Nissan Factory service manual for the A14E fuel injected engine, 1978 edition.
A14E Service Manual A14E Service Manual Part 2 Engine Overhaul & Service Data
You can help us out! If you can type Japanese, please click Edit and type in the text. Also need help translating. Thanks!
A型 エンジン
A-series Engine
(1978 Standards Conforming Car)
はじめに Introduction
はじめに
この本は、53年度排出ガス規制適合のNAPSを挟用したA系EGI仕 ... | Introduction
This book, A-specifications EGI system was for conforming the NAPS of 1978 fiscal exhaust gas regulations ... |
目次 Table of Contents
Contents[hide] |
Summary 4
page 41. 概要
| 1. Summary
Engine Main Specifications 5
1-1 エンジン主要諸元 Engine Main Specifications
page 5Template:PhotoBorder
NAPS Specification List 6
1-2 NAPS仕様-覧 NAPS Specification - List
page 6Template:PhotoBorder
Engine Appearance 7
1-3 エンジン外観 Engine Appearance
1. 二?空気導入 Exhaust Air Induction Tube 2. Throttle Chamber 3. Air Regulator 4. EGR control valve 5. Dash Pot
1. Water temperature switch 2. TV valve 3. Water temp sensor 4. Blowby lower hose
1. Alternator 2. Distributor 3. Blowby upper hose 4. Pressure Regulator 5. VVT valve 6. VC solenoid valve 7. Fuel injector
Engine Sectional View 10
1-4 エンジン断面図 Engine Sectional View
page 10Template:PhotoBorder
Engine Performance Curve 11
1-5 エンジン性能曲線 Engine Performance Curve
page 11Template:PhotoBorder
NAPS System View 12
1-6 NAPSシステム図 NAPS System View
page 12Template:PhotoBorder
NAPS Piping Diagram 13
1-7 NAPS配管図 NAPS Piping Diagram
(1) Vacuum Hose Diagram
page 13Template:PhotoBorder
mm 1. 170 Vacuum gallery ~ pressure regulator 2. 90 VVT tube ~ VVT valve 3. 200 VVT valve ~ TV valve 3-way connector 4. 70 Vacuum gallery ~ Dist. 3-way connector 5. 50 Vacuum gallery ~ Dist. 3-way connector 6. 190 Vacuum gallery ~ TV valve 7. 170 EGR control valve ~ TV valve 8. 110 TV valve ~ 3-way connector 9. 540 Distributor ~ 3-way connector 10. 120 Vacuum gallery ~ VC solenoid valve 11. 200 VVT valve ~ VC solenoid valve 12. 200 Throttle chamber ~ vacuum gallery 13. 90 Vacuum connector ~ vacuum gallery 14. 130 Throttle chamber ~ vacuum gallery (for Distributor) 15. 230 Throttle chamber ~ VC solenoid valve 16. 170 Throttle chamber ~ vacuum gallery (for EGR control) 17. Blind Cap
page 14Template:PhotoBorder
Engine Maintenance Notes 15
1-8 エンジン整備上の注意 Engine Maintenance Notes
page 15Template:PhotoBorder
page 16Template:PhotoBorder
page 17Template:PhotoBorder
Engine Start-up Notes 18
1-9 エンジン始動上の注意 Engine Start-up Notes
page 18Template:PhotoBorder
Regular Inspection And Maintenance 19
2. 定期点検整備 Regular inspection and maintenance
page 19Template:PhotoBorder
page 20Template:PhotoBorder
page 21Template:PhotoBorder
page 22Template:PhotoBorder
page 23Template:PhotoBorder
page 24Template:PhotoBorder
page 25Template:PhotoBorder
page 26Template:PhotoBorder
page 27Template:PhotoBorder
Checker 28
3. チェッカー Checker
Function Checker 28
3-1 ファンクション チェッカー Function Checker
page 28Template:PhotoBorder
page 29Template:PhotoBorder
EGI Harness Check 30
3-2 EGI ハーネス チェッカー (EG1131) EGI Harness Checker
page 30Template:PhotoBorder
(1) (2)page 31
page 31Template:PhotoBorder
page 32Template:PhotoBorder
page 33Template:PhotoBorder
EGI Circuit (page 34)
full | japanese
Checker: ハーネス実態図 EGI Harness Schematic View (page 35)
full | Japanese
page 36Template:PhotoBorder
page 37Template:PhotoBorder
EGI Control Unit Checker 38
3-3 EGIコントロール ユニット チェッカー EGI Control Unit Checker
page 38Template:PhotoBorder
page 39Template:PhotoBorder
page 40Template:PhotoBorder
page 41Template:PhotoBorder
Fault Diagnosis 42
4. 故障診断 Fault diagnosis
page 42Template:PhotoBorder
page 43Template:PhotoBorder
page 44Template:PhotoBorder
On-vehicle Engine Maintenance 45
5. 車載上のエンジン整備 On-vehicle Engine maintenance
Air Door Adjustment 45
5-1 アイ ドル調整
page 45Template:PhotoBorder
page 46Template:PhotoBorder
page 47Template:PhotoBorder
Air Cleaner and ? 48
5-2 エア クリーナー及びニ?空気?入(EAI)装
page 48Template:PhotoBorder
Throttle Chamber 89
5-8 スロットル チャンバー
page 89Template:PhotoBorder
Manifold 90
5-9 マニホールド
page 90Template:PhotoBorder
page 91Template:PhotoBorder
Cylinder Head 92
5-10 シリダー ヘッド
page 92Template:PhotoBorder
page 93Template:PhotoBorder
page 94Template:PhotoBorder
Catalyst ? 95
5-11 触媒コンベーター及び排気温?報装置
page 95Template:PhotoBorder
page 96Template:PhotoBorder
page 97Template:PhotoBorder
page 98Template:PhotoBorder
page 99Template:PhotoBorder
page 100Template:PhotoBorder
page 101Template:PhotoBorder
page 102Template:PhotoBorder
103
page 103Template:PhotoBorder
104
page 104Template:PhotoBorder
105
page 105Template:PhotoBorder
page 106Template:PhotoBorder
page 107Template:PhotoBorder
108
page 108Template:PhotoBorder
page 109Template:PhotoBorder
page 110Template:PhotoBorder
Engine ? 111
6. エンジン脱? Engine ?
page 111Template:PhotoBorder
page 112Template:PhotoBorder
page 113Template:PhotoBorder
Engine Overhaul 114
See A14E Service Manual Part 2
7 Engine Overhaul 114 7.1 Overhaul Notes 114 7.2 Disassembly 115 7.3 Inspection, Correction, Replacement 119 7.3.1 Cylinder Head and Valve 119 7.3.2 Cylinder Block 124 7.3.3 Piston, Piston Ring, Conrod 125 7.3.4 Crankshaft, Main Bearing 128 7.3.5 Camshaft 130 7.3.6 Other Components 131 7.4 Assembly 132
Service Data 141
8. サ=ビス データ Service Data
8.1 Standard Bolt, Nut Tightening Torque 141 8.2 Engine Torque Specs 142 8.3 Service Data 143
Special Tools And Checker 146
9. 特殊工具監及びチェッカー Special tools and checker
Special Tools 146
9-1 特殊工具
page 146Template:PhotoBorder
page 147Template:PhotoBorder
page 148Template:PhotoBorder
page 149Template:PhotoBorder
page 150Template:PhotoBorder
Checker and Check Sheet 151
9-2 チェッカー及びチェック シート
page 151Template:PhotoBorder
page 152Template:PhotoBorder
page 153Template:PhotoBorder
page 154Template:PhotoBorder
Inspection Circuits 155
10. 点検回路 Checking Circuits
Function Checker Check 155
10-1 ファンクション チェッカー チェック
page 155Template:PhotoBorder
EGI Harness Checker Check 156
10-2 EGI ハーネス チェッカー チェック
page 156Template:PhotoBorder
page 157Template:PhotoBorder
page 158Template:PhotoBorder
page 159Template:PhotoBorder
page 160Template:PhotoBorder
page 161Template:PhotoBorder
page 162Template:PhotoBorder
page 163Template:PhotoBorder
page 164Template:PhotoBorder
page 165Template:PhotoBorder
page 166Template:PhotoBorder
page 167Template:PhotoBorder
page 168Template:PhotoBorder
page 169Template:PhotoBorder
page 170Template:PhotoBorder
page 171Template:PhotoBorder
page 172Template:PhotoBorder
page 173Template:PhotoBorder
page 174Template:PhotoBorder
page 175Template:PhotoBorder
Memos
[pages 176-183 are blank "Memo" pages for taking notes]
Template:ThumbPhotoAlbum Template:ThumbPhotoAlbum Template:ThumbPhotoAlbum Template:ThumbPhotoAlbum Template:ThumbPhotoAlbum Template:ThumbPhotoAlbum Template:ThumbPhotoAlbum
page about publicationTemplate:PhotoBorder
Back cover
