Canopy
Revision as of 20:23, 27 February 2013; view current revision
Category: Body
Datsun 1200 Trucks look good with a canopy.
2784.jpg 2785.jpg 2836.jpg 8770.jpg 12898.jpg 12899.jpg 12946.jpg 13507.jpg 10789.jpg
[hide]
Bakkie
In South Africa, fitting a canopy to the B140 is very popular.
http://www.chariots-auto.co.za
Stingray Marine Canopies
SA Canopy
http://sacanopy.co.za
SA CANOPY 2010 LIST
NSA001 NISSAN 1400 HD F/G/D
NSA001AV NISSAN 1400 HD F/G/D + AIRVENT
NSA065 NISSAN 1400 HD F/G/D - B/SIDES
NSA085 NISSAN 1400 HD F/G/D - C/BLANK
NSA004 NISSAN 1400 FULL DOOR
NSA055 NISSAN 1400 FULL DOOR - B/SIDES
NSA103 NISSAN 1400 FULL DOOR - C/BLANK
NSA128 NISSAN 1400 HD F/G/D SPORT
NSA131 NISSAN 1400 SPACESAVER
SA Canopy Carryboy SA Series
SA Canopy
Canopy King
http://www.canopyking.com
Classic Half Door
Classic Full Door
Bucco
Sadly, it seem Bucco is no longer selling B140 canopies.
Nissan 1400 Full Door Canopy
Nissan 1400 Half Door Canopy
  • Canopy bolted to vehicle as standard fitting for higher safety
2-Bar Roof Rack as a standard feature - feet are made from non-corrosive high tensile plastic and cross-bars are epoxy coated oval steel tubes (100Kgs Max. Load)
  • Fibreglass double skinned lockable rear lif-up door with large toughened automotive safety glass for greater visibility, heavy duty double gas struts opening mechanism and two-way locking mechanism which locks door to reinforced side plates for greater stability
  • Sliding lockable windows and additional fixed windows are rubber mounted (kick-out) on each side with maximum length toughened automotive safety glass
  • Canopy is designed to seal to the rear of the vehicle's cab and easy access is obtained through the vehicle's rear cab sliding window.
Optional extras:
  • Colour coding to match the vehicle colour
  • Window tinting to reduce internal heat and for greater safety
  • Non-slip Polyurethane Lining to vehicle's bin
  • 3rd Brake Light fitted to the rear of the canopy
  • Fitted PVC Air Vents
  • Excalibur Running Boards
  • Internal Switchable Strip Light
  • Heavy Duty Roof Rack (250Kg Max. Load)
  • Clip-on adaption for easily removable canopy (for safety reasons, not recommended)
  • Woven Rubber Bin Mat
  • Tow Bar and/or Bull Bar
  • Internal or external burglar guards for all canopy windows.
Bakkie Canopy Photo Index
More photos at Bakkie Gallery
th_0d18_20.jpg th_4b85_20.jpg th_4cf1_20.jpg th_05c5_20.jpg th_6d43_20.jpg th_9f69_20.jpg th_058a_20.jpg th_061c_20.jpg th_065e_20.jpg th_85c7_20.jpg th_91c3_20-X.jpg th_493e_20.jpg th_01011eg_20.jpg th_1530amb_20.jpg th_2469kjm_20.jpg th_02582nf_20.jpg th_02786ii_20.jpg th_4724lhb_20.jpg th_4822dnm_20.jpg th_5585c97_20.jpg th_5789_20.jpg th_6147i1n_20.jpg th_6670cha_20.jpg th_7331mn3_20.jpg th_7400ahm_20.jpg th_8179hgl_20.jpg th_8182dib_20.jpg
