Wheels
Revision as of 09:00, 23 January 2015; view current revision
Category: Wheel And Tire
Stock Wheels
  • 12" diameter
  • 4-inch wide
  • bolt-pattern: 4 on 4-1/2 inch circle (4 x 114.3 PCD)
Comparison of B110, B210, B310 wheels
wheelsB10B1101977 US B210 A141980 NA B310
size3-1/2 J-124 J-124-1/2 J-134-1/2 J-13
5 J-13 (aluminum)
Canada w/A12A: 4J-12
offset?30 mm30mm offset30mm
25 mm (aluminum)
tire size?-126.00-12
155SR-12
155SR-136.00-12
155SR13
175/70SR13
balance10gr or less (0.35 oz)11gr or less10gr or less
lugnut torque  8-9kg-m (58-65 ft-lb)8-9kg-m8-10
Datsun Option Wheels
Options
  • 40300-N5825 WHEEL SET-ROAD ALUMINIUM, B TYPE (5JX13)
  • 40300-W6625 WHEEL SET-ROAD ALUMINIUM, C TYPE (5JX13)
  • Also used on 200SX (S10 silvia) 1977-1979
fullsize
B310 Wheels
  • 40300-W8300 WHEEL ASSY-ROAD(4 1/2-JX13) (STYLED) 0879-
ホイール
510
510 came with 4x13 wheels (4.5x13 option?), and are often used on 1200s. Offset is +30(?).
Lug Nuts
M12x1.25 thread
  • B110: Nuts are 19mm hex head (~3/4 inch)
  • B210: 13/16" lug nuts
See main article Wheel Studs
Torque
  • 8.0-9.0 kg/m (58-65 ft-lb)
Wheel Balance
  • Maximum allowable unbalance at rim flange: 10 gr (0.35 oz)
  • Tire balancing weight: 10-70 gr (0.35-2.47 oz), spacing 10 gr (0.35 oz)
Wheel Offset
STOCK = 30 mm offset
* Choosing Wheel Offset for wide tires
* Selecting compatible FWD Wheels
* Measuring Offset
* Offset size that work with stock bodywork
Scrub Radius
scrub radius. its the distance from the centre of the tyre contact patch to where SAI intersects the ground.
'+' scrub radius where the centre of tyre contact patch is outside SAI, '-' where its inside the SAI.
Largest Sizes to Fit 1200
  • Front: 3.25" is the maximum backspace (which is used by the stock 4" wheel). So if going wider, the offest must be reduced from +30.
  • Rear: +30 offset works best with Datsun 1200.
16"
  • 4": B110 12" stockers are 4" wide with +30 offset
  • 4.5": B310 13" +30 stockers won't fit the front of the 1200. They hit the brake calipers, which may be related to the shape of the wheel.
  • 5.5": Most with appropriate offset will fit a Datsun 1200. 15mm offset wheels fit nicely under the front guards, but look anemic on the rear.
  • 6-inch wide wheels: most will not fit, but a zero offset will.
  • 6.5": the biggest 15s you can put on are +24 15x6.5 even then they stick out a couple of mm past the fenders
  • 6.5" 16s with a 40mm offset (silvia wheels or R32 skyline stock rims fit this). These wheels are the limit, I have 195/45 R16 on it and they sit within the guard and don't rub anything....but the front of the guard has been altered.
  • 7" Reportedly 13x7 +0 fits perfectly
  • 7" wide wheels with offset of +10 require front guards modification (they will rub on the fenders). At full lock -- depending on the tires -- the fronts will probably scrub inside the guards
  • 7" 14s with 0 offset sit flush with the rear and poke a little on the front. More positive offset bring them inside, but then you risk hitting the struts
  • 7": 15s +10 offset on fronts and +2 offset on rears. Tires rub a little at full lock. With pumped guards with possibly 15x7 -2 offset would work better.
  • 7": I have 14x7 on my 1200. With zero offset. It is a tight fit with stretched tires. Mine have 175/60R14 tires, so obviously they are stretched over the 7 inch wide rim.
IMPORTANT
Height has little to do with your wheel, but
more to do with the tire. See Tires
a 195-width tire will fit if
small enough diameter (e.g. 195-50R15)
You may need to roll the fender.
Rear
  • 7": 13x7 with 0 offset and they fill the gaurds perfectly. The tire will be under the guard lip, and will rub if the 1200 is lowered unless the tires are very small diameter.
  • 8.5": 13" -15 with 175/60R13
Ute Rear
Wheel Adapters
Wheel Spacers
If the offset is too negative, they will fit the fenders (guards) and there is nothing you can do except cut out the bodywork, perhaps fitting large flares.
10064.jpg re-drilled axle flange
Suppliers
See Rims
Aftermarket Wheels
See Rims
Compatible Wheels
  • Rear-wheel drive Toyota
  • 1960s Ford Falcon and Mustang 4-lug (6-cylinder models)
  • Chevrolet Corvair (5 x 13)
    • pefect for the rear
    • may need a 1/4 inch spacer on fronts to clear the brake caliper
  • Rear-wheel drive Datsun & Nissan models.
  • Datsun B310 wheels fit the rear, but do not fit the front of Datsun 1200
  • Datsun 240Z wheels -- 14"
  • Uni-lug alloy wheels
  • Rear-wheel-drive Mitsubishi
  • Skyline R31 spare steel wheels (14")
What WONT work:
  • early Honda
  • Isuzu/Holden Gemini
  • Ford Escort/Cortina
  • early Mazda
  • Subaru
  • some SAAB
  • Ford Escort/Pinto/Mustang II/Mustang Fox
FWD Rims
  • Acura Legend 1986-1990 (15x6", 64.1 center hole)
  • Acura Vigor 1991-1994
  • Acura TC 1992-1995
  • Acura TL 2.5 1995- (15x6", 64.1 center hole)
  • Acura CL 2.2/3.0 1995- (15x6", 64.1 center hole)
  • Chevrolet Sprint 1988-1989 (12x4, 10mm studs, 59.6 center)
  • Ford Festiva 1987-1993 (12x4)
  • Ford Laser (KA to KH)
  • Geo Metro 1989-1997 (12x4, 10mm studs, 59.6 center)
  • Honda Accord 1990- (14x6, 15x6, 64.1 center)
  • Hyundai Excel
  • Kia 2001- (67.1 center)
  • SAAB 99 1968-1980 (5.5 inch wide, needs spacer)
  • SAAB 900, 900 Turbo 1979-1987 (needs spacer)
  • Suzuki 1989- including Swift, Aerio, Verona, Reno, Forenza
  • Volvo 40-series 1998- including 15x6 (centers need boring out to 70mm)
Saab Wheels
Unknown Saab rims
  • 1979-1983 SAAB 900
  • 1984-1987 SAAB 900, 900 Turbo (6" wide, needs spacer) 71.5 centers
Sigma Rims
Sigma Turbo rims 15 inch 4x114.3
3914.jpg 3917.jpg 4162.jpg 3440.jpg 15x6
Sigma Turbo
14X6JJ GK/N SE sigma rims
sigma mags 14x5.5 195x65x14
Toyoda
Corolla
Nissan-Datsun Wheels
S13 Rims
15" x 6" +40, 4 Lug, 4.5" Bolt Pattern, 10-hole
* Base: 195/60R15
* SE: 205/60R15
10-hole Spare
15" x 4", 4 Lug, 4.5" Bolt Pattern
Pursuit/chaser" style wheel may be used on Datsun 1200.
See main article: Pursuits
TRX Wheels
Alloy wheels from Datsun 910 "Bluebird Series II" Australia TRX package work nicely on a Datsun 1200.
See main article: TRX Wheels
Stanza SSS
Australian-assembled 1981-1983 Stanza SSS (PA10MX) has 13" alloy rims.
SSS wheels reportedly not fit 1200 without spacers.
1200 with SSS wheels
Stanza SSS
sss
C22
USA C22
40300-V6104 5.5-JJX14 +40 <> 40300-V6120
40300-V8000 SPARE <> 40300-V8077 [8-hole steel]
40300-17C25 AL [turbine]
810
810 Datsun 810/200B/180B/Bluebird
40300-R4671 40300-U8925
910
USA 910 "Datsun 810" and "Maxima"
40300-N8810
40300-N8870 <1>  40300-N8804
40300-W1000
40300-W1004 <5>  40300-W1014
40300-W1070 <5>  40300-W1004
40300-W2426
40300-W2428
Pulsar
Pulsar Turbo
F31
Nissan F31 was badged "Nissan Leopard" or "Infiniti M30".
buy at rtw wheels
buy at wheel collision
1990-1992 Infiniti M30
slanted 8 slot
15 x 6.5 +25
4 on 4-1/2 bolt circle
Pilot hole diameter 66 mm
23 lbs
left & right wheels
F31 Japan
8602-8808
 14x5.5+30 7-slot styled steel
   40300-58L05 8602-8702 VG20 [F31,C32]
   40300-58L07 8702-8808 VG20 [F31,C32]
 15x6+30 10-slot styled steel
   40300-59S00 8602-8702 V20T.XS [F31,C32,R31]
   40300-59S07 8702-8808 V20T.XS GOLD [F31,C32,R31]
               8808-9805 VG20E *(VG20DT+VG30#)
   40300-59S08 8905- VG20E *(VG20DT+VG30#) CHROME [F31]
8602-8808 spare steel 4x15 4-slot
  VG20 40300-03E00 8602-8808 <> 40300-28E15 <7> 40300-16E15
  VG30.ULTIMA 40300-59S15 8602-8808
  ALL 40300-59S15 8808-
8602-8603- alloy 8-slant/spoke 6.5x15
  40300-F6226 RH 8808- <> 40300-F6228 GOLD VG20DT+VG30# *VG20E
  40300-F6626 RH 8808- <> 40300-F6628 SILVER VG20DT+VG30# *VG20E
  40300-F6627 LH <> 40300-F6225
  40300-F6526 8602-8808 <> 40300-F6528 VG20T.XS2+VG30D.ULTIMA *(*VG20E.XJ#+*VG20T.XS)
  40300-F6527 LH
Spare Tire
15x4T+40
40300-28E15 キイロ 4ケシ 60ネン キネンシヤ <> 40300-03E00 <7> 40300-16E15
* C23 Vanette
* M10/M11
* S12/S13/RS13 Silvia
* W10
* T12/T12Y
* A31
* F31
* R31
* C32/C33
* P10/P10E
* R32
* U11/U12/U13
40300-16E15 15x4T BLACK steel クロ <7> 40300-28E15
* B15
* C23
* K30S
* P11/P11E
* R33
* RS13/S14
* U14
* W10/WP11
* C34
* U13
S110
S110 1980-1983 Nissan Silvia Datsun 200SX/180SX/240RS
40300-N8810 4TX16 SPARE
40300-N8900 5JX14 0179-0783
40300-N8910 5JX14 0781-1081
40300-N8427 5.5JJX14 AL [16-spoke]
40300-N8825 5.5JJX14 AL <4> 40300-11S25 [16-spoke 5.5x14 +25]
40300-S6027 5.5JJX14 AL <4> 40300-N8427 [32-spoke 5.5JJ14 25]
EXA Rims
EXA wheels N12 or N13 ???
Similar
Cheviot 13x5.5
S13
RS13 (180SX)
R30 Rims
15 X 6 Skyline R30 wheels
20-spoke 15x6
