Canopy
Revision as of 21:30, 15 May 2016; view current revision
Categories: Body | Fibreglass
Datsun 1200 Trucks look good with a canopy.
2784.jpg 2785.jpg 2836.jpg 12898.jpg 12899.jpg 12946.jpg 13507.jpg 10789.jpg
[hide]
Bakkie
In South Africa, fitting a canopy to the B140 is very popular.
http://www.chariots-auto.co.za
Stingray Marine Canopies
Skytop
Skytop - one of the strongest canopies available!
th_Nissan1400A.jpg th_Nissan1400B.jpg th_Nissan1400C.jpg th_Nissan1400D.jpg th_Nissan1400E.jpg
On 18th July, 2000, at our Edenvale factory, we decided to 'put our canopy where our mouth is' and perform the ultimate strength test on the Skytop. Four canopy shells were randomly selected off the production line, and our Nissan 1400 was lowered by crane directly onto their roofs! Notice that no bending, buckling or distortion occurred when the full weight of the vehicle was brought to bear on the roof of each canopy! After the test these four shells went back onto the assembly line without so much as a hairline crack, or being any worse-off for their punishing ordeal.
SA Canopy
http://sacanopy.co.za
SA CANOPY 2010 LIST
NSA001 NISSAN 1400 HD F/G/D
NSA001AV NISSAN 1400 HD F/G/D + AIRVENT
NSA065 NISSAN 1400 HD F/G/D - B/SIDES
NSA085 NISSAN 1400 HD F/G/D - C/BLANK
NSA004 NISSAN 1400 FULL DOOR
NSA055 NISSAN 1400 FULL DOOR - B/SIDES
NSA103 NISSAN 1400 FULL DOOR - C/BLANK
NSA128 NISSAN 1400 HD F/G/D SPORT
NSA131 NISSAN 1400 SPACESAVER
SA Canopy Carryboy SA Series
SA Canopy
Canopy King
http://www.canopyking.com
Classic Half Door
Classic Full Door
Bucco
Sadly, it seem Bucco is no longer selling B140 canopies.
Nissan 1400 Full Door Canopy
Nissan 1400 Half Door Canopy
  • Canopy bolted to vehicle as standard fitting for higher safety
2-Bar Roof Rack as a standard feature - feet are made from non-corrosive high tensile plastic and cross-bars are epoxy coated oval steel tubes (100Kgs Max. Load)
  • Fibreglass double skinned lockable rear lif-up door with large toughened automotive safety glass for greater visibility, heavy duty double gas struts opening mechanism and two-way locking mechanism which locks door to reinforced side plates for greater stability
  • Sliding lockable windows and additional fixed windows are rubber mounted (kick-out) on each side with maximum length toughened automotive safety glass
  • Canopy is designed to seal to the rear of the vehicle's cab and easy access is obtained through the vehicle's rear cab sliding window.
Optional extras:
  • Colour coding to match the vehicle colour
  • Window tinting to reduce internal heat and for greater safety
  • Non-slip Polyurethane Lining to vehicle's bin
  • 3rd Brake Light fitted to the rear of the canopy
  • Fitted PVC Air Vents
  • Excalibur Running Boards
  • Internal Switchable Strip Light
  • Heavy Duty Roof Rack (250Kg Max. Load)
  • Clip-on adaption for easily removable canopy (for safety reasons, not recommended)
  • Woven Rubber Bin Mat
  • Tow Bar and/or Bull Bar
  • Internal or external burglar guards for all canopy windows.
Bakkie Canopy Photo Index
More photos at Bakkie Gallery
th_0d18_20.jpg th_4b85_20.jpg th_4cf1_20.jpg th_6d43_20.jpg th_9f69_20.jpg th_05c5_20.jpg th_058a_20.jpg th_061c_20.jpg th_065e_20.jpg th_85c7_20.jpg th_91c3_20-X.jpg th_493e_20.jpg th_01011eg_20.jpg th_1530amb_20.jpg th_2469kjm_20.jpg th_02582nf_20.jpg th_4724lhb_20.jpg th_4822dnm_20.jpg th_5585c97_20.jpg th_5789_20.jpg th_6670cha_20.jpg th_7331mn3_20.jpg th_7400ahm_20.jpg th_8179hgl_20.jpg th_8182dib_20.jpg th_02786ii_20.jpg
