フロア The front floor panel is stamped in one piece with the tunnel. However, automatic cars have a separate tunnel.
Contents[hide] |
A CROSS MEMBER, front seat (RH & LH differ) * Van & Truck driver's side has Jack bracket B SEAT BRACKET, inner (RH & LH) C SEAT BRACKET, outer (RH & LH) D (Truck only) Back Panel, lower E (Truck only) Back Panel
Replacement coupe floor panels by Automotive Panel Craft (1mm cold rolled mild steel)
Front Floor
Floor Side (inner sill)
FRONT FLOOR PANEL USA/JAPAN, COUPE/SEDAN/VAN 1 ASSY-FLOOR FRONT 74300-H1000 3 SPEED 74300-H1010 4 SPEED 74300-H1021 AUTOMATIC 2 FRONT SEAT CROSS MEMBER RH 3 FRONT SEAT CROSS MEMBER LH * H14 Van RHD [has bracket for Jack] 4 FRONT SEAT BRACKET-INNER RH 5 FRONT SEAT BRACKET-INNER LH 6 FRONT SEAT BRACKET-OUTER RH 7 FRONT SEAT BRACKET-OUTER LH 8 INNER SILL (FLOOR SIDE MEMBER) RH 9 INNER SILL (FLOOR SIDE MEMBER) LH 16 FRONT SIDE MEMBER RH 17 FRONT SIDE MEMBER LH 18 TENSION ROD BRACKET RH 19 TENSION ROD BRACKET LH 20 FRONT CROSS MEMBER
Rear Floor
Rear Floor, Truck
The Truck rear floor is the bottom of the tray/bed. The supporting structure (side members and cross members) are also part of the floor.
See Truck Rear Floor Panel
Floor Trim
Floor Side Cover - Front SEDAN & COUPE * 74921-H1100 COVER-FLOOR SIDE FRONT RH NLA * 74921-H7000 COVER-FLOOR SIDE FRONT RH (BLUE,LG-211 0772- * 74921-H7001 COVER-FLOOR SIDE FRONT RH (BEIGE,LG-20 0173- * 74921-H7002 COVER-FLOOR SIDE FRONT RH (BLACK,LG-13 0173- NLA * 74922-H1100 COVER-FLOOR SIDE FRONT LH NLA * 74922-H7000 COVER-FLOOR SIDE FRONT RH (BLUE,LG-211 0772- * 74922-H7001 COVER-FLOOR SIDE FRONT LH (BEIGE,LG-20 0173- * 74922-H7002 COVER-FLOOR SIDE FRONT LH (BLACK,LG-13 0173- NLA
Floor Side Cover - Rear SEDAN * 74925-H1300 COVER-FLOOR SIDE REAR RH NLA * 74925-H7000 COVER-FLOOR SIDE REAR RH (BLUE,LB-211 0772- * 74925-H7002 COVER-FLOOR SIDE REAR RH (BLACK,LG136 NLA 0173- * 74926-H7002 COVER-FLOOR SIDE REAR LH (BLACK,LG136 NLA 0173- * 74926-H1300 COVER-FLOOR SIDE REAR LH * 74926-H7000 COVER-FLOOR SIDE REAR LH (BLUE,LB-211 * 74926-H7001 COVER-FLOOR SIDE REAR LH (BEIGE,LH-20 * 74926-H7002 COVER-FLOOR SIDE REAR LH (BLACK,LG-13
Floor Side Cover - Rear COUPE * 74925-H1800 COVER-FLOOR SIDE REAR RH COUPE * 74925-H7100 COVER-FLOOR SIDE REAR RH (BLUE,LB-211 0772- * 74925-H7101 COVER-FLOOR SIDE REAR RH (BEIGE,LH-20 0173- * 74925-H7102 COVER-FLOOR SIDE REAR RH (BLACK,LG-13 0173- * 74926-H1800 COVER-FLOOR SIDE REAR LH * 74926-H7102 COVER-FLOOR SIDE REAR LH (BLACK,LG-13 * 74926-H7101 COVER-FLOOR SIDE REAR LH (BEIGE,LH-20 * 74926-H7100 COVER-FLOOR SIDE REAR LH (BLUE,LB-211
Wheel House Trim - SEDAN 74915-H1000 COVER-REAR WHEEL HOUSE BLACK#1742 (2) SEDAN 74915-H1001 COVER-REAR WHEEL HOUSE YELLOW (2) SEDAN(DX) 1270- 74915-H7000 COVER-REAR WHEEL HOUSE (BLUE,LB-211 (2) SEDAN 0772- 74915-H7001 COVER-REAR WHEEL HOUSE (BEIGE,LH-20 (2) SEDAN 0772- 74915-H7002 COVER-REAR WHEEL HOUSE (BLACK,LG-13 (2) SEDAN 0173- 74917-18200 PAD-REAR WHEEL HOUSE (2)
Wheel House Trim - COUPE 74915-H1800 COVER-REAR WHEEL HOUSE RH 74915-H1801 COVER-REAR WHEEL HOUSE RH YELLOW COUPE 1270- 74915-H7100 COVER-REAR WHEEL HOUSE RH (BLUE,LB-211 COUPE 0772- 74915-H7101 COVER REAR WHEEL HOUSE RH (BEIGE,LH-20 COUPE 0772- 74915-H7102 COVER REAR WHEEL HOUSE RH (BLACK,LG-13 COUPE 0173- 74916-H1800 COVER-REAR WHEEL HOUSE LH 74916-H1801 COVER-REAR WHEEL HOUSE LH YELLOW 1270- 74916-H7101 COVER REAR WHEEL HOUSE LH (BEIGE,LH-20 0772- 74916-H7100 COVER-REAR WHEEL HOUSE LH (BLUE) 0772- 74916-H7102 COVER REAR WHEEL HOUSE LH (BLACK,LG-13 0173- 74917-H1800 PAD-REAR WHEEL HOUSE (2) 74917-H7000 PAD-REAR WHEEL HOUSE 0173- (2)
See main articles: * Floor Part Numbers * Floor Trim Part Numbers
Ute
Rear Floor: See Body Panels
Front Floor Panel サニトラ フロント フロア パネル
- 74300-G1050 FLOOR ASS'Y-front (up to '72-12) 3-speed
- 74300-G1450 FLOOR ASS'Y-front (from '73-1) 3-speed
- 74300-G1150 FLOOR ASS'Y-front (up to '72-12) 4-speed
- 74300-G1450 FLOOR ASS'Y-front (from '73-1) 4-speed
- 74300-G1401 FLOOR-FRONT 7510-7803
- 74300-G1160 FLOOR-FRONT 7804-8808
- 74300-G1950 FLOOR-FRONT 8809-9810
- 74300-95W00 FLOOR-FRONT 9810-
Floor assembly includes: A * 74310-H1000 MEMBER ASS'Y-cross seat, front (R.H.) -8904 * 74330-95W00 MEMBER-FRONT SEAT MOUNTING, RH 8904- * 74311-H1400 MEMBER ASS'Y-cross seat, front (L.H.) -8910 * 74331-95W00 MEMBER-FRONT SEAT MOUNTING, LH 8910- B * 74314-H1001 BRACKET-front seat, inside (R.H.) * 74315-H1000 BRACKET-front seat, inside (L.H.) -8910 * 74351-95W00 BRACKET-FRONT SEAT MOUNTING, INNER LH 8910- C * 74316-H1000 BRACKET-front seat, outside(R.H.) * 74317-H1000 BRACKET-front seat, outside(L.H.) (not shown in photo) inner sill, under the aluminum sill trim * 74320-G1000 FLOOR ASS'Y-side (R.H.) * 74321-G1000 FLOOR ASS'Y-side (L.H.)
D, E: See Body Related parts * 74810-H1001 MEMBER ASS'Y-side, front (R.H.) * 74810-G1600 MEMBER-SIDE, FRONT RH 7510-7803 * 74810-G1601 MEMBER-SIDE, FRONT RH 7804-8910 * 74810-G1900 MEMBER-SIDE, FRONT RH 8910- * 74811-H1001 MEMBER ASS'Y-side, front (L.H.) * 74811-G1601 MEMBER-SIDE, FRONT LH 7510-8503 * 74811-H1001 MEMBER-SIDE, FRONT LH 8504-8910 * 74811-G1900 MEMBER-SIDE, FRONT LH 8910- * 54532-H1001 BRACKET ASS'Y-tension rod (R.H.) * 54532-H1001 BRACKET ASS'Y-tension rod (L.H.) * 74800-H1000 MEMBER ASS'Y-cross front
