The Rear Engine Crossmember is more commonly called the gearbox crossmember. This transmission crossmember hold the rear engine mount (transmission mount).
- <li>One type of 60a mount bolts to the crossmember from the sides of the mount, just like these stock 1200 mounts:
Just use a u-shaped flat steel adapter, with long bolts and spacers.
60a adapter Put together, it looks like this:
also see: this one
... or make a more sophisticated mount which doesn't need long bolts or spacers:
rear engine mounts
custom engine mounts
<li>The stock Datsun 1200 driveshaft should be used. While the B310 driveshaft is the same length, it has the larger H150-style rear flange.
</ul>
