Datsun 1200s came with two brake systems:
- Drum front/drum rear - Standard trim, Deluxe trim
- Disc front/drum rear - GL, GX and optional on Deluxe
The 1200 front-disc/rear-drum system was good for 1971. In fact, stopping power was better than most 'muscle cars' of the era. However, if you have a drum/drum system, you'll want to upgrade to disc/drum. The drum system stops well enough, but the disc system has less fading going down mountain roads.
Also see:
Caliper bolt spacing:
- ~84 mm: B110, and all 12" wheel B210 and B310
- 88.9 mm: B310 large struts for 13" wheels
Rotor Sizes
| Dia. (mm) | Part Number | Source |
| 212.5 | 40206-H1006 | B110, B210 with A12 1974, 1975 |
| 220 (AN18) | 40206-H7500 | B210 A12 1976-1978,B310 with 12" wheels |
| 232 | 40206-A1155 | B210 A13, PB110?, PB210 early? |
| 245 (AN20) | 40206-U6700 | A10, B210 A14, B310 A14/A15, PB210 late? |
| ? | ? | B210 Australia-assembled |
| ? (Girlock) | ? | A10, Australia-assembled |
| brake cylinders | B110 (disc) | 1977 US B210 | 1980 US B310 (Disc-AN20) | 1980 Canada A12A (Disc-AN18) |
| Proportioning valve | not used | yes | 1,961 kPa x 0.4 psi | 1,961 kPa x 0.4 psi |
| Booster (Master-Vac) | not used | ? | M60 6-in diameter 135mm rod length (flange-to-pedal) | M60 6-in diameter |
| Master diameter | 11/16 inch | 3/4 inch | 13/16 | 13/16 |
| Front cylinder diameter | 1.894 inch (drum brakes: 11/16) | 2.012 inch | 2.012 inch | 1.894 inch |
| Rotor diameter | 212.5 mm | 245mm | 245mm | 220mm |
| Pad (width x length) | 42.5 x 53.1 mm | 41.2 x 63.4 mm | 41.2 x 61.4 mm | 42.0 x 56.8 mm |
| Pad thickness | 10.3 | 10.0 | 10.0 | 10.3 |
| Total front braking area (discs) | 14.0 sq in | 16.2 sq in | ~14.6 | ~13.8 |
| Total front braking area (drums) | 42.3 sq in | n/a | n/a | n/a |
| Rear cylinder diameter | disc brake models: 11/16 inch (all-drum models: 13/16) | 13/16 inch | 13/16 | 13/16 |
| Drum diameter | 8.0 inch | 8.0 inch | 8.0 | 8.0 |
| Drum width | 1.378 inch | 1.378 inch | 1.378 | 1.378 |
| Total rear braking area | 42.3 sq in | 42.3 sq in | 42.3 | 42.3 |
Front Brake Hoses
- Length=11" End A Size=M10X1 End B Size=M10X1
- RAYBESTOS BH36892; DORMAN H96862; ACDELCO 18J2188, 18J126, 19173109
Rear Brake Hose
- Length=13.188" End A Size=M10X1 End B Size=M10X1
- RAYBESTOS BH36866; DORMAN H36866
Small Pad (58 mm for 212mm rotor) Fits:
Raybestos PGD104, Wearever D41, Bendix D104, Beck/Arnley 0880100D?, ACDELCO 17D104 (18028686), ACDELCO ACD39, ACDELCO ACD122 |
Medium Pad (for 220mm rotor) fits:
- B310 A12A Canada (220mm AN18 rotor)
Beck/Arnley 0820100 Premium Organic $9.18
Large Pad (63.5 mm for 245 mm rotor) RockAuto for AN20 rotor
PartsAmerica fits:
- 1974-1978 Datsun B-210
- 1975-1979 Civic USA
- 1977-1979 Datsun 200SX (S10)
- 1979-1982 Datsun 210 (B310) USA
- 1975-1976 Datsun 610
- 1975-1977 Datsun 710
Raybestos SGD117, PGD117 or RPD117, Beck/Arnley 0870944, 0820944 or 0880944D, Wearever D103, Bendix D103, ACDELCO 17D117 (18028692)
D103 also D113. KD-29, MK D1008, AK A-33K
Rear Brake Shoe set (8 x 1-3/8, fits B110, B210 and B310)
- RAYBESTOS 371PG $15.36
- WAGNER PAB371 $16.52
- ACDELCO 17371B $19.02
- WAGNER BD60368 $39.89
Rotor
- Front disc inner wheel bearing {Taper Bearing Assembly / Cone Length=0.5906 Bore=0.9843 Outer Diameter=2.0472 Width=0.6398 Cup Length=0.5118 Cone Radius=0.06 Cup Radius=0.06}
- BECK/ARNLEY 0513809 $13.61
- BCA 30205 $14.73
Wheel Bearing, FRONT INNER, disc brake
- Taper Bearing Assembly / Cone Length=0.5906" Bore=0.9843" Outer Diameter=2.0472" Width=0.6398" Cup Length=0.5118" Cone Radius=0.06" Cup Radius=0.06"
- BCA/NATIONAL 30302
- Nissan 43215-18000
- TIMKEN 30205M
Wheel Bearing, FRONT OUTER
- Taper Bearing Assembly / Cone Length=0.5118 Bore=0.5906 Outer Diameter=1.6535 Width=0.561 Cup Length=0.4331 Cone Radius=0.06 Cup Radius=0.06
- BCA/NATIONAL 30205
- TIMKEN 30302
Caliper
- Bore Size=1.89" Inlet Thread=M10X1 Bleeder Thread=M10X1
- Right: RAYBESTOS FRC3021 $30.79, RC3021, A-1 CARDONE 19124, 17124
- Left: RAYBESTOS FRC3022 $30.79, RC3022, A-1 CARDONE 19125, 17125
Parking Brake Cable
- 48-1/4" Overall Length, 2 Per Car
- RAYBESTOS BC92888 $39.79
- ACDELCO 18P154, 18033072 $48.79
Master Cylinder
- Bore Size=11/16" Number of Ports=2 Primary Outlet Size=M10x1 Secondary Outlet Size=M10x1
- A-1 CARDONE 111655 Remanufactured $26.79
- RAYBESTOS MC39087
- ACDELCO 18M1072, 19106858
B120
Front Disk Brakes from 8910. These are unique as they fit the same strut as the former drum brake setup.
- 41060-G1985 PAD KIT-DISC BRAKE [Nissan/Subaru]
- 41001-G1500 CALIPER ASS'Y-FRONT RH W/O PADS OR SHIMS
- 41121-05A10 PISTON-CYLINDER $31.23
- 47210-G1500 BOOSTER ASSY-BRAKE
- 40207-G1501 ROTOR-DISC BRAKE, FRONT
Master cylinder has two bolts in horizontal plane; previous drum brake system used two bolts in vertical plane (like B110).
Rear Drum Brake Shoes
- 44060-G0300 SHOE ASSY-REAR BRAKE SHOE 7510-7611
- 44060-G0325 7612-8910
- 44060-G1225 8910-
- 43206-18000 DRUM BRAKE-REAR
Friction Materials
- FMSI 782-D41
- FMSI 7059 (D41) Nissan, Honda
- FMSI 7039 (D103) Nissan, Honda
- 1976-1982 Cherry
- 1980-1982 Pulsar
- 1970-1974 1200
- 1974-1976 B210
- 1979-1981 Sunny
- 1972-1979 Civic
- 1969-1970 S800
- FMSI 7040 (D104)
- FMSI 7064-D113
