Weber DGV Adapters
Revision as of 08:00, 15 May 2019; view current revision
Category: Fuel System
The Weber 32/36 (DGV) carburetor has a larger bolt pattern than the stock Hitachi on a Datsun A-series engine. You can modify the stock manifold, or use an adapter plate.
<-- Back to Weber 32/36 Carburetor
[hide]
174_59868ad1eaea0.jpgPost 485784
Comparo: DGV vs Hitachi 306
10870.jpgAlbum 10870
You can make a DGV-compatible intake:
11269.jpgAlbum click to view 5178.jpgAlbum click to view 7236.jpgAlbum click to view 3038.jpgAlbum click to view
But most of us use an adapter plate:
589.JPGAlbum click to view 7235.jpgAlbum click to view
Adapters for many models are available for sale, but I made my own adapter for the Nissan A12 engine out of a block of aluminum:
820.jpgAlbum 820
Custom machined adapter (left) and kit-provided cast adapter
Be sure to use the Weber-type (thick) gasket under the carburetor. If you use a thin gasket it may tear during operation.
11219.jpgAlbum 11219
2976.jpgAlbum 2976
Plate Numbers
10-212 for larger Datsun L-series carburetor
26875.jpgAlbum 26875
Fits all with 80mm x 43mm carb base
Chrysler/Mitsubishi Colt, Galant,Lancer, Sigma
- Citroen CX2200, CX2400
- Daihatsu with 80mm x 43mm carb base
- Datsun 1600, 180B, 200B, 240K, 260C, Bluebird, 510, 610
- Fiat 125 coupe, X-19, 131
- Ford Courier with mazda engine
- Holden Gemini 1600 OHC (Isuzu)
- Isuzu, Bellet, Gemini, Luv
- Mazda 1200, 1300, 808, 323 rear wheel drive model, 1500, 1800,929,
  Capella 121, mazda 1400
- Mitsubishi Express L300, Mitsubishi Colt, Galant,Lancer, Sigma
- Toyota corolla 1100,1200 1300 1966-1984
3K,4K 5K, 1983-1987 corolla/sprinter/seca
Corona, Celica, Crown, Celica 1600 TA22 1971-75
Suppliers
Most local auto parts store can custom-order this part for you.
Or buy mail order
http://redlineweber.com
Pierce Manifolds $45 USD
2646.jpgAlbum 2646
Make Your Own Plate
Weber bolt-pattern: 93x46mm | A-series manifold: 61x37mm
5450.jpgAlbum 5450 174_59868adec9885.jpgPost 485784
  1. Dimensions: 1 x 2.75 x 5 inches (minimum would be approximately 10 x 6.7 x 11.4 mm)
  2. Using a Nissan gasket as a template on one side, and the Weber gasket on the other, mark the holes.
  3. Drill two bores ~30mm and 27mm to match the intake manifold. You might have a machine shop do this; I had access to a lathe with a large bit chuck into it.
  4. Drill and Countersink holes for stock Nissan pattern using a drill press to get them straight.
  5. Thread holes for Weber pattern
  6. Use a round rasp file to smooth out the transition from the small Nissan bore holes to the larger Weber holes you drew from the template
500.jpgAlbum click to view 11589.jpgAlbum click to view 11590.jpgAlbum click to view 11591.jpgAlbum click to view 11596.jpgAlbum click to view 3067.jpgAlbum click to view 5178.jpgAlbum click to view 5315.jpgAlbum click to view 7235.jpgAlbum click to view 7236.jpgAlbum click to view 11270.jpgAlbum click to view
