Throttle Cable
Revision as of 02:24, 13 May 2013; view current revision
Category: Fuel System
Datsun 1200 uses a throttle cable with twisted-braid steel core. A cable is better than linkage for smooth throttle action. RHD and LHD differ by length.
Ends
Both RHD and LHD use the same clip on the interior to fix the cable to the Accelerator Pedal.
  • 18036-18000 SPRING-CLAMP ACCELERATOR WIRE
    fixes cable to accelerator pedal
Ferrule end (that clamps to the carburetor)
  • 8mm diameter x 21mm long ALL
Cable
Since the carburetor is always on the same side, the accelerator cable length is different for RHD and LHD models.
When replacing, adjust cable for 1mm play at the carburetor cable clamp.
Left-Hand Drive
  • B110: A8200-G1300 ASSY-WIRE ACCELERATOR [40 mm length] $7.30 USD
    • Superceded old part number 18200-H1600
  • B210: 18200-H7200 ASSY-WIRE ACCELERATOR A14 FED(GFU) From 12/76 $20.81 USD
  • B210: 18200-H6102 ASSY-WIRE ACCELERATOR $19.08 USD
    • Superceded 18200-H6100
Length measured firewall to end of cable ferrule
  • B110: 40 mm long ball-end
  • B210: 43.5 mm long ball-end
  • B310: 40 mm long eyelet-end
Right-Hand Drive
  • 18200-H1000 WIRE ASS'Y-accelerator B110 [85 cm length, tube 72cm]
    • 18211-18001 RING-wire clamp
  • 18200-G1601 ASSY-WIRE ACCELERATOR B120 -8910
  • 18201-95W00 ASSY-WIRE ACCELERATOR B120 8910-
    • 24222-89901 CLIP-WIRE, ACCELERATOR 9810-
Other Part Numbers
  • 18200-18000 WIRE ASS'Y-accelerator B10 superceded
  • 18200-18001 WIRE ASS'Y-accelerator B10 replaces 18200-18000
  • 18200-27700 WIRE ASS'Y-accelerator B10 replaces 18200-18001
  • 18200-H5000 WIRE ASS'Y-ACCELERATOR B210 early
  • 18200-H5005 WIRE ASS'Y-ACCELERATOR B210 early GL op. and late B210
  • 18200-H5205 WIRE ASS'Y-ACCELERATOR B210 GX A12T
  • 18200-H7510 WIRE ASS'Y-ACCELERATOR B210 A14T
  • 18200-H7900 WIRE ASS'Y-ACCELERATOR B210 L16
  • 18200-H8501 WIRE ASS'Y-ACCELERATOR B310 Rockauto $11
  • 18200-H8502 WIRE ASS'Y-ACCELERATOR B310 NLA
  • 18200-H9205 WIRE ASS'Y-ACCELERATOR B310 A14E, A15E
GX Cable Routing
GX uses same cable as others RHD Datsun 1200s.
Weber DGV Cable
See DGV#Throttle_linkage
Sidedraft Cable
Also see: Weber_DCOE_carburetor#Linkage
556.gif 1113.jpg 1114.jpg 1115.jpg 3422.jpg 3461.jpg 3503.jpg 5212.jpg 6581.jpg 8988.jpg 9463.jpg 11368.jpg 11497.jpg 11506.jpg
B110 Catalog
18200-H1600 ASSY-WIRE ACCELERATOR
