910 (Bluebird/Maxima/810) Brake Rotors can be modified to bolt to the back of the 1200 hub. The rotor's PCD needs to be modified from 95mm to 87mm.
Usage
USA: 250 mm (same as the smallest S13 size) EUR: 238 mm JAP: 250 mm or 238 mm
250 mm Nissan 40206-W1210 40206-W1260 40206-W1265 40206-W1270 Girling 6019401 Brembo 09.4789.10 * height: 22mm * center hole: 73 mm * PCD: 4 on 95 mm, 10.7mm holes * thickness: 18mm * weight: 4.13 kg * also used by EUR C120, JAP C120
238 mm Nissan 40206-W1010 40206-W1060 40206-W1070 * 238 mm * height: 22mm * center hole: 73 mm * thickness: 18mm * also used by JAP C120, EUR C120
Rear Discs
Maxima rear Calipers and Sentra 240mm rotors can be modified for use on the H165
Which Maxima is it?
A32 EUR 43206-31U12 5-lug
J30 EUR 43206-88E01 5-lug 43206-88E03
