Datsun 1200 standard interior was elk-pattern black vinyl. Blue, Yellow, Ivory and Brown were also available in some markets, as well as fabric patterns.
Black was the original interior trim color. Regardless of exterior/interior color, blue vinyl floor mats were standard.
Black was exclusively used for Ute 1971-1978
Brown was exclusively used 1978-1989
Gray was exclusively used 1989-1994, along with black vinyl floor mats
Sunvisors
See main article: Visors
Door Trim
Door 80510-H1000 ESCUTCHEON-REMOTE CONTROL RH NLA 80511-H1000 ESCUTCHEON-REMOTE CONTROL LH NLA
Window Trim
Front window - 2-dr sedan * 80260-H1000 Handle-vent R $19.67 * 80261-H1000 Handle-vent L $19.67 * 80760-H1000 Handle-regulatr $24.00
Rear window - 2-dr sedan * 76828-H1200 Cover-hinge [rear window] $1.02 USD * 76870-H1200 Handle-window RR $39.17 USD * 76871-H1200 Handle-window RL $40.62 USD ** 80234-H1000 WASHER-BRACKET PIVOT $5.83 USD * 76832-H1201 HINGE-SIDE WINDOW (4) NLA
* 76828-H5300, 76828-H5301 COVER-SIDE WINDOW HINGE B210 [GRAY]
Head Liner
The head lining covers and insulates the roof panel.
See main article: Upholstery#Headliner
Kick Panel
Kick panel is the front side panel, in front of door, under dash.
See main article: Kick Panel
Package Tray
See Package Tray for under-dash compartment
Coin trays
The seat riser trim is the little plastic pockets next to the door|s.
See main article: Seat Riser Trim
Below-door Trim
- 74921-H1100 COVER-FLOOR SIDE FRONT RH
- 74921-H7000 COVER-FLOOR SIDE FRONT RH (BLUE,LB-211
- 74921-H7001 COVER-FLOOR SIDE FRONT RH (BEIGE,LH-20
- 74921-H7002 COVER-FLOOR SIDE FRONT RH (BLACK,LG-13
- 74922-H7001 COVER-FLOOR SIDE FRONT LH (BEIGE,LH-20
- 74922-H7002 COVER-FLOOR SIDE FRONT LH (BLACK,LG-13
- 74922-H1100 COVER-FLOOR SIDE FRONT LH
- 74922-H7000 COVER-FLOOR SIDE FRONT LH (BLUE,LB-211
Parcel Shelf
Parcel shelf is the area above the rear seat, under that rear window.
The original Parcel Shelf is a black-painted thin fiberboard.
Often used to place speakers.
full
TRIM CLIP (10 needed for parcel shelf)
17 79910-H1001 ASSY-PARCEL SHELF SEDAN <x> 79910-H7000 [fireproof] 18 01553-00051 CLIP-PARCEL SHELF (10) 14Ø (from '70-September) 76906-G0511 取付穴9Ø用 (until '70-September) [9 mm mounting hole] 19 79911-H1000 COVER-PARCEL SHELF SEDAN [Cloth trim] 20 79912-H1000 PLUG-PARCEL SHELF SEDAN (4)
* G9910-H7000 Shelf-parcel $63.67
Tattered Cover
Also See
* Carpet
