Front Combination Lamp
Revision as of 06:53, 17 May 2012; view current revision
All 1200 body style use the same Front Combination Light Assembly (Coupe/Sedan/Van/Truck). But it varies by country and by year. USA has single-bulb, Japan has dual-bulb. Sunny Truck after 1973 has dual-reflector type.
Market Differences
Front running light lenses are either all-orange or white + orange. Reportedly the lamp housing is different so that you cannot simply swap lenses.
Europe, Australia (two-color)
Japan, America (single-color, but are different)
Japan - Single Reflector (early) 3-wire Large + small bulb
Japan - Twin Reflector (late model) 3-wire 2-large-bulb
USA - 2-wire
Offset Reflector
Centered Reflector
Body Style
Early Versus Late
Sunny Truck 1200 after September 1973 use a dual-reflector lens. Earlier 1200 Trucks use a single-reflector lense.
This uses the same lenses as B210, but the housings are different in that 1200 has bullet connectors, while B210 has multi-connector.
Interchange 1200 with B210: Probable, but requires wiring connector change.
Wiring Differences
1200 bullet connectors (B110 or B120)
B210 single multi-connector
510 Lamps
Do not confuse 1200 front lamps with 510 laps. They look very similar but the 1200 unit is more rounded.
Clear Lenses
Get the right kind of your assembly
  • Euro/Aussie
  • Japan single-reflector
  • Japan dual-reflector
  • USA single-bulb, single-reflector
B140
The late-model B140 Bakkie has the front combination lamp in the front bumper.
