Choices
- get pre-made lines of various lengths and bend and install it yourself
- get brake line material and fittings and cut it, flare it and fit it
- pay a shop to make and install custom lines
- buy genuine brake lines from Nissan and install. The ute parts are still available, and most will fit a Sedan or Coupe.
The first two are available at the usual spare auto parts stores, or mail order from hot rod stores.
Right Hand Drive (1) front drums (2) front discs
1 46223-H1001 TUBE ASS'Y-brake master cylinder to connector (up to '72-7) (Single M/C) 1 46223-H3200 TUBE ASS'Y-brake master cylinder to connector 1 46223-H3201 TUBE ASS'Y-brake master cylinder to connector (from '72-8) (Tandem M/C) 2 46234-H1000 CONNECTOR-brake tube (4-way)(up to '72-7)(Single M/C)
Disc Brakes, Left Hand Drive, Tandem Cylinder
46223-H1901 ASSY-TUBE BRAKE MASTER CYL. FR(TANDEM)TO 46223-H3900 ASSY-TUBE,B/MASTER CYL.FR (TANDEM) TO 46223-H3901 ASSY-TUBE,B/MASTER CYL. FR (TANDEM) TO 46223-G1300 ASSY-TUBE,B/MASTER CYL. FR (TANDEM) TO 46223-H1900 ASSY-TUBE BRAKE MASTER CYL FR(TANDEM)TO 46224-H3901 ASSY-TUBE,B/MASTER CYL. RR (TANDEM) TO 46224-H1900 ASSY-TUBE BRAKE MASTER CYL RR(TANDEM)TO 46224-H1901 ASSY-TUBE BRAKE MASTER CYL. RR(TANDEM)TO 46224-H3900 ASSY-TUBE,B/MASTER CYL.RR (TANDEM) TO 46100-26100 ASSY-SWITCH BRAKE INDICATOR 46100-U5200 ASSY-SWITCH BRAKE INDICATOR 08360-63514 SCREW-MACHINE WITH WASHER 46240-H1900 ASSY-TUBE BRAKE FRONT RH FOR TANDEM B 46240-H1901 ASSY-TUBE BRAKE FRONT RH FORTANDEM BRAKE 46240-G1300 ASSY-TUBE BRAKE FRONT RH FORTANDEM BRAKE 46242-H1900 ASSY-TUBE BRAKE FRONT LH FOR TANDEM B 46242-H1901 ASSY-TUBE BRAKE FRONT LH FORTANDEM BRAKE 46242-G1300 ASSY-TUBE BRAKE FRONT LH FORTANDEM BRAKE 46280-H1902 ASSY-TUBE CONNECTOR TO REAR FOR TANDEM B 46280-H1905 ASSY-TUBE CONNECTOR TO REAR 46280-H1906 ASSY-TUBE CONNECTOR TO REAR 46280-H1901 ASSY-TUBE CONNECTOR TO REAR FOR TANDEM B 46280-H1902 ASSY-TUBE CONNECTOR TO REAR FOR TANDEM B 46313-18000 CONNECTOR-3WAY REAR 02463-13200 CONNECTOR-3WAY REAR 08110-82562 BOLT-HEX WITH WASHER M8 46290-H5501 ASSY-TUBE REAR BRAKE RH 46290-H7301 ASSY-TUBE REAR BRAKE RH 46290-H1000 ASSY-TUBE REAR BRAKE RH 46290-H1001 ASSY-TUBE REAR BRAKE RH 46290-H5001 ASSY-TUBE REAR BRAKE RH 46290-H7201 ASSY-TUBE REAR BRAKE RH 46310-H5501 ASSY-TUBE REAR BRAKE LH 46310-H5001 ASSY-TUBE REAR BRAKE LH 46310-H1000 ASSY-TUBE REAR BRAKE LH 46310-H1001 ASSY-TUBE REAR BRAKE LH 46201-89918 ASSY-HOSE BRAKE REAR L=330 46201-H7200 ASSY-HOSE BRAKE REAR L=330 46237-18000 GASKET-BRAKE HOSE TO TUBE 46205-61000 PLATE-LOCK BRAKE HOSE 46206-18000 SPRING-LOCK BRAKE HOSE
