Early 1200 Sunny Truck/Ute/Bakkie badges are mostly re-used from sedan or coupe but in unique combinations.
World-market trucks generally use the same badges as JDM models, except use "D" badging instead of "S" badging, plus the timing of changes varies by a few months.
LHD Badges
* Okinawa used 'S' and 'Sunny'
* Other LHD markets use 'D' and 'Datsun'
Sunny Truck/Ute
"Sunny Truck" was the name given to the Japan-market 1200 pickup. "Ute" is the common name for the Australia-market pickup.
Front
62311 ORNAMENT-FRONT オーナメント、フロント
Early
Trucks to early 1978 used Sedan grille and emblems "D" (Export) or "S" (JDM)
* -7804 62312-H1026 ORNAMENT-FRONT 'S' [round] * -7801 62312-H1026 ORNAMENT-FRONT 'D'[round]![]()
Mid-model
Early 1978 to late 1989 trucks used Coupe-like grille with unique rectangular center emblem
"D" (Export) or "S" (JDM) with black or red background * 62312-G1025 7804-7907 'S' [rectangular, black]![]()
* 62312-G1260 7802- 'D' [rectangular, black] * 62312-G1261 7804- 'D' [rectangular, black] * 62312-G1225 7802- 'D' [rectangular, black] with nut and washer
* 62312-G1625 7908-8503 [rectangular, red]
* 62312-G1660 8504-8910 [rectangular, red]
Late
8911-1994 trucks use a square headlight grill with 'NISSAN' emblem on left side
* 62392-G1265 ORNAMENT-FRONT 9810- カクガタ NISSAN![]()
Side Emblems
78801 EMBLEM-SIDE REAR, RH エンブレム、サイッド リヤ RH
NOTE: Export models used no side badges
Sunny Truck intro-7409 only DX comes with side emblems 7510-8102 'Sunny' script sedan-type sedan side emblems 8103-8910 'SUNNY' block-type side emblems 8911-up: no side emblems
Early Side Emblem
* 76854-H1000 -7510 DX [same as Sedan side badge] * 76854-H1050 7510-8102 ALL チユーブラー トメ [cursive]![]()
Mid-model Side Emblem
76854-G1900 8103-8910 セシチヤク トメ [similar to B310 Van side emblem]
Rear
Model
Below RH tailgate latch
Early [same as Sedan badge] 84822-H1000 EMBLEM-trunk lid (SUNNY 1200) -7907 トランク リッド エンブレム84822-H1600 'Datsun 1200' script -7510
Mid-model 7511-7907 'DATSUN 1200' [sticker, similar to B140 fender badge]
Trim
84823-H1000 MARK-deluxe DX [fitted below Sunny emblem] JDM -7907 デラックス マーク![]()
Label
96905-15200 LABEL-LOADING CAPACITY -8109 [white on black?]
96905-89900 LABEL-LOADING CAPACITY 8110- [black on silver] Buy at Bprojects![]()
96906-89900 LABEL-FRIGID ZONE 8110-![]()
96908-G5100 LABEL-REAR 'NISSAN' 8910-
96908-G1661 LABEL-REAR 'SUNNY' short body 8110- Buy at Bprojects![]()
96908-G1665 LABEL-REAR 'SUNNY LONG BODY' long body 8110-![]()
Black stickers with silver writing
'Sunny Long Body' sticker
white sticker with black writing
Loading Capacity Label '最大積載量500kg' (Maximum payload 500kg)
Other Label
14807-89910 STICKER-FUEL 7510- 無鉛 Unleaded petrol only * placed on assistant's window![]()
99070-89909 PLATE-MODEL NUMBER 8504-8910 Buy at Bprojects![]()
14806-89901 LABEL-UNLEADED FUEL ONLY 8910- * Inside Fuel Door![]()
14808 LABEL-EMISSION CONTROL,A 14808-G2200 7510-7907 14808-H9460 7908-8109 14808-H9470 8110-8910 14808-95W00 8910-
21435 LABEL-CAUTION,RADIATOR 21450-89900 8110-8504 21435-89900 8504-8910 2 21435-89902 8910- キヤンペ ヨウ キイロ [54 mm diameter] Buy at Projects![]()
99053 LABEL-OIL CAUTION
96903-89921 8110-8503
99053-G1900 8504-8910
99053-79965 8910- Buy at Projects![]()
99072 PLATE-CAUTION 48477-C0400 7510-8910 T/SIGNAL & DIM SW 96920-89900 8110-8306 <2,0> 96920-89910 96920-89910 8307-8910 48477-C0400 8910-
99072M TAG-KEY CAUTION 68215-89903 8110-8910 68215-89901 8910- 99090 PLACARD-TIRE LIMIT 99090-G1660 8110-8910 99090-95W00 8910-
99099 LABEL 21450-89915 8110-8503 LLC ヨウ30 21450-89935*8110-8504 LLC ヨウ50 21450-89916 8504-8910 LLC ヨウ30 21450-89936*8504-8910 LLC ヨウ50 21435-89915 8910- LLC ヨウ30 21435-89945*8910- LLC ヨウ50
B140 Bakkie
Also see: * B140 Badges * B140 Grille
- B140 LDV 1400 Bakkie uses "NISSAN" grille letters
- 2006 Bakkie front with "Nissan" oval grille emblem
