Sunny Truck was fitted with a regular (contact points) distributor through October 1989. From there on it was fitted with Electronic Ignition.
Versions
22100-H1001 DISTRIBUTOR ASS'Y (HITACHI D411-61) * B110 Type 22100-G1400 DISTRIBUTOR ASS'Y (HITACHI D411-97) (from '73-4) * B210 Type 22100-H1011 DISTRIBUTOR ASS'Y (MITSUBISHI TVG-4FL) * alternate B110 type 22100-G1410 DISTRIBUTOR ASS'Y (MITSUBISHI TVT3T01877) (from '73-1) * alternate B210 type 22100-G1610 DISTRIBUTOR ASSY 7510-7907 MITSUBISHI 22100-W8511 DISTRIBUTOR ASSY 7907-8602 MITSUBISHI 22100-G1910 DISTRIBUTOR ASSY 8602-8910 MITSUBISHI 22100-95W10 DISTRIBUTOR ASSY 8910- MITSUBISHI * Bolt-down cap type (Mitsubishi), electronic
The last one is Electronic Ignition
22100-24B01 1400 South Africa? * 2210024B01, 22100-G5110
22162 DISTRIBUTOR CAP 22162-71312 7510-8602 Mitsubishi > 22162-71311 * 210/713 type 70 mm I.D. clip-on 22162-25G11 8602-8910 Mitsubishi <> 22162-25G10 * low-profile clip-on 22162-78A10 8910- Mitsubishi * bolt-down
22157 ROTOR all Mitsubishi 22157-18011 -8602 > 22157-18010 22157-R9007 8602-8812 * 37x56x22 mm 22157-10B10 8812-8910 22157-23G15 8910-
Coils
All used with ballast resistor, except the Electronic Distributor
* 22433-U3100 COIL ASSY-IGNITION [HITACHI] 7510-8910 * 22433-U3110 COIL ASSY-IGNITION [HANSHIN] 7510-8910 * 22433-U3140 COIL ASSY-IGNITION [MITSUBISHI] 8504-8910 * 22433-52A60 COIL ASSY-IGNITION MITSUBISHI
Resistor * 22460-14606 RESISTOR-IGNITION COIL 7510-8910 Hitachi choice Hanshin HP5-13E10 12V-R(ヒタチ センタク シヨウ) * 22460-14615 RESISTOR-IGNITION COIL 7510-8910 Hanshin choice * 22460-14645 RESISTOR-IGNITION COIL 8504-8910 Mitsubishi choice
22100-W8511
22100-G1910
22100-95W10
This is fitted to Datsun 1200 trucks from October 1989 through end of production in 1994. It is a nice unit with the transistor unit mounted in the distributor body, under the distributor cap. Late-model Electronic Distributor.
Also see Coil Wiring - Late 1200
22462-52A60 COIL-IGNITION 22100-95W10 DISTRIBUTOR ASSY A12S 8910- ミツビシ (Mitsubishi) デストリビユーター (デストリビューター) 22100-95W12 B2235-U7410 TAPE-SEAL, DISTRIBUTOR [a roll of tape] 7510-, 1194- B14U SR20DE,GA16DE * superceded by 22235-U7400 $3.39 USD 22301-95W10 CONTROL ASSY-VACUUM 22023-G5110 UNIT-SETTER 22201-22010 SCREW 7510- [fixing timing plate to distributor] 22180-71200 SEAL-O RING [distributor to engine block] A/L/Z engines $4.25 USD 22101-95W10 HOUSING ASSY-DISTRIBUTOR Condensor: None used ? 22107-95W10 GOVERNOR SET-DISTRIBUTOR 22115-95W10 SIGNAL-ROTO ASSY 22109-52H60 WEIGHT-GOVERNOR 22127-95W10 SPRING-GOVERNOR 22136-77A11 PLATE ASSY-BREAKER 22132-95W10 CAM SET 22229-95W10 SIGNAL SET
22020-G5111 TRANSISTOR IGNITION UNIT [fits inside distributor] * 8910- Sunny Truck * Intermotor 15650 * J117 * Mazda/Ford 323/626/929/MPV/MX3/B2600/B2200 * Suzuki * Komatsu/TCM/
Cap & Rotor * 22162-78A10 CAP ASSY-DISTRIBUTOR B12 1088- GA16I $27.36 USD * 22185-95W10 PACKING [seal, cap to body] * ? 04136-00211 SCREW * 22157-23G15 ROTOR-HEAD $6.88 USD
Cap fits North America models: * 1988-1990 Nissan Sentra with Mitsubishi distributor Oreillys.com E16 or GA16 Sentra * Master Pro C672 * BWD C672 * Beck/Arnley 1746918 * Niehoff Ultra WA468A; Pro-Power WA468ACS * Bosch 03320 * Standard Motor Products JH180 * AC/Delco E338A * 1987-1988 Nissan Pulsar NX
Bosch 03320 CAP fits North America models: * Nissan 1983-1994 * 1989-1990 Nissan 240SX * 1990-1994 Nissan Pickup * 1983-1990 Nissan Pulsar NX * 1991-1993 Nissan NX * 1984-1994 Nissan Sentra * Subaru 1987-1991 * 1988-1989 Subaru DL * 1990-1994 Subaru Loyale * 1987-1989 Subaru GL * 1987-1989 Subaru RX * 1987-1989 Subaru GL-10 * 1987-1991 Subaru XT * Suzuki * 1989-1994 Suzuki Swift
T4T66373 2227 Nissan service part, possibly remanufactured. Note the sticker instead of cast/stamped numbers.
Mitsubishi T4T Family
Mitsubishi T4T series came with points and electronic versions. See Mitsubishi T4T Distributors.
