Toyota 4A engine
Revision as of 21:12, 17 August 2018; view current revision
Category: Engine Swaps
The Toyota 4A engine variations are a popular swap into Datsun 1200s.
[hide]
About
Toyota 4A engine series are 1600cc engines, so are a significant upgrade in terms of cubic inches alone compared to the Datsun A12 or A14. However, it is the DOHC 4A-GE that shines with impressive power. Also notable is the 4AGEZ supercharged engine from the Toyota MR2.
NOTE to newbys: Beware of mentioning rotary-powered or Toyota 4AGE-powered 1200s. Some club members may get offended! But really, these are also excellent engines that fit in fairly well. Just don't tell anybody ;-)
Counterpoint: The 4AGE weighs the same as the better engine... Nissan's CA18DE. The CA18DE is 200cc larger, has bigger everything. So you can get away with the same mods as a 4age and get more power.
18188.jpgAlbum 18188
The biggest thing that has to be done was a fabricated header, because the 4A manifold is large and does not clear the LHD steering box. You may not have any trouble with a RHD car.
Datsun A15 vs Toyota 4A-**
Datsun A15 4A-FE 4A-GE (Gen 3) 4A-GZE (AE101)
Bore 76 mm 81 mm 81 mm 81 mm
Stroke 82 mm 77 mm 77 mm 77 mm
Displacement 1488 cc 1587 cc 1587 cc 1587 cc
Power 81 hp (60 kW) 89 hp (66 kW) 138 hp (103 kW) 168 hp (125 kW)
Although some have been able to extract more power from the 4A-FE. The upside is that they are very easily obtainable and so are parts. They are a narrow angle DOHC (single sprocket) cross-flow alloy head with a cast iron block.
  • 4A-GE (wide angle DOHC) Come in 5 flavours ranging from 86kW (Gen 2) up to 121kW (Gen 5) 20 Valve.
  • 4A-GZE supercharged. Some use this motor and its fuel system and computer for a turbo setup although simply replacing the cast pistons with forged items in a 4A-GE will yield the same result (except that an aftermarket ECU will be needed). The advantage over the supercharger is that boost can be variably controlled using and adjustable wastegate or boost controller. A supercharger has a fixed design boost, although aftermarket overdrive pulleys are available. They don't like to be spun more that around 8000 rpm as the teflon coatings on the roots can melt.
19928.jpgAlbum 19928
Swap Overview
26020.jpgAlbum 26020
The conversion isn't bolt-on -- its all fab work:
  • Engine mounts
  • Gearbox mount
  • Custom cooling system pipes
  • Custom exhaust
No one sells a "kit" to fit the 4AGE into a Datsun 1200.
20V 4AGE's use a distributor which ends up in the 1200 glovebox and heater/demister box. This means modifying all that. That isn't easy.
Front-wheel-drive 4AGE uses a distributor which ends up in the 1200 glovebox and heater/demister box. Modifying all that isn't easy. It's almost always a FWD engine in Australia, unless you can get a Japanese RWD AE86 Engine.
Source for Engine
RWD 4A Engines
  • AE71 was the 1983 Corolla, with carbureted 4AS SOHC engine.
  • AE85/AE86 was the last RWD series (1984-1986) with fuel injected DOHC 4AGE engine
826.jpgAlbum 826
4AGE 16V engine is arguably one of the best 1.6 litre motors ever put together. 75KW to 100KW power ratings. The suzuki g13b or g16b weigh 15kgs less than an a15. At around 80kgs the nearest rival is the 4age at 130kg. 108 rwhp from a stock 4AGE.
4AGE 20V engine: 120 kw.
* 4065
4AGZE: factory supercharged motor with about 135KW. It has factory forged pistons with later variants with ceramic coated tops, suitable for forced induction and perfect for aftermarket turbo as well. The con-rods and crank are the same or similar to 4age. (eg early AE92 4agze has larger rods). The 4agze smallport head will also come with oil squirter pistons, another good thing for cooling high performance setups. This std setup is strong enough for +200kw hence the reason people grab them for turbo setups with no reason to upgrade pistons, rods or the crank. They are 25kgs lighter than a Nissan CA18DET engine. Most people take off the supercharger and place on a turbo for much better performance and then loosely call it a "4AGTE". If you were hunting for max power, then a 7afe block with 4agze internals, turbo and some other mods would bump it to a 1.8L, also known as the "7agte". Maximum powered 7agtes can reach +300kw at the wheels with custom pistons, crank & rods.
Formula Atlantic 4A-GE puts out 240 bhp.
Gearbox
Use the gearbox that came with the engine. Don't try to fit it to the Datsun gearbox, because the Toyota box is much stronger.
There is just enough room for the t50 in a Datsun 1200 manual tunnel. The 1200's speedometer cable screws straight on.
26021.jpgAlbum 26021
T50 transmission is less expensive than the Supra W55 box & plenty strong enough for the 4AGE. They've been putting them behind 5 litre Holden & Ford V8's for years. The w55 conversion for 4AGE is $1000-up (for new parts), not including the w55 itself. Don't have to cut the tunnel, put in a T50 5 speed, just cut off the two mounts in the tunnel, cleanly and the box fits perfectly.
Or if you live where W55 is cheap (South Africa) use the R900 conversion bell housing
9498.jpgAlbum 9498
T50 is good to handle the torque from a little 1.6 liter 4AGE, but not from a 4AGZE (supercharged engine). A turbo conversion should be OK at low boosts. Otherwise you'll need a stronger transmission like this one:
Toyota W gearbox
11928.jpgAlbum 11928
For drag racing, an automatic is fastest. Use Ford C4, or Toyota Trimatic. Both require custom bellhousing.
Since this is not Datsun-specific, For more details, search:
Clutch & Flywheel
OPTIONAL - lighten flywheel
14583.jpgAlbum 14583
Differential
The AE86 rear live axle assembly is strong, and is narrow enough to fit under a Datsun 1200. Put the whole thing in there, and use the Toyota alloy wheels while you're at it.
AE86 is the RWD Toyota Corolla 1983-1986 (E80 series). The most desirable rear axle is from the GTS model (AE88) with disc brakes. Some were fitted with LSD, but if not TRD sells one. This model came with 14" alloy wheels instead of the 13" common to most AE86. It also had the stronger T282/T284 differential.
Projects
Ruda's 11-sec Bakkie
2080.jpegAlbum 2080
Zoom 153
4AGE STREET ELITE DATTO white ute 'DATOOW' "Third time's a charm" page 20
26726.jpgAlbum 26726 26727.jpgAlbum 26727 26728.jpgAlbum 26728 26724.jpgAlbum click to view 26725.jpgAlbum click to view
in its third incarnation Simon Vella's 1200 Ute is a stunning showcase of a well thought-out performance package that goes, turns stops and looks damn good doing so
DatsunDonnie
Donnie in Victoria, Canada has a fantastic 4AGE-powered 2-door sedan:
3020.jpgAlbum 3020
Had it at the drags the other night-15.95@86mph sound good? 7100 RPM through the traps!
4002.jpgAlbum 4002 3019.jpgAlbum 3019
Donnie used the stock Datsun 1200 radiator.
GX Monster
South Africa
14762.jpgAlbum 14762 14763.jpgAlbum 14763 14761.jpgAlbum 14761
Kululadotgroen
In Cape Town, South Africa there is this one:
9675.jpgAlbum 9675 16548.jpgAlbum 16548
See Main Article: Kululadotgroen
9486.jpgAlbum click to view 9487.jpgAlbum click to view 9489.jpgAlbum click to view 9490.jpgAlbum click to view 9491.jpgAlbum click to view 9492.jpgAlbum click to view 9493.jpgAlbum click to view 9494.jpgAlbum click to view 9495.jpgAlbum click to view 9496.jpgAlbum click to view 9497.jpgAlbum click to view 9498.jpgAlbum click to view 9499.jpgAlbum click to view 9505.jpgAlbum click to view 9506.jpgAlbum click to view 9507.jpgAlbum click to view 9508.jpgAlbum click to view 9510.jpgAlbum click to view 9511.jpgAlbum click to view 9512.jpgAlbum click to view 9513.jpgAlbum click to view 9514.jpgAlbum click to view 9515.jpgAlbum click to view 9516.jpgAlbum click to view 9517.jpgAlbum click to view 9518.jpgAlbum click to view 9519.jpgAlbum click to view 9520.jpgAlbum click to view 9521.jpgAlbum click to view 9522.jpgAlbum click to view 9523.jpgAlbum click to view 9524.jpgAlbum click to view 9525.jpgAlbum click to view 9526.jpgAlbum click to view 9668.jpgAlbum click to view 9669.jpgAlbum click to view 9670.jpgAlbum click to view 9671.jpgAlbum click to view 9672.jpgAlbum click to view 9673.jpgAlbum click to view 9674.jpgAlbum click to view 9675.jpgAlbum click to view 9676.jpgAlbum click to view 9677.jpgAlbum click to view 9678.jpgAlbum click to view 9679.jpgAlbum click to view 9680.jpgAlbum click to view 10833.jpgAlbum click to view 10835.jpgAlbum click to view 10952.jpgAlbum click to view 10953.jpgAlbum click to view 10954.jpgAlbum click to view 12440.jpgAlbum click to view 12441.jpgAlbum click to view 12442.jpgAlbum click to view 12662.jpgAlbum click to view 12670.jpgAlbum click to view 12671.jpgAlbum click to view 12672.jpgAlbum click to view 12673.jpgAlbum click to view 12674.jpgAlbum click to view 12675.jpgAlbum click to view 12676.jpgAlbum click to view 12692.jpgAlbum click to view 12693.jpgAlbum click to view 12896.jpgAlbum click to view 13128.jpgAlbum click to view 13129.jpgAlbum click to view 13377.jpgAlbum click to view 13378.jpgAlbum click to view 13379.jpgAlbum click to view 13380.jpgAlbum click to view 14068.jpgAlbum click to view 14365.jpgAlbum click to view 14388.jpgAlbum click to view 14389.jpgAlbum click to view 15122.jpgAlbum click to view 15123.jpgAlbum click to view 15124.jpgAlbum click to view 15125.jpgAlbum click to view
Jason's 1200 Coupe
Out of Vancouver, WA:
1609.jpgAlbum 1609 4003.jpgAlbum 4003
  • Toyota 4AGE DOHC engine
  • Toyota T50 5-speed
  • Corolla EFI fuel tank is in the back compartment
  • 77 Corolla SR5 rear with LSD pumpkin
  • 175/70R-13 tires
Randoli
4A-GZE conversion. Use EMS ECU and removed the MAF sensor
21259.jpgAlbum 21259 18548.jpgAlbum 18548
3Rotor
See all pics from 10936 - 10947, starting with:
10936.jpgAlbum 10936
Wogboy
Turbo conversion
7634.jpgAlbum click to view 7216.jpgAlbum click to view 6406.jpgAlbum click to view
The clutch is original datto 1200. I used the datsun clutch fork and cut the opposite side of the bellhousing on the t50. Then is used the toyota thrust race, ground down the datto clutch fork to clear , then welded a couple of allen keys(strong steel) to reinforce the clutch fork. The result was the sweetest clutch action I have ever felt. Lucky but amazing.So I have a mechanical clutch.
Normo's Ute
(now sold)
gearbox crossmember
4642.jpgAlbum click to view 4639.jpgAlbum click to view
Swap Notes
9515.jpgAlbum click to view Engine Mount Left9493.jpgAlbum click to view
9514.jpgAlbum click to view Engine Mount Right 9492.jpgAlbum click to view
9499.jpgAlbum click to view Sump Fitment
The 4A has a front sump oil pan, actually shorter than the a12, so you can position it lower in the chassis.
9494.jpgAlbum click to view front clearance
9491.jpgAlbum click to view rear clearance
9508.jpgAlbum click to view Air Inlet
9507.jpgAlbum click to view Engine 9506.jpgAlbum click to view
9498.jpgAlbum click to view Gearbox 9497.jpgAlbum click to view9496.jpgAlbum click to view
9495.jpgAlbum click to view Shifter
9509.jpgAlbum click to view VW Golf Radiator
9673.jpgAlbum click to view Water pump hose
9672.jpgAlbum click to view Radiator 9517.jpgAlbum click to view
9671.jpgAlbum click to view Water bottle 9670.jpgAlbum click to view
9522.jpgAlbum click to view Pedal Boxes
Brake booster
9521.jpgAlbum click to view9520.jpgAlbum click to view9519.jpgAlbum click to view 9669.jpgAlbum click to view 9525.jpgAlbum click to view9524.jpgAlbum click to view
9668.jpgAlbum click to view clutch pedal 9526.jpgAlbum click to view
10002.jpgAlbum click to view right mount
Discussions
* Datsun 1200 (4agze TURBO)Conversion
* 4331 4AGE into Datsun 1000
826.jpg 826.jpg 1603.jpg 1607.jpg 1609.jpg 2146.jpg 3019.jpg 4065.jpg 4331.jpg 4639.jpg 4640.jpg 4641.jpg 4642.jpg 5456.jpg 5457.jpg 8867.jpg 8868.jpg 8884.jpg 10002.jpg 10936.jpg 10937.jpg 10938.jpg 10939.jpg 10940.jpg 10941.jpg 10942.jpg 10943.jpg 10944.jpg 10945.jpg 10946.jpg 10947.jpg 14388.jpg 14412.jpg 14711.jpg 15206.jpg 15215.jpg 16189.jpg 17185.jpg 18246.jpg
