1900 ASSY-VALVE CONTROL
14920-H1905 ASSY-VALVE CONTROL
08120-61210 BOLT-HEX M6
08915-1361A WASHER-LOCK M6
08915-13610 WASHER-LOCK M6
B2318-N3300 TUBE-VACUUM L=150 IN TAKE MANIFOLD TO [?]
14917-E4600 TUBE-VACUUM L=150 IN TAKE MANIFOLD TO
14918-H1900 TUBE-VACUUM L=105 IN TAKE MANIFOLD TO
14917-H1901 TUBE-VACUUM L=170 CONTROL VALVE TO CAR
02141-319W0 TUBE-VACUUM L=5000 CONTROL VALVE TO CAR
B2318-73002 TUBE-VACUUM L=5000 CONTROL VALVE TO CAR
14917-H1901 TUBE-VACUUM L=260 CONTROL VALVE TO CAR
14917-H1900 TUBE-VACUUM L=260 CONTROL VALVE TO CAR
02141-319W0 TUBE-VACUUM L=155 CONTROL VALVE TO AIR
B2318-73002 TUBE-VACUUM L=155 CONTROL VALVE TO AIR
14875-A3000 CONNECTOR-VACUUM TO IN TAKE MANIFOLD
14875-H1900 CONNECTOR
24220-B0100 CLIP-CABLE
14910-A5500 ASSY-VALVE FLOW GUIDE
14910-A5501 ASSY-VALVE FLOW GUIDE
14910-A5502 ASSY-VALVE FLOW GUIDE
14910-H3900 ASSY-VALVE FLOW GUIDE
14910-H3901 ASSY-VALVE FLOW GUIDE
14910-H3902 ASSY-VALVE FLOW GUIDE
14910-N2203 ASSY-VALVE FLOW GUID
14913-A5500 TUBE-EVAPO CONTROL L=200
14913-A5501 TUBE-EVAPO CONTROL L=200
14910-N2200 ASSY-VALVE FLOW GUIDE
14910-N2202 ASSY-VALVE FLOW GUIDE
16439-A0602 CLAMP-HOSE
08915-13610 WASHER-SPRING
14911-A5500 TUBE-EVAPO CONTROL(L=80)
14915-H3900 CONNECTOR-3 WAY
22318-C0601 TUBE-VACUUM CONTROL(L=135)
14955-H3900 ASSY-VALVE,VACUUM CUTTING
08120-62010 BOLT
14956-H3900 ASSY-TUBE,RUBBER,WITH ORIFICE (L=5
14956-H3901 ASSY-TUBE,RUBBER,WITH ORIFICE (L=6
14960-H3900 CONNECTOR-3 WAY
24220-B0100 CLIP-TUBE
08120-62010 BOLT
