Rear Axle Part Numbers
Revision as of 06:46, 27 February 2017; view current revision
Categories: Rear Axle And Rear Suspension | Catalog
<-- back to Part Numbers Index
Also see: Main article for usage, photos, cross-reference
Rear Axle
Tires
Wheel
Hubcaps
Truck
40315-15400 CAP-road wheel STD
40315-H1000 CAP-road wheel DX -7907, (op.)STD
40343-H8510 ORNAMENT-DISC WHEEL 7908-
reference:
 1974 B120 Parts Catalog C-288, page 70-2
 1997 B120 Parts Catalog C-415, page F40-03
 1 43010-H1004 COMP-CASE REAR AXLE SEDAN 0673- 5 43010-H1003
   43010-H1404 COMP-CASE REAR AXLE COUPE 0673- 5 43010-H1803
   43010-H1802 COMP-CASE REAR AXLE COUPE -1172
   43010-H1003 COMP-CASE REAR AXLE SEDAN 1272-0573 2 43010-H1002
   43010-H1002 COMP-CASE REAR AXLE SEDAN -1172
   43010-H1803 COMP-CASE REAR AXLE COUPE 1272-0573 2 43010-H1802
 2 43067-H0100 STUD-GEAR CARRIER FIX (8)
 3 43059-A1600 PLUG-TAPER SQUARE SOCKET
 4 32103-14600 ASSY-PLUG DRAIN
 5 38322-55100 ASSY-BREATHER
 6 38162-G0300 ASSY-SHAFT REAR AXLE (2)
 7 40222-18000 BOLT-HUB ROAD WHEEL (8)
 8 43065-10600 CLIP-BRAKE TUBE (2)
 9 43066-22500 SEAT-CONNECTOR BRAKE HOSE
10 43070-04101 SPACER-REAR AXLE BEARING (2) -1172
10 43070-H5000 SPACER-REAR AXLE BEARING (2) 1272- 43070-04101
11 43215-18000 BEARING-REAR AXLE (2) SEDAN COUPE
11 43215-H5000 BEARING-REAR AXLE (2) SEDAN COUPE 0673-1172 5 43215-18000
12 43255-18000 COLLAR-REAR AXLE BEARING (2)
12 43255-H1000 COLLAR-REAR AXLE BEARING (2) 1271- 2 43255-18000
13 43036-H5000 SHIM-REAR AXLE CASE END (0) SEDAN COUPE 0673-1172 5 43036-10601
13 43036-10601 SHIM-REAR AXLE CASE END (0) SEDAN COUPE
14 43239-04100 PACKING-GREASE CATCHER (2) -1172
14 43239-H5000 PACKING-GREASE CATCHER (2) 1272- 43239-04100
15 43237-18000 CATCHER-GREASE RH -1172
16 43236-H5000 CATCHER-GREASE (2) 2 1272- 43236-18000
16 43236-18000 CATCHER-GREASE LH -1172
17 43252-18000 SEAL-OIL REAR AXLE SHAFT (2)
17 43252-H1000 SEAL-OIL REAR AXLE SHAFT (2) 0372- 43252-18000
17 43252-H1010 SEAL-OIL REAR AXLE SHAFT (2) 0372- 43252-H1000
18 08915-23810 WASHER-SPRING LOCK (8)
19 43063-18001 BOLT-FIX REAR BRAKE DISC (8)
20 08912-43810 NUT-HEX SELF LOCK (8)
21 43206-18000 DRUM-BRAKE (2)
22 40300-H1001 ASSY-ROAD WHEEL 4JX12 (3) DELUXE
23 40310-H1772 SET-TIRE & TUBE 6.00-12-4PR WITHE FMVSS (3) OP
23 40310-H1940 SET-TIRE & TUBE 155SR12 RADIAL FMVSS (3) OP
23 40312-H1922 TIRE 6.00-12-4PR FMVSS (3)
23 40310-H1928 TIRE 6.00-12-4PR SNOW FMVSS (3) OP
24 40315-H1100 COVER-ROAD WHEEL (2) DELUXE (OP STD)
25 40315-H1800 COVER-ROAD WHEEL (2) P COUPE
25 40315-H1801 COVER-ROAD WHEEL (MEXICO MADE) (2) COUPE 0872- 5 40315-H1800
26 40225-27700 NUT-ROAD WHEEL 1 (16)
27 40324-H1000 WEIGHT 40G WHEEL BALANCE (0) 2 40324-18000
27 40329-18000 WEIGHT 90G WHEEL BALANCE (NOT ADOPTED (0)
27 40328-18000 WEIGHT 80G WHEEL BALANCE (NOT ADOPTED (0)
27 40327-H1000 WEIGHT 70G WHEEL BALANCE (0) 2 40327-18000
27 40327-18000 WEIGHT 70G WHEEL BALANCE (0)
27 40326-H1000 WEIGHT 60G WHEEL BALANCE (0) 2 40326-18000
27 40326-18000 WEIGHT 60G WHEEL BALANCE (0)
27 40330-18000 WEIGHT 100G WHEEL BALANCE (NOT ADOPTED (0)
27 40324-18000 WEIGHT 40G WHEEL BALANCE (0)
27 40323-H1000 WEIGHT 30G WHEEL BALANCE (0) 2 40323-18000
27 40323-18000 WEIGHT 30G WHEEL BALANCE (0)
27 40322-H1000 WEIGHT 20G WHEEL BALANCE (0) 2 40322-18000
27 40322-18000 WEIGHT 20G WHEEL BALANCE (0)
27 40321-H1000 WEIGHT 10G WHEEL BALANCE (0) 2 40321-18000
27 40321-18000 WEIGHT 10G WHEEL BALANCE (0)
27 40325-H1000 WEIGHT 50G WHEEL BALANCE (0) 2 40326-18000
27 40325-18000 WEIGHT 50G WHEEL BALANCE (0)
28 40360-H1000 CHAIN-TIRE (4) 4 OP COUPE
1973 LB110 USA Parts Catalog, page 62-1
