フロア The front floor panel is stamped in one piece with the tunnel. However, automatic cars have a separate tunnel.
A CROSS MEMBER, front seat (RH & LH differ) * Van & Truck driver's side has Jack bracket B SEAT BRACKET, inner (RH & LH) C SEAT BRACKET, outer (RH & LH) D (Truck only) Back Panel, lower E (Truck only) Back Panel
Replacement coupe floor panels by Automotive Panel Craft (1mm cold rolled mild steel)
Front Floor
Coupe Floor Side (inner sill)
FRONT FLOOR PANEL USA/JAPAN, COUPE/SEDAN 1 ASSY-FLOOR FRONT 74300-H1000 3 SPEED 74300-H1021 AUTOMATIC 74300-H1010 4 SPEED 2 74310-H1000 ASSY-MEMBER CROSS FRONT SEAT RH 3 74311-H1000 ASSY-MEMBER CROSS FRONT SEAT LH 74311-H1400 Van RHD [has bracket for Jack] 4 74314-H1001 BRACKET-FRONT SEAT INSIDE RH 5 74315-H1000 BRACKET-FRONT SEAT INSIDE LH 6 74316-H1000 BRACKET-FRONT SEAT OUTSIDE RH 7 74317-H1000 BRACKET-FRONT SEAT OUTSIDE LH 8 74320-H1000 ASSY-FLOOR SIDE RH 9 74321-H1000 ASSY-FLOOR SIDE LH 12 74860-H1000 ASSY-MEMBER CROSS REAR SEAT LOWER * Van: Not Used 16 74810-H1001 ASSY-MEMBER SIDE FRONT RH 17 74811-H1001 ASSY-MEMBER SIDE FRONT LH 18 54532-H1001 ASSY-BRACKET TENSION ROD RH 19 54533-H1001 ASSY-BRACKET TENSION ROD LH 20 74800-H1000 ASSY-MEMBER CROSS FRONT
Rear Floor
Rear Floor, Truck
The Truck rear floor is the bottom of the tray/bed. The supporting structure (side members and cross members) are also part of the floor.
See Truck Rear Floor Panel
Floor Trim
Floor Side Cover - Front SEDAN & COUPE * 74921-H1100 COVER-FLOOR SIDE FRONT RH NLA * 74921-H7000 COVER-FLOOR SIDE FRONT RH (BLUE,LG-211 0772- * 74921-H7001 COVER-FLOOR SIDE FRONT RH (BEIGE,LG-20 0173- * 74921-H7002 COVER-FLOOR SIDE FRONT RH (BLACK,LG-13 0173- NLA * 74922-H1100 COVER-FLOOR SIDE FRONT LH NLA * 74922-H7000 COVER-FLOOR SIDE FRONT RH (BLUE,LG-211 0772- * 74922-H7001 COVER-FLOOR SIDE FRONT LH (BEIGE,LG-20 0173- * 74922-H7002 COVER-FLOOR SIDE FRONT LH (BLACK,LG-13 0173- NLA
Floor Side Cover - Rear SEDAN * 74925-H1300 COVER-FLOOR SIDE REAR RH NLA * 74925-H7000 COVER-FLOOR SIDE REAR RH (BLUE,LB-211 0772- * 74925-H7002 COVER-FLOOR SIDE REAR RH (BLACK,LG136 NLA 0173- * 74926-H7002 COVER-FLOOR SIDE REAR LH (BLACK,LG136 NLA 0173- * 74926-H1300 COVER-FLOOR SIDE REAR LH * 74926-H7000 COVER-FLOOR SIDE REAR LH (BLUE,LB-211 * 74926-H7001 COVER-FLOOR SIDE REAR LH (BEIGE,LH-20 * 74926-H7002 COVER-FLOOR SIDE REAR LH (BLACK,LG-13
Floor Side Cover - Rear COUPE * 74925-H1800 COVER-FLOOR SIDE REAR RH COUPE * 74925-H7100 COVER-FLOOR SIDE REAR RH (BLUE,LB-211 0772- * 74925-H7101 COVER-FLOOR SIDE REAR RH (BEIGE,LH-20 0173- * 74925-H7102 COVER-FLOOR SIDE REAR RH (BLACK,LG-13 0173- * 74926-H1800 COVER-FLOOR SIDE REAR LH * 74926-H7102 COVER-FLOOR SIDE REAR LH (BLACK,LG-13 * 74926-H7101 COVER-FLOOR SIDE REAR LH (BEIGE,LH-20 * 74926-H7100 COVER-FLOOR SIDE REAR LH (BLUE,LB-211
Wheel House Trim - SEDAN 74915-H1000 COVER-REAR WHEEL HOUSE BLACK#1742 (2) SEDAN 74915-H1001 COVER-REAR WHEEL HOUSE YELLOW (2) SEDAN(DX) 1270- 74915-H7000 COVER-REAR WHEEL HOUSE (BLUE,LB-211 (2) SEDAN 0772- 74915-H7001 COVER-REAR WHEEL HOUSE (BEIGE,LH-20 (2) SEDAN 0772- 74915-H7002 COVER-REAR WHEEL HOUSE (BLACK,LG-13 (2) SEDAN 0173- 74917-18200 PAD-REAR WHEEL HOUSE (2)
Wheel House Trim - COUPE 74915-H1800 COVER-REAR WHEEL HOUSE RH 74915-H1801 COVER-REAR WHEEL HOUSE RH YELLOW COUPE 1270- 74915-H7100 COVER-REAR WHEEL HOUSE RH (BLUE,LB-211 COUPE 0772- 74915-H7101 COVER REAR WHEEL HOUSE RH (BEIGE,LH-20 COUPE 0772- 74915-H7102 COVER REAR WHEEL HOUSE RH (BLACK,LG-13 COUPE 0173- 74916-H1800 COVER-REAR WHEEL HOUSE LH 74916-H1801 COVER-REAR WHEEL HOUSE LH YELLOW 1270- 74916-H7101 COVER REAR WHEEL HOUSE LH (BEIGE,LH-20 0772- 74916-H7100 COVER-REAR WHEEL HOUSE LH (BLUE) 0772- 74916-H7102 COVER REAR WHEEL HOUSE LH (BLACK,LG-13 0173- 74917-H1800 PAD-REAR WHEEL HOUSE (2) 74917-H7000 PAD-REAR WHEEL HOUSE 0173- (2)
See main articles: * Floor Part Numbers * Floor Trim Part Numbers
Ute
Rear Floor: See Body Panels
Front Floor Panel サニトラ フロント フロア パネル
- 74300-G1050 FLOOR ASS'Y-front (up to '72-12) 3-speed
- 74300-G1450 FLOOR ASS'Y-front (from '73-1) 3-speed
- 74300-G1150 FLOOR ASS'Y-front (up to '72-12) 4-speed
- 74300-G1450 FLOOR ASS'Y-front (from '73-1) 4-speed
- 74300-G1401 FLOOR-FRONT 7510-7803
- 74300-G1160 FLOOR-FRONT 7804-8808
- 74300-G1950 FLOOR-FRONT 8809-9810
- 74300-95W00 FLOOR-FRONT 9810-
Floor assembly includes: A * 74310-H1000 MEMBER ASS'Y-cross seat, front (R.H.) -8904 * 74330-95W00 MEMBER-FRONT SEAT MOUNTING, RH 8904- * 74311-H1400 MEMBER ASS'Y-cross seat, front (L.H.) -8910 * 74331-95W00 MEMBER-FRONT SEAT MOUNTING, LH 8910- B * 74314-H1001 BRACKET-front seat, inside (R.H.) * 74315-H1000 BRACKET-front seat, inside (L.H.) -8910 * 74351-95W00 BRACKET-FRONT SEAT MOUNTING, INNER LH 8910- C * 74316-H1000 BRACKET-front seat, outside(R.H.) * 74317-H1000 BRACKET-front seat, outside(L.H.) (not shown in photo) inner sill, under the aluminum sill trim * 74320-G1000 FLOOR ASS'Y-side (R.H.) * 74321-G1000 FLOOR ASS'Y-side (L.H.)
D, E: See Body Related parts * 74810-H1001 MEMBER ASS'Y-side, front (R.H.) * 74810-G1600 MEMBER-SIDE, FRONT RH 7510-7803 * 74810-G1601 MEMBER-SIDE, FRONT RH 7804-8910 * 74810-G1900 MEMBER-SIDE, FRONT RH 8910- * 74811-H1001 MEMBER ASS'Y-side, front (L.H.) * 74811-G1601 MEMBER-SIDE, FRONT LH 7510-8503 * 74811-H1001 MEMBER-SIDE, FRONT LH 8504-8910 * 74811-G1900 MEMBER-SIDE, FRONT LH 8910- * 54532-H1001 BRACKET ASS'Y-tension rod (R.H.) * 54532-H1001 BRACKET ASS'Y-tension rod (L.H.) * 74800-H1000 MEMBER ASS'Y-cross front
