Late-model Vacuum Advance
Revision as of 23:59, 7 May 2019; view current revision
Category: Distributor
For Hitachi D4A Distributor (points) distributors, D4F (remote ignitor) and D4K (matchbox) distributors. All 1974-1982 model B210, B310 and N10 (310/Pulsar) use the same vacuum advance modules. Advance varies slightly by year and model (see Spark Curve). Some are advance/retard units. See Datsun Factory Service Manual for the specs. Original B110 distributors use a different shape module.
ANY modules fit and work "OK", but none are correct for performance -- they are all emission related. The curve can be adjusted. Just remember it has zero effect on full-throttle acceleration (vacuum advance only works at part throttle).
26839.jpgAlbum 26839
These two screws fasten the Vacuum Advance module to D4K. Remove screws and pull module out
174_5786fc8bacf03.jpgUpload click to view
$40-$70 at RockAuto.com. $20-up eBay.
  • AIRTEX 4V1179/4V1150
  • Standard Motor Product VC506/VC469/VC483/VC436
  • Niehoff WA894A
  • BWD V569
Dot is color code for the advance curve. You can peel the sticker off, dig out the clay, and adjust the total advance. The internal spring controls the steepness of the curve.
26840.jpgAlbum 26840
Vacuum Advance rubber diaphragm gets old and brittle from age, cracks, then won't hold vacuum. Replace the entire unit (unless you know of a source for new rubber?)
26841.jpgAlbum 26841 26842.jpgAlbum 26842
USA B310 CONTROL ASSY-VACUUM
  • 22301-H7365 A14,A15 CAL to 0780 $75.20
  • 22301-H9801 A15 CAL(MANUAL) from 0880 former 22301-H7365 $67.72
  • 22301-H9806 A15 CAL(AUTO) from 0880 former 22301-H7365 $57.00
  • 22301-H7205 A14,CAN(AUTO) $63.03
  • 22301-H9106 A14,A15 FED(AUTO) to 0780 $45.98
  • 22301-H9501 A15 FED from 0880 former 22301-H9106 $45.98
  • 22301-H8700 A15 FED(MANUAL) from 1279 to 0780 former 22301-H9106 $66.12
  • 22301-H9160 A14 FED(KFU) to 0779 $57.08
  • 22301-H9100 A14 FED(MANUAL) $54.60
  • 22301-M2361 CAN A12 + CAN A14,A15(MANUAL) $92.72
Possible Fit: Standard Motor Product
  • VC506 Nissan 210 80
    • 22301-H9100
  • VC505 Nissan Stanza 82
  • VC504 Nissan Stanza 82
  • VC503 Nissan 510 80
  • VC502 (Advance/Retard) Nissan 310 81
  • VC499 (Advance/Retard) Nissan Sentra 83
  • VC498 (Advance/Retard) Nissan Sentra 1982
  • VC497 Nissan 620 Pickup 77-75 . Nissan B210 76-75
    • 22301-H7205 $63.03
  • VC495 Nissan B210 74
    • 22301-H6200
  • VC492 Nissan 280Z 77, Nissan 810 78-77
  • VC489 Nissan 510 79
  • VC486 Nissan 310 81-80
    • 22301-H7201
  • VC485 Nissan B210 77-76, Nissan F10 77-76
    • 22301-H7201
  • VC483 Nissan Nissan B210 78-77, Nissan F10 78-77
    • 22301-H7360 $71.28
  • VC481 Nissan B210 76-75
    • 22301-H7200
  • VC469 Nissan 210 80-79, Nissan B210 78-77
    • 22301-H9106
    • 22301-H7106
  • VC463 Nissan Pulsar NX 85-83, Nissan Sentra 85-83
  • VC437 (Advance/Retard) Nissan 210 80
    • 22301-H8700
  • VC436 Nissan 210 82-79, Nissan 310 80-79, Nissan B210 78, Nissan F10 78
    • 22301-H7680 $92.72
    • 22301-M2361 (same part)
  • VC351 Nissan 280Z 77, Nissan 280ZX 79, Nissan 810 78-77
  • VC350 Nissan Stanza 84-83
  • VC284 (Advance/Retard) (1978 Honda Accord)
    •  ?? 22301-18R00,22301-18R05,22301-D3300 ??
  • VC285 Nissan Stanza 86-85
NOT FIT
Hitachi Type D4N (internal ignitor) -- Side-screw module
Z20,Z22,Z24 (Z24I has no vacuum advance module)
* VC508 Nissan  720 Pickup  84-83
* VC482 Nissan  720 Pickup  84-83
* VC466 Nissan  720 Pickup  82-81
