Nissan Factory service manual for the A14E fuel injected engine, 1978 edition.
A14E Service Manual A14E Service Manual Part 2 Engine Overhaul & Service Data
You can help us out! If you can type Japanese, please click Edit and type in the text. Also need help translating. Thanks!
A型 エンジン
A-series Engine
(1978 Standards Conforming Car)
はじめに Introduction
はじめに
この本は、53年度排出ガス規制適合のNAPSを挟用したA系EGI仕 ... | Introduction
This book, A-specifications EGI system was for conforming the NAPS of 1978 fiscal exhaust gas regulations ... |
目次 Table of Contents
Summary 4
page 4| 1. 概要
| 1. Summary
Engine Main Specifications 5
1-1 エンジン主要諸元 Engine Main Specifications
page 5https://i297.photobucket.com/albums/mm219/ddgonzal/005.jpg/A14E
NAPS Specification List 6
1-2 NAPS仕様-覧 NAPS Specification - List
page 6https://i297.photobucket.com/albums/mm219/ddgonzal/006.jpg/A14E
Engine Appearance 7
1-3 エンジン外観 Engine Appearance
1. 二?空気導入 Exhaust Air Induction Tube 2. Throttle Chamber 3. Air Regulator 4. EGR control valve 5. Dash Pot
1. Water temperature switch 2. TV valve 3. Water temp sensor 4. Blowby lower hose
1. Alternator 2. Distributor 3. Blowby upper hose 4. Pressure Regulator 5. VVT valve 6. VC solenoid valve 7. Fuel injector
Engine Sectional View 10
1-4 エンジン断面図 Engine Sectional View
page 10https://i297.photobucket.com/albums/mm219/ddgonzal/010.jpg/A14E
Engine Performance Curve 11
1-5 エンジン性能曲線 Engine Performance Curve
page 11https://i297.photobucket.com/albums/mm219/ddgonzal/011.jpg/A14E
NAPS System View 12
1-6 NAPSシステム図 NAPS System View
page 12https://i297.photobucket.com/albums/mm219/ddgonzal/012.jpg/A14E
NAPS Piping Diagram 13
1-7 NAPS配管図 NAPS Piping Diagram
(1) Vacuum Hose Diagram
page 13https://i297.photobucket.com/albums/mm219/ddgonzal/013.jpg/A14E
mm
1. 170 Vacuum gallery ~ pressure regulator
2. 90 VVT tube ~ VVT valve
3. 200 VVT valve ~ TV valve 3-way connector
4. 70 Vacuum gallery ~ Dist. 3-way connector
5. 50 Vacuum gallery ~ Dist. 3-way connector
6. 190 Vacuum gallery ~ TV valve
7. 170 EGR control valve ~ TV valve
8. 110 TV valve ~ 3-way connector
9. 540 Distributor ~ 3-way connector
10. 120 Vacuum gallery ~ VC solenoid valve
11. 200 VVT valve ~ VC solenoid valve
12. 200 Throttle chamber ~ vacuum gallery
13. 90 Vacuum connector ~ vacuum gallery
14. 130 Throttle chamber ~ vacuum gallery
(for Distributor)
15. 230 Throttle chamber ~ VC solenoid valve
16. 170 Throttle chamber ~ vacuum gallery
(for EGR control)
17. Blind Cap
page 14https://i297.photobucket.com/albums/mm219/ddgonzal/014.jpg/A14E
Engine Maintenance Notes 15
1-8 エンジン整備上の注意 Engine Maintenance Notes
page 15https://i297.photobucket.com/albums/mm219/ddgonzal/015.jpg/A14E
page 16https://i297.photobucket.com/albums/mm219/ddgonzal/016.jpg/A14E
page 17https://i297.photobucket.com/albums/mm219/ddgonzal/017.jpg/A14E
Engine Start-up Notes 18
1-9 エンジン始動上の注意 Engine Start-up Notes
page 18https://i297.photobucket.com/albums/mm219/ddgonzal/018.jpg/A14E
Regular Inspection And Maintenance 19
2. 定期点検整備 Regular inspection and maintenance
page 19https://i297.photobucket.com/albums/mm219/ddgonzal/019.jpg/A14E
page 20https://i297.photobucket.com/albums/mm219/ddgonzal/020.jpg/A14E
page 21https://i297.photobucket.com/albums/mm219/ddgonzal/021.jpg/A14E
page 22https://i297.photobucket.com/albums/mm219/ddgonzal/022.jpg/A14E
page 23https://i297.photobucket.com/albums/mm219/ddgonzal/023.jpg/A14E
page 24https://i297.photobucket.com/albums/mm219/ddgonzal/024.jpg/A14E
キャニスター Canister * ? * ? filter 40,000 km
キャニスター本体 Canister Body フィルター Filterフィルターの点検 Filter Inspection
page 25https://i297.photobucket.com/albums/mm219/ddgonzal/025.jpg/A14E
page 26https://i297.photobucket.com/albums/mm219/ddgonzal/026.jpg/A14E
page 27https://i297.photobucket.com/albums/mm219/ddgonzal/027.jpg/A14E
Checker 28
3. チェッカー Checker
Function Checker 28
3-1 ファンクション チェッカー Function Checker
page 28https://i297.photobucket.com/albums/mm219/ddgonzal/028.jpg/A14E
page 29https://i297.photobucket.com/albums/mm219/ddgonzal/029.jpg/A14E
EGI Harness Check 30
3-2 EGI ハーネス チェッカー (EG1131) EGI Harness Checker
page 30https://i297.photobucket.com/albums/mm219/ddgonzal/030.jpg/A14E
(1) (2)page 31
page 31https://i297.photobucket.com/albums/mm219/ddgonzal/031.jpg/A14E
page 32https://i297.photobucket.com/albums/mm219/ddgonzal/032.jpg/A14E
page 33https://i297.photobucket.com/albums/mm219/ddgonzal/033.jpg/A14E
EGI Circuit (page 34)
full | japanese
Checker: ハーネス実態図 EGI Harness Schematic View (page 35)
full | Japanese
page 36https://i297.photobucket.com/albums/mm219/ddgonzal/036.jpg/A14E
page 37https://i297.photobucket.com/albums/mm219/ddgonzal/037.jpg/A14E
EGI Control Unit Checker 38
3-3 EGIコントロール ユニット チェッカー EGI Control Unit Checker
page 38https://i297.photobucket.com/albums/mm219/ddgonzal/038.jpg/A14E
page 39https://i297.photobucket.com/albums/mm219/ddgonzal/039.jpg/A14E
page 40https://i297.photobucket.com/albums/mm219/ddgonzal/040.jpg/A14E
page 41https://i297.photobucket.com/albums/mm219/ddgonzal/041.jpg/A14E
Fault Diagnosis 42
4. 故障診断 Fault diagnosis
page 42https://i297.photobucket.com/albums/mm219/ddgonzal/042.jpg/A14E
page 43https://i297.photobucket.com/albums/mm219/ddgonzal/043.jpg/A14E
page 44https://i297.photobucket.com/albums/mm219/ddgonzal/044.jpg/A14E
On-vehicle Engine Maintenance 45
5. 車載上のエンジン整備 On-vehicle Engine maintenance
Air Door Adjustment 45
5-1 アイ ドル調整
page 45https://i297.photobucket.com/albums/mm219/ddgonzal/045.jpg/A14E
page 46https://i297.photobucket.com/albums/mm219/ddgonzal/046.jpg/A14E
page 47https://i297.photobucket.com/albums/mm219/ddgonzal/047.jpg/A14E
Air Cleaner and ? 48
5-2 エア クリーナー及びニ?空気?入(EAI)装
page 48https://i297.photobucket.com/albums/mm219/ddgonzal/048.jpg/A14E
Throttle Chamber 89
5-8 スロットル チャンバー
page 89https://i297.photobucket.com/albums/mm219/ddgonzal/089.jpg/A14E
Manifold 90
5-9 マニホールド
page 90https://i297.photobucket.com/albums/mm219/ddgonzal/090.jpg/A14E
page 91https://i297.photobucket.com/albums/mm219/ddgonzal/091.jpg/A14E
Cylinder Head 92
5-10 シリダー ヘッド
page 92https://i297.photobucket.com/albums/mm219/ddgonzal/092.jpg/A14E
page 93https://i297.photobucket.com/albums/mm219/ddgonzal/093.jpg/A14E
page 94https://i297.photobucket.com/albums/mm219/ddgonzal/094.jpg/A14E
Catalyst ? 95
5-11 触媒コンベーター及び排気温?報装置
page 95https://i297.photobucket.com/albums/mm219/ddgonzal/095.jpg/A14E
page 96https://i297.photobucket.com/albums/mm219/ddgonzal/096.jpg/A14E
page 97https://i297.photobucket.com/albums/mm219/ddgonzal/097.jpg/A14E
page 98https://i297.photobucket.com/albums/mm219/ddgonzal/098.jpg/A14E
page 99https://i297.photobucket.com/albums/mm219/ddgonzal/099.jpg/A14E
page 100https://i297.photobucket.com/albums/mm219/ddgonzal/100.jpg/A14E
page 101https://i297.photobucket.com/albums/mm219/ddgonzal/101.jpg/A14E
page 102https://i297.photobucket.com/albums/mm219/ddgonzal/102.jpg/A14E
103
page 103https://i297.photobucket.com/albums/mm219/ddgonzal/103.jpg/A14E
104
page 104https://i297.photobucket.com/albums/mm219/ddgonzal/104.jpg/A14E
105
page 105https://i297.photobucket.com/albums/mm219/ddgonzal/105.jpg/A14E
page 106https://i297.photobucket.com/albums/mm219/ddgonzal/106.jpg/A14E
page 107https://i297.photobucket.com/albums/mm219/ddgonzal/107.jpg/A14E
108
page 108https://i297.photobucket.com/albums/mm219/ddgonzal/108.jpg/A14E
page 109https://i297.photobucket.com/albums/mm219/ddgonzal/109.jpg/A14E
page 110https://i297.photobucket.com/albums/mm219/ddgonzal/110.jpg/A14E
Engine ? 111
6. エンジン脱? Engine ?
page 111https://i297.photobucket.com/albums/mm219/ddgonzal/111.jpg/A14E
page 112https://i297.photobucket.com/albums/mm219/ddgonzal/112.jpg/A14E
page 113https://i297.photobucket.com/albums/mm219/ddgonzal/113.jpg/A14E
Engine Overhaul 114
See A14E Service Manual Part 2
7 Engine Overhaul 114 7.1 Overhaul Notes 114 7.2 Disassembly 115 7.3 Inspection, Correction, Replacement 119 7.3.1 Cylinder Head and Valve 119 7.3.2 Cylinder Block 124 7.3.3 Piston, Piston Ring, Conrod 125 7.3.4 Crankshaft, Main Bearing 128 7.3.5 Camshaft 130 7.3.6 Other Components 131 7.4 Assembly 132
Service Data 141
8. サ=ビス データ Service Data
8.1 Standard Bolt, Nut Tightening Torque 141 8.2 Engine Torque Specs 142 8.3 Service Data 143
Special Tools And Checker 146
9. 特殊工具監及びチェッカー Special tools and checker
Special Tools 146
9-1 特殊工具
page 146https://i297.photobucket.com/albums/mm219/ddgonzal/146.jpg/A14E
page 147https://i297.photobucket.com/albums/mm219/ddgonzal/147.jpg/A14E
page 148https://i297.photobucket.com/albums/mm219/ddgonzal/148.jpg/A14E
page 149https://i297.photobucket.com/albums/mm219/ddgonzal/149.jpg/A14E
page 150https://i297.photobucket.com/albums/mm219/ddgonzal/150.jpg/A14E
Checker and Check Sheet 151
9-2 チェッカー及びチェック シート
page 151https://i297.photobucket.com/albums/mm219/ddgonzal/151.jpg/A14E
page 152https://i297.photobucket.com/albums/mm219/ddgonzal/152.jpg/A14E
page 153https://i297.photobucket.com/albums/mm219/ddgonzal/153.jpg/A14E
page 154https://i297.photobucket.com/albums/mm219/ddgonzal/154.jpg/A14E
Inspection Circuits 155
10. 点検回路 Checking Circuits
Function Checker Check 155
10-1 ファンクション チェッカー チェック
page 155https://i297.photobucket.com/albums/mm219/ddgonzal/155.jpg/A14E
EGI Harness Checker Check 156
10-2 EGI ハーネス チェッカー チェック
page 156https://i297.photobucket.com/albums/mm219/ddgonzal/156.jpg/A14E
page 157https://i297.photobucket.com/albums/mm219/ddgonzal/157.jpg/A14E
page 158https://i297.photobucket.com/albums/mm219/ddgonzal/158.jpg/A14E
page 159https://i297.photobucket.com/albums/mm219/ddgonzal/159.jpg/A14E
page 160https://i297.photobucket.com/albums/mm219/ddgonzal/160.jpg/A14E
page 161https://i297.photobucket.com/albums/mm219/ddgonzal/161.jpg/A14E
page 162https://i297.photobucket.com/albums/mm219/ddgonzal/162.jpg/A14E
page 163https://i297.photobucket.com/albums/mm219/ddgonzal/163.jpg/A14E
page 164https://i297.photobucket.com/albums/mm219/ddgonzal/164.jpg/A14E
page 165https://i297.photobucket.com/albums/mm219/ddgonzal/165.jpg/A14E
page 166https://i297.photobucket.com/albums/mm219/ddgonzal/166.jpg/A14E
page 167https://i297.photobucket.com/albums/mm219/ddgonzal/167.jpg/A14E
page 168https://i297.photobucket.com/albums/mm219/ddgonzal/168.jpg/A14E
page 169https://i297.photobucket.com/albums/mm219/ddgonzal/169.jpg/A14E
page 170https://i297.photobucket.com/albums/mm219/ddgonzal/170.jpg/A14E
page 171https://i297.photobucket.com/albums/mm219/ddgonzal/171.jpg/A14E
page 172https://i297.photobucket.com/albums/mm219/ddgonzal/172.jpg/A14E
page 173https://i297.photobucket.com/albums/mm219/ddgonzal/173.jpg/A14E
page 174https://i297.photobucket.com/albums/mm219/ddgonzal/174.jpg/A14E
page 175https://i297.photobucket.com/albums/mm219/ddgonzal/175.jpg/A14E
Memos
[pages 176-183 are blank "Memo" pages for taking notes]
Template:PhotoThAlbum Template:PhotoThAlbum Template:PhotoThAlbum Template:PhotoThAlbum Template:PhotoThAlbum Template:PhotoThAlbum Template:PhotoThAlbum
page about publicationhttps://i297.photobucket.com/albums/mm219/ddgonzal/183.jpg/A14E
Back cover
