Steering Gear Part Numbers
Revision as of 09:06, 22 July 2019; view current revision
Categories: Steering System | Catalog
<-- back to Part Numbers Index
Also see: Main article for usage, photos, cross-reference
Steering Gearbox
Steering Column
1 48805-H1951 ASSY-GEAR,STEERING, COLLAPSIBLE OP.
2 48850-H1900 ASSY-TUBE,JACKET OP.
3 48011-H1601 ASSY-HOUSING,GEAR OP.
4 48820-H1900 ASSY-SHAFT,COLUMN OP.
5 48025-18000 BEARING-WORM OP.
6 48103-H1002 SHAFT-SECTOR OP.
7 48137-H1002 SEAL-OIL OP.
8 48135-66000 SCREW-ADJUSTING OP.
 08911-3401A NUT OP. 08911-34010
9 08911-34010 NUT OP.
10 48133-66000 SHIM-SCREW,T=1.62 OP.
10 48134-66000 SHIM-SCREW,T=1.65 OP.
10 48131-66000 SHIM-SCREW,T=1.56 OP.
10 48130-66000 SHIM-SCREW,T=1.53 OP.
10 48132-66000 SHIM-SCREW,T=1.59 OP.
11 48201-18000 COVER-SIDE OP.
12 48204-18000 PACKING-SIDE COVER OP.
13 08931-10410 PLUG OP.
14 08120-82010 BOLT (8) OP.
15 08915-13810 WASHER-SPRING (8) OP.
16 08911-24610 NUT OP.
17 08915-14610 WASHER-LOCK OP.
18 48031-18000 SHIM-COVER,T=0.05 OP.
18 48032-18000 SHIM-COVER,T=0.07 OP.
18 48033-18000 SHIM-COVER,T=0.08 OP.
18 48034-18000 SHIM-COVER,T=0.10 OP.
18 48035-18000 SHIM-COVER,T=0.12 OP.
19 48910-H1020 BUSH-COLUMN OP.
19 48910-H1021 BUSH-COLUMN OP. 2 48910-H1020
20 48931-H1020 WASHER-PLAIN OP.
21 00922-11700 RING-SNAP OP.
22 08110-81210 BOLT (4) OP.
23 08915-13810 WASHER (4) OP.
24 48960-H1020 ASSY-CLAMP,STEERING POST OP.
25 08915-13810 WASHER-LOCK (4) OP.
26 08110-81210 BOLT (4) OP.
27 08120-83010 BOLT (2) OP.
28 08915-53810 WASHER-PLAIN (3) OP.
29 48361-H1000 BOLT (3) OP.
30 48366-H1000 NUT (3) OP.
31 48502-H1600 ARM-STEERING GEAR OP.
