<-- back to Part Numbers Index
Also see: Main article for usage, photos, cross-reference: 56-Series Transmission
Main article for usage, photos, cross-reference: F5C56
F5C56A Case
1972 B110 Parts Catalog C-231 TRANSMISSION (5 SPEED) 32010-H7251 TRANSMISSION ASS'Y (17/5) 1 08120-85510 BOLT-hex 6 2 08915-23810 WASHER-lock 6 3 08111-02062 BOLT-hex 3
TRANSMISSION CASE (5 SPEED) 4 32100-H7230 CASE COMP.-transmission 32219-G1000 BEARING-needle counter shaft 5 32102-18000 PLUG-welch T/M case 2 6 00931-10810 PLUG-filler 7 32110-H1000 COVER ASS'Y-front transmission 8 32113-H3100 SEAL-oil, front cover 9 32112-18000 RING-O, front cover As required: 10 32208-18001 SHIMG-adjusting from cover (t=0.2) 11 32208-18002 SHIMG-adjusting from cover (t=0.1) 12 32208-18003 SHIMG-adjusting from cover (t=0.3) 13 08120-82510 BOLT-fix front cover 3 14 08915-13810 WASHER-spring 3 15 32130-H7230 EXTENSION ASS'Y-rear 16 32136-G1001 SEAL-oil, rear extension 17*32150-H5000 RETAINER-oil 18 38322-H7201 BREATHER ASS'Y 19 32140-24900 BUSH-return spring 20 32351-H7200 BEARING-needle extension rear 21 08120-80510 BOLT-hex, fix rear extension 3 22 08120-80110 BOLT-hex, fix rear extension 23 08120-85510 BOLT-hex, fix rear extension 4 24 08915-23810 WASHER-spring 8 25 32137-H7200 PLATE ASS'Y-adapter 26 32133-18000 PIN-dowel, rear extension 2 27 08931-44210 PLUG-drain 28 32155-H7200 GASKET-plate coppes 29 32005-21000 SWITCH ASS'Y-reverse lamp 30 32703-15400 PINION ASS'Y-speedometer (17T) 31 32707-18000 SLEEVE ASS'Y-speedometer pinion 32 32709-18000 RING-O, speedometer pinion 33 32710-18000 RING-O, speedometer pinion 34 32708-18000 WASHER-speedometer pinion 35 32712-18000 PIN-retaining speedometer pinion 36 08915-13610 WASHER-spring 2 37 08110-61410 BOLT-fix speedometer 2 [Missing from diagram] 08120-85510 BOLT-hex 6 08915-23810 WASHER-spring 6 48 30422-18000 COVER-dust, clutch 49 08360-61014 BOLT-hex, dust cover 3
F4W56L Case
4-Speed Light-Duty to March 1973
1 32100-H1630 CASE-TRANSMISSION 4 SPEED 1070- 2 32100-H1600 1 32101-H3900 CASE-TRANSMISSION 4 SPEED 0671- 1 32100-H3930 ASSY-CASE,TRANSMISSION 4 SPEED 0172- 2 32101-H3900 1 32100-H1600 CASE-TRANSMISSION 4 SPEED 2 32102-18000 PLUG-WELCH TRANSMISSION CASE 4 SPEED 3 00933-11400 PLUG-WELCH TRANSMISSION CASE (2) 4 SPEED 3 00933-11400 PLUG-WELCH TRANSMISSION CASE (2) 4 SPEED 0172- 4 00931-10810 PLUG-FILLER 4 SPEED 5 32110-H1000 ASSY-COVER FRONT T/M CASE 4 SPEED 6 32113-13200 SEAL-OIL FRONT COVER 4 SPEED 6 32113-H3100 SEAL-OIL FRONT COVER 4 SPEED 0971- 2 32113-13200 7 32112-18000 RING-'O' FRONT COVER 4 SPEED 8 32208-18002 SHIM-ADJUST FRONT COVER T=0.1MM (0) 4 SPEED 8 32208-18003 SHIM-ADJUSTING FRONT COVER T=0.3MM (0) 4 SPEED 1071- 8 32208-18001 SHIM-ADJUSTING FRONT COVER T=0.2MM (0) 4 SPEED 8 32208-18000 SHIM-ADJUSTING FRONT COVER T=0.5MM (0) 4 SPEED 9 08120-82510 BOLT (3) 4 SPEED 10 08915-13810 WASHER-LOCK (3) 4 SPEED 11 32130-H3900 ASSY-EXTENSION REAR 4 SPEED 0172-0972 22 32130-H1010 11 32130-H6230 ASSY-EXTENSION REAR WITHOUT OIL SEAL 4 SPEED 0273- 0 32130-H3930 11 32130-H3930 ASSY-EXTENSION REAR WITHOUT OIL SEAL 4 SPEED 1072- 2 32130-H3901 11 32130-H3930 ASSY-EXTENSION REAR WITHOUT OIL SEAL 4 SPEED 0172- 2 32130-H3900 11 32130-H1030 ASSY-EXTENSION REAR WITHOUT OIL SEAL 4 SPEED 1070- 2 32130-H1010 11 32130-H1010 ASSY-EXTENSION REAR 4 SPEED 2 32130-H0110 11 32130-H0110 ASSY-EXTENSION REAR 4 SPEED 11 32130-H3901 ASSY-EXTENSION REAR 4 SPEED 1072-0173 30 32130-H3900 12 32132-18000 BUSH-REAR EXTENSION 4 SPEED 13 32136-G1001 SEAL-OIL REAR EXTENSION 4 SPEED 1072- 0 32136-H3100 13 32136-18001 SEAL-OIL REAR EXTENSION 4 SPEED 13 32136-H3100 SEAL-OIL REAR EXTENSION 4 SPEED 1071-0972 22 32136-18001 14 38322-N0100 ASSY-BREATHER 4 SPEED 1070- 2 38322-A0900 14 38322-A0900 ASSY-BREATHER 4 SPEED 15 32140-24900 BUSH-RETURN SPRING 4 SPEED 16 00931-10810 PLUG-FILLER 4 SPEED 17 08120-85510 BOLT (8) 4 SPEED 18 08915-23810 WASHER-LOCK (8) 4 SPEED 19 08915-43810 WASHER-PLAIN 4 SPEED 20 32137-H1010 ASSY-PLATE ADAPTER 4 SPEED 21 32133-18000 PIN-DOWEL REAR EXTENSION 4 SPEED 22 32141-24900 BUSH-STRIKING ROD 4 SPEED 23 32005-21100 COMP-SWITCH REVERSE LAMP 4 SPEED 23 32005-21101 COMP-SWITCH REVERSE LAMP 4 SPEED -673 32 32005-21100 23 32005-H5000 COMP-SWITCH REVERSE LAMP 4 SPEED 0773- 2 32005-21101 24 32005-H5000 COMP-SWITCHI,4 TH 4 SPEED 0773- 2 32005-21101 24 32005-21100 COMP.-SWITCH,4 TH 4 SPEED 0671- 24 32005-21101 COMP-SWITCH,4 TH 4 SPEED -673 32 32005-21100 25 32006-H6000 COMP-SWITCH,NEUTRAL 4 SPEED 0773- 2 32006-H3900 25 32006-H3900 COMP.-SWITCH,NEUTRAL 4 SPEED 0172-0673 3 26 08120-85510 BOLT FIXING TRANSMISSION (6) 4 SPEED 27 08915-23810 WASHER-LOCK FIXING TRANSMISSION (6) 4 SPEED 28 24210-89957 CLIP 4 SPEED 2 24210-89922 29 32702-15400 ASSY-PINION SPEEDOMETER 17T 4 SPEED SEDAN COUPE 30 32707-18000 ASSY-SLEEVE SPEEDOMETER 4 SPEED 31 32709-18000 RING-'O' SPEEDOMETER PINION 4 SPEED 32 32710-18000 RING-'O' SPEEDOMETER PINION 4 SPEED 33 32708-18000 WASHER-SPEEDOMETER PINION 4 SPEED 34 32712-18000 PIN-RETAINING SPEEDOMETER 4 SPEED 35 08915-13610 WASHER-LOCK (2) 4 SPEED 36 08110-61410 BOLT (2) 4 SPEED 37 30422-18000 COVER-DUST CLUCH HOUSING 4 SPEED 38 08110-61010 BOLT (3) 4 SPEED 39 08915-13610 WASHER-LOCK (3) 4 SPEED
1973 LB110 USA Parts Catalog, page 50-1
F4W56A Case
4-Speed Heavy-Duty from April 1973
1 32100-H6210 CASE-TRANSMISSION 4 SPEED 0473- 2 32005-21101 2 00933-11400 PLUG-WELCH TRANSMISSION CASE (2) 4 SPEED 0473- 3 00931-10810 PLUG-FILLER 4 SPEED 0473- 4 32110-H1000 ASSY-COVER FRONT TRANSMISSION 4 SPEED 0473- 5 32113-H3100 SEAL-OIL FRONT COVER 4 SPEED 0473- 6 32112-18000 RING-'O' FRONT COVER 4 SPEED 0473- 7 32208-18003 SHIM-ADJUSTING FRONT COVER T=0.3 (0) 4 SPEED 0473- 7 32208-18001 SHIM-ADJUSTING FRONT COVER T=0.2 (0) 4 SPEED 0473- 7 32208-18002 SHIM-ADJUSTING FRONT COVER T=0.1 (0) 4 SPEED 0473- 8 08120-82510 BOLT-FIX FRONT COVER (3) 4 SPEED 0473- 9 08915-13810 WASHER-SPRING (3) 4 SPEED 0473- 10 32130-H6200 ASSY-EXTENSION REAR 4 SPEED 0473- 11 32132-18000 BUSH-REAR EXTENSION 4 SPEED 0473- 12 32136-G1001 SEAL-OIL REAR EXTENSION 4 SPEED 0473- 13 38322-A0900 ASSY-BREATHER 4 SPEED 0473- 13 38322-N0100 ASSY-BREATHER 4 SPEED 0473- 2 38322-A0900 14 32140-24900 BUSH-RETURN SPRING 4 SPEED 0473- 15 00931-10810 PLUG-FILLER 4 SPEED 0473- 16 08120-85510 BOLT (8) 4 SPEED 0473- 17 08915-23810 WASHER-LOCK (8) 4 SPEED 0473- 18 08915-43810 WASHER-PLAIN 4 SPEED 0473- 19 32137-G1100 ASSY-PLATE ADAPTER 4 SPEED 0473- 20 32133-18000 PIN-DOWEL REAR EXTENSION (2) 4 SPEED 0473- 21 32141-24900 BUSH-STRIKING ROD 4 SPEED 0473- 22 32005-21101 COMP-SWITCH REVERSE LAMP 4 SPEED 0473-0673 3 22 32005-K1214 COMP-SWITCH REVERSE LAMP 4 SPEED 0473-0673 32005-21101,32005-H5000 22 32005-H5000 COMP-SWITCH REVERSE LAMP 4 SPEED 0773- 23 32006-H6000 COMP-SWITCH 4TH LAMP 4 SPEED 0473- 24 08120-85510 BOLT-FIXING TRANSMISSION (6) 4 SPEED 0473- 25 08915-23810 WASHER-LOCK FIXING TRANSMISSION (6) 4 SPEED 0473- 26 24210-89957 CLIP 4 SPEED 0473- 27 32702-15400 ASSY-PINION SPEEDOMETER 17T 4 SPEED 0473- 32702-15400 27 32703-15400 ASSY-PINION SPEEDOMETER 17T 4 SPEED 0473- 2 32702-15400 28 32707-18000 ASSY-SLEEVE SPEEDOMETER 4 SPEED 0473- 29 32709-18000 RING-'O' SPEEDOMETER PINION 4 SPEED 0473- 30 32710-18000 RING-"O" SPEEDOMETER SLEEVE 4 SPEED 0473- 31 32708-18000 WASHER-SPEEDOMETER PINION 4 SPEED 0473- 32 32712-18000 PIN-RETAINING SPEEDOMETER 4 SPEED 0473- 33 08915-13610 WASHER-LOCK (2) 4 SPEED 0473- 34 08110-61410 BOLT-FIX SPEEDOMETER (2) 4 SPEED 0473- 35 30422-H5010 COVER-DUST CLUTCH HOUSING 4 SPEED 0473- 36 08111-01614 BOLT-HEX DUST COVER (3) 4 SPEED 0473- 37 32719-18000 BUSH-SLEEVE SPEEDOMETER 4 SPEED 0473-
1973 LB110 USA Parts Catalog, page 50A-1
