Injectors
Revision as of 06:04, 3 September 2013; view current revision
Category: EFI
INJECTOR ASSY-FUEL 16600
SR: side-feed injectors (mostly)
CA: top-feed injectors, low impedance (requires dropping resistor)
RB: top-feed injectors, low impedance
Colors
Wheel HP listed is appropiate power level of the injector set for a conservative tune (not saturating the injectors).
Side-feed Injectors
185cc 125whp Pink GA16
259cc 175whp Red SR20DE
333cc 226whp Grey SR20VE
370cc 250whp Purple SR20DET
444cc 300whp Brown SR20DET (S15)
Top-feed Injectors
260cc 175wgp Red CA18DE
370cc 250whp Cream CA18DET
350cc 275whp Green SR20VE 20V P12
444cc 300whp Yellow SR20DET (GTiR), SR20VET
CA-Series
CA18DE - YELLOW OR GREEN high power engines
CA18DE - RED low power engines
16600-35F05 JECS キイロ/YELLOW <> 16600-35F01 <> 16600-35F00 DKC キイロ/YELLOW [330cc???]
* S13 CA18D
16600-35F10 (OPTION) JECS ミドリ/GREEN <> 16600-35F11 <> 16600-35F15 DKC ミドリ/GREEN
* S13 CA18D
CA18DET - 370cc???
16600-56E00 JECS <> 16600-56E01 <> 16600-56E05 DKC
* RS13/S13 CA18DT, U12 CA18DT
SR-Series
SR20DE
16600-52F10 センタク シヨウ ミドル/SELECT USE GREEN <> 16600-52F12
* S13 SR20D, RS13 SR20DE
16600-52F00 センタク シヨウ ミドル/SELECT USE GREEN <> 16600-52F02
SR20DET
16600-50F00 センタク シヨウ キイロ/SELECT USE YELLOW <> 16600-50F02
* RS13, S13
16600-50F10 センタク シヨウ ミドル/SELECT USE GREEN <> 16600-50F12
* RS13, S13
Bosch Grey top feed, high impedance, 365cc
* JAPAN Primera, USA Sentra 2000-2002
RB-series
440cc
