Elrich11
Revision as of 01:54, 21 July 2018; view current revision
Category: User Community
CA18DET-powered turbo ute
17122_583abb8eca8f0.jpgPost 482522 17122_583abb7935201.jpgPost 482522 17122_583abb9f7a2bc.jpgPost 482522
standard S13 CA radiator
new Autometer gauges
GT2860 turbo (S15-size)
17122_5858ef2195b9b.jpgPost 482859 17122_575f4b1dac181.jpgPost 479244
 V I D E O  CA18DET Datsun 1200 Ute - First Start 2016 (click to view)
3" exhaust with cat - bigg diff
17122_57bfa46cc13c5.jpgPost 480824
inter cooler is 560x180x65. It fits behind the grille without chopping it and sits in behind the apron. You could go a bit taller without problems but this fits nicely. I cut out the radiator support and made up my own strap from the apron to the rad support out of 5mm steel. I made some spacer brackets to mount the inter cooler, it has to hang about 50-60mm below the rad support from memory to clear the bonnet latch. When I have the grille on you can't even tell its there, which is what I wanted as well.
Getting alignment done after suspsension changes
17122_57a593dc2a316.jpgPost 480341
Changed front pads from a high temp pad to a basic road pad and improved grab and feel a lot at road speeds. Big 280mm S13 Brakes makes it stop very well
17122_58c5027fd481c.jpgPost 484345 17122_58c5028d54f79.jpgPost 484345
 V I D E O  Ca18det Datsun 1200 Ute First Drive 2016 (click to view)
First legal cruise - July 2018
17122_5b5135702828b.jpgPost 488971
