B310 rear axle
Revision as of 10:51, 29 January 2017; view current revision
Datsun B310 (210/Sunny) came with coil-sprung rear axle assembly with H150 differential.
[hide]
4-link suspension came on all B310 (Sedan, Coupe & Wagon) except VB310 Van (squareback wagon)
Links are same right/left. Upper links are shorter than lower links.
S110 rear Swaybar works
14990.jpgAlbum 14990
Specification
rear sway bar: YES GX, RSE
width: 53.5 in (1360 mm)
length lower arm: 490 mm
length upper arm: 280 mm
REAR SUSPENSION
55110 55019-H8500 LINK LOWER 2
55045-H8500 BUSHING-REAR SUSPENSION 4
55226M 55048-W5001 PIN-ARM 2
55120 55023-H8500 LINK-UPPER 2
55046-W5000 BUSHING-REAR SPRING REAR UPPER 4
55226 55048-W5000 PIN-ARM 2
08915-14210 M12 WASHER, spring lock medium
08915-44210 M12 WASHER, plain standard
08911-54210 M12 NUT, high low carbon steel
Links for Datsun A10 (Stanza/510/Violet) is reportedly interchangeable but heavier duty.
55019-W5000 A10 LINK-LOWER
55045-W5000 A10 BUSHING
55023-W5000 A10 LINK-UPPER
55046-W5001 A10 BUSHING
Pins are same as B310
Swaps
Bolt-in H165 with rear disc brakes
S110
