Wiring up a newer engine with its stock EFI involves getting the entire donor engine-room harness, the computer and all connected wiring. Eight wires from the Nissan harness connect to the car's wiring; there are many wires in the new engine harness, but you only need to identify eight of them to connect up. Use severals relays and new fuses. It's a chore but you'll have OEM EFI -- power and economy both with awesome smoothness.
Nissan uses three relays for EFI:
* Fuel Pump Relay * ECU Relay * ECCS Relay * Properly Fused
We recommend you use the same. The fuel pump relay is wired so that if the engine stops running, they fuel pump will shut off. This is very important in a wreck to help prevent fires.
CAN/AM Wiring Box
A CAN/AM Box (engine swap wiring distribution box) makes EFI wiring swaps easier -- and easier to troubleshoot (though not required).
A Can/Am box is a relay board made by a couple of guys in Seattle. Contact: icehouse
It is certainly not needed for a swap -- you can instead use the relays from the S13/S14 wiring harness, or from other 1990s Nissans. However, the Can/Am box makes for a neat & tidy installation.
CAN/AM "easy wiring box for EFI"make wiring newer EFI Nissan engines into our old Datto's, or any cars for that matter, much simpler. These boxes take the place of the point to point wiring that would normally be done by us "do it yourselfers." Making the wiring easier for the new to wiring guys by following the drawings, which are also under construction. Using this box cuts HOURS out of the EFI wiring as wellThis circuit board contains three relays and proper fuses. Relay for fuel pump, ECU relay, etc. Has terminal blocks for easy wiring: just slide the wires you need in and screw the terminals down. DONE.
Ignition Switch
Newer Datsun ignition switches fit the 1200 (large size) but work slightly different. When the key is in START position, the original switches cut power to IGN. The new switch retain power to IGN. Some say to use this switch. However if wired correctly this is not needed.
The two Ignition Switch wires to tap into and connect to the EFI relays are:
- IGN (B/W wire) You can tap into this at the switch, at the existing Coil wiring in the original vehicle engine room harness, or anywhere else this wire exists.
- START B/Y wire. You can tap into this at the switch, at the existing Starter wiring in the original vehicle engine room harness, at the starter 'S' terminal, or anywhere else this wire exists. Connect this via a 10A fuse to the START ECU signal wire in the harness.
It is recommended to solder a new larger B/Y wire from the ignition switch to the starter, instead of the original small-gauge B/Y for the 1kw oringal starter.
Alternator
Newer Nissan alternators are wired like a late model 1200 Hitachi LR Alternator, but may not use the familiar T-connector of the older alternators.
If you have an early 1200 (1970-1989), remove and discard the external Voltage Regulator. Insert two jumper wires into the plug as per IR Alternator Conversion Wiring.
If you already have your 1200 wired for Hitachi LR wiring, and the new alternator uses an oval plug:
- Connect the alternator thick white wire to battery positive
- Connect W/R wire from alternator to dash for charge light. Can use the existing wire in the original Datsun 1200 engine room harness
- Optional, but recommended. Solder a 100k resistor across the CHG lamp circuit on the back of the gauge cluster. This will allow the alterator to keep charging even if the lamp burns out.
Starter
Wire the new starter same as the original Datsun 1200 starter:
- Wire from Ignition Switch to S terminal on starter solenoid
- Ensure large Ground wire exists from engine block to body (the original 1200 battery cable does this). See Battery Wiring
- Thick Positive wire from battery to starter motor
Battery
If you relocate the battery to the trunk/boot:
- Connect large gauge cable from Battery Positive to starter motor
- Connect large gauge cable from Battery Negative to engine block. Resist the temptation to simply connect the battery to the sheet metal. That may work but running a line to the engine is more reliable.
- run large cable from engine to chassis ground.
