Datsun 1200 can use many engine oils including these modern blends:
* 5W-40 * 10W-30 * 10W-40
Oil Change Specs
1972 Recommendation every 3 months * Change engine oil (& filter every other time) every 6 months * Replace oil filter * Check oil system for leaks
Oil needed: 4 quarts with oil filter change
Modern Recommendation
With today's modern oil blends, we recommend changing the oil and filter every 6 months/6000 miles for regular oil. Regular oil (non-synthetic) is a fine lubricant but as it breaks down sooner, regular changes are a must!
Synthetic oil does not break down as fast, so if using a synthetic oil the changes can be less frequent. For example, Mobil 1 Extended Performance is guaranteed for 15,000 miles/12 months.
Engine Oil Viscosity
Choose the engine oil by the climate in your area. The 10Ws are good down to freezing, per the owner's manual chart, while 5Ws are good for colder climates.
The lower weights (5W especially) will use less HP when the engine is cold, however they cannot be used for high speed driving. Instead, a 5W-40 blend can be used, gaining HP and fuel economy both. And its 40 rating means no problems at high temperatures.
5W-40 Temp Range: -10F to 120F
Recommended by Nissan, depending on temperature * 5W-20 (for cold areas) * 20W-40 * 10W-40 * 10W-30
Nissan also specified some single weights, but those have a limited temperature range.
Since the A series is a pushrod engine, it is highly recommended to use an oil designed for older engines that has higher levels of ZDDP in it. The risk you run is rounding your camshaft lobes or wearing through the hardened face of the lifters. Symptoms include a tapping or ticking developing on the valvetrain from your lash on one or multiple valves opening up from the increased wear on the damaged lobes. If you've been using modern oils, the switch to high zddp oils will result in a smoother and quieter engine immediately after the oil change.
Factory Datsun 1200 Specifications
Reference: 1972 USA Owner's manual original Specification:
* Multigrade: SD MIL-L-2104B or * Monograde: SD MIL-L-2104B
Oil Usage
It is normal to add some oil between the oil changes. Usually a quart every 1,500 miles is OK. A quart every 500 miles indicates either a serious leak, or "oil burning" (bad rings) in the engine. To test for ring wear, perform an Engine Smoke Test. You can also do a wet/dry engine compression test using an inexpensive compression gauge.
