Datsun 1200 Trucks look good with a canopy.
Contents[hide] |
Bakkie
In South Africa, fitting a canopy to the B140 is very popular.
http://www.chariots-auto.co.za
SA Canopy
SA CANOPY 2010 LIST NSA001 NISSAN 1400 HD F/G/D NSA001AV NISSAN 1400 HD F/G/D + AIRVENT NSA065 NISSAN 1400 HD F/G/D - B/SIDES NSA085 NISSAN 1400 HD F/G/D - C/BLANK NSA004 NISSAN 1400 FULL DOOR NSA055 NISSAN 1400 FULL DOOR - B/SIDES NSA103 NISSAN 1400 FULL DOOR - C/BLANK NSA128 NISSAN 1400 HD F/G/D SPORT NSA131 NISSAN 1400 SPACESAVER
SA Canopy Carryboy SA Series
Canopy King
Classic Half Door
Classic Full Door
Bucco
Sadly, it seem Bucco is no longer selling B140 canopies.
Nissan 1400 Full Door Canopy
Nissan 1400 Half Door Canopy
- Canopy bolted to vehicle as standard fitting for higher safety
2-Bar Roof Rack as a standard feature - feet are made from non-corrosive high tensile plastic and cross-bars are epoxy coated oval steel tubes (100Kgs Max. Load)
- Fibreglass double skinned lockable rear lif-up door with large toughened automotive safety glass for greater visibility, heavy duty double gas struts opening mechanism and two-way locking mechanism which locks door to reinforced side plates for greater stability
- Sliding lockable windows and additional fixed windows are rubber mounted (kick-out) on each side with maximum length toughened automotive safety glass
- Canopy is designed to seal to the rear of the vehicle's cab and easy access is obtained through the vehicle's rear cab sliding window.
Optional extras:
- Colour coding to match the vehicle colour
- Window tinting to reduce internal heat and for greater safety
- Non-slip Polyurethane Lining to vehicle's bin
- 3rd Brake Light fitted to the rear of the canopy
- Fitted PVC Air Vents
- Excalibur Running Boards
- Internal Switchable Strip Light
- Heavy Duty Roof Rack (250Kg Max. Load)
- Clip-on adaption for easily removable canopy (for safety reasons, not recommended)
- Woven Rubber Bin Mat
- Tow Bar and/or Bull Bar
- Internal or external burglar guards for all canopy windows.
Bakkie Canopy Photo Index
More photos at Bakkie Gallery
