All 1200 body style use the same Front Combination Light Assembly (Coupe/Sedan/Van/Truck). But the specific type varies by country and by year. USA has single-bulb, Japan has dual-bulb. Sunny Truck after 1973 has dual-reflector type.
Australia Indicators (orange) + Clear Parking Lamp Japan I Indicators (orange) + Orange small Lamp North America Indicators (orange) + Orange large Running Lamp
ANZAC/Europe - dual color lens
Japan/USA - single color lens
Market Differences
Front running light lenses are either all-orange or white + orange. Reportedly the lamp housing is different so that you cannot simply swap lenses.
Japan, America (single-color, but are different)
Japan - Single Reflector (early) 3-wire Large + small bulb
Japan - Twin Reflector (late model) 3-wire 2-large-bulb
Body Style
Early Versus Late
Sunny Truck 1200 after September 1973 use a dual-reflector lens. Earlier 1200 Trucks use the standard 1200 single-reflector lense (same as Coupe/Sedan/Van).
This uses the same lenses as B210, but the housings are different in that 1200 has bullet connectors, while B210 has multi-connector. Interchange 1200 with B210: Probable, but requires wiring connector change.
Also see B210#Front_Lights
B210 uses same twin-reflector lenses as 1974-up Sunny Truck, but uses a different connector.
Bulbs
See main article: Bulbs
Japan single-reflector * 26717-89920 inner 23/8 watt * 26261-89900 outer (small) 3 watt
Japan dual-reflector * 26717-89900 inner 23 watt * 26715-89920 outer 8/3.4 watt
USA single-bulb * 26717-89920 23/8 watt
Wiring Differences
Connectors
1200 bullet connectors (B110 or B120)
2-wire Versus 3-wire
3-wire bullet connectors - Japan
2-wire bullet connectors - North America
510 Lamps
Do not confuse 1200 front lamps with 510 laps. They look very similar but the
1200 unit is more rounded.
For Japan & USA (all orange), the position of the reflector differs:
Clear Lenses
Get the right kind of your assembly
- Euro/Aussie
- Japan single-reflector
- Japan dual-reflector
- USA single-bulb, single-reflector
B140
The B140 bakkie has the front combination lamp in the front bumper.
It looks similar to the Datsun 1000 late sedan lamp.
Gasket
ウインカー パッキンゴム
See Front Combination Lamp Part Numbers
Lens
JAPAN all-orange 26121-H1000 1-reflector lens -7308 ICHIKO 市光 <> 26121-H1010 KOITO 26121-H5000 2-reflector lens 7309- [same as B210]
AUS/EUR orange & white
NORTH AMERICA all-orange 26121-H1000 <> 26121-H1901
Assembly
JAPAN all-orange, dual bulb, 3 male bullet wires 26120-H1000 single reflector -7308 small & large bulbs <> 26120-H1010 KOITO 26120-G1000 dual reflector, two large bulbs 7309-
NORTH AMERICA all-orange, single bulb, 2 male bullet wires 26120-H1900 <> 26120-H1901 <> 26120-H7000
G08
G0800 - Same as H1000?![]()
looks like it is from C20 Nissan Cherry Cab チェリーキャブ
Generational
Datsun 1200 was fitted with four or five different Front Combination Lamps, depending on the year and country. USA and Japan got all-Red, while other export countries got Orange-White lamps.
Variations
- one reflector Orange (B110 Japan, USA)
- two reflector Orange (B120, B210)
- two reflector Orange-White (Australia)
- B110 - Bayonet connector wires
- ??? - square connector
- B210 - Multi-pin connector
Japan Car
3-wire, 1-1/2 bulb, single reflector Orange
- 26120-H1010 LAMP ASS'Y-front combination (R.H.)
- 23/7W bulb
- 3W bulb
- 26121-H1010 LENS (R.H.)
- 26123-H1010 PACKING (R.H.)
Japan Sunny Truck
7510-, 3-wire, 2-reflector, 2-bulb Orange
- 26120-G1000 LAMP ASSY-FRONT COMBINATION, RH
- 23W bulb
- 8/3.4W bulb
- 26121-H5000 LENS, RH
- 26123-H5000 PACKING, RH -8910
- 26123-G1000 PACKING, RH 8910-
- 08310-44020 SCREW (2 per side)
Japan B210
multi-pin connector, 2-reflector, 2-bulb Orange
- 26120-H5000 LAMP ASS'Y-front combination lamp (R.H.)
- 23W bulb
- 8/3.4W bulb
- 01411-00101 SCREW
2-wire, single-bulb, single-reflector, orange
- 26120-H1901 ASSY-LAMP,FRONT COMBINATION R.H
- 26120-H7000 ASSY-LAMP,FRONT COMBINATION R.H 0772-
- 26121-H1000 LENS RH AMBER(ICHIKHO)
- 26121-H1901 LENS RH AMBER(ICHIKHO)
- 26123-H1000 PACKING RH(ICHIKHO)
- 26717-89920 BULB 12V-23-8W(ICHIKHO)
- 08310-44020 SCREW TO FIX LENS(ICHIKHO) (M4X0.7)
