Fast Idle Control Device (F.I.C.D.) was fitted to some Datsuns with factory-fitted Aircon. The FICD raises the idle speed automatically when A/C is ON to respond to the increased load.
FICD consists of two parts, a throttle actuator, and a magnetic vacuum switch. The switch is electrically operated off the compressor signal. The switch then lets vacuum go to the actuator, which pulls the carburetor throttle a little (about 100 RPM).
Magnetic Switch
The magnetic switch is on the side of the compressor, and opens when the compressor activates.
Fast Idle Actuator
- Clearance 'C' should be more than 3mm, Engine fully warm, A/C off.
- Start engine and set correct warm idle speed (700 in neutral, or 650 RPM in 'D')
- Turn A/C ON, in 'N' and adjust engine speed to 800 RPM.
- FICD adjusting screw
- Lever 'A'
- Lever 'B'
- Cable lock screw
Sunny Truck
From 1978-1989, no special idle control device was used. For 1990-1994 they added FICD.
Engine Mounted 9810- Fast Idle Control Device (FICD) * 14875-G5105 Manifold Connector [right next to carb base plate] * Vacuum Hose L=370 * 27654-H8500 FICD Actuator 92551-95W00 Actuator Bracket * 27720-G2500 FICD Lever * 92255-G5100 Solenoid Valve 92256-95W00 Bracket * Vacuum Hose L=270
B310
1979 North America A14 & A15 models had optional A/C.
A14/A15 Manual Transmission * A/C OFF: 700 rpm * A/C ON: 800 rpm
A14/A15 Automatic Transmission * A/C OFF: 650 rpm in "D" * A/C ON: 800 rpm in "N"
