Grille Badge
See main article: B10 Badges
1967 'D' chevron 62311-18025 (JDM and Export used this)![]()
1968-1970 'S' shield 62311-27725 1968-1970 'D' shield 62311-27726![]()
COUPE [flag style 'S'] 62311-25725
62311-25700
Coupe
* 62303-25700 Coupe (base) * 62303-25701 Coupe GL (black) * 25701 head lamp rim Coupe (also used by 1969-1970 sedan)
Export Coupe
Late Australia Coupe used a JDM sedan grille
Sedan
* Type 180 1967 (multi-slat aluminum) * Type 27700 1968 (eggcrate style) * Type 27701 1968 (4 chromed slats) * Type H01 1969 (3 chromed triple-slats)
#1968 Sedan eggcrate | 4-slat
#1969 Sedan 3-slat
Head light rim (eyebrows) * 18000 round type 1967 (differs from Truck) * 25700 half type 1968 sedan * 25701 half type 1969-1970 sedan (same as coupe)
1967 Sedan
1966-1967 62303-18002
1968 Sedan
62303-27700 62303-27701
1969 Sedan
Van
B10 Wagon (VB10) uses same grilles as Sedan:
- Type 180 1967 (multi-slat aluminum)
- Type 277 1968 (eggcrate style)
- Type H01 1969 (4 chromed slats)
GRILLE-radiator * 62303-18002 [with vertical center badge] * 62303-27700 from Chassis no. VB10-066701 [eggcrate style with 'S' shield badge] * 62303-27701 from Chassis no. VB10-955161 * 62303-H0100 from 1968 October
Truck
B20 Truck a.k.a. ute
- Early ute grille has vertical bars dividing it into 2 sections
- Early sedan grille has vertical bars dividing it into 4 sections
Type 180 Sedan/Van Grille - 1968 #Export Truck
27701 1968 Sedan Grille - #Export Truck
Type 154 pick-up Grille #STD 1968 Truck
G01 pick-up Grille #STD 1969-1970 Truck | #DX Truck
STD 1968 Truck
STANDARD * 62303-15400 GRILLE-radiator TS (not listed in Export catalog) Used with chevron center emblem![]()
* 62303-15401 Used with shield center emblem![]()
Export B20 (B20U) introduction
STD 1969-1970 Truck
* 62303-G0100 GRILLE-radiator TS 1969- Used with shield emblem
DX Truck
DELUXE 62303-G0101 GRILLE-radiator TD![]()
Deluxe added small vertical dividers in the upper and lower portion of the grille -- similar to the 1963 Datsun 320 truck grille
Export Truck
- Deluxe Truck was not offered
- Apparently in AUS, sedan grilles were used with some utes
1968 Australia ute with 180-Type (1967 sedan) grille
Australia ute with H01-Type (1969 sedan) grille
.jpg)
.jpg)
