<-- Back to: Lighting System
The room lamp, also known a dome light.
Put the switch in the middle position so it operates from the door switches (if so equipped).
1972 USA Owners manual (Page 06 ... ):
To switch the interior lamp "ON", and "OFF", turn the switch lever clockwise or counterclockwise.
alternative interior headliner light
Car
These parts are the same for both B110 and B210.
B110 | B210 (120Y)
Pickup
buy from Bprojects 26410-04100 LAMP ASS'Y-room -7803 IKI [single wire] 26410-04400 LAMP ASSY-ROOM 7803- IKI [two wire] 26410-G1000 LAMP ASSY-ROOM -7803 IMASEN
Two Wire type: * Red/yellow: bulb 12V * Black: earth/groundReportedly, the 2000 Rodeo sport the same or similar Room Lamp to the late 1200 (both with door light positions)
Astro_Boy: was looking at a 2000 model rodeo ute that was crashed and would you believe it? THE INTERIOR LIGHT is the same size and shape as the standard datsun one, but with a door sensor setting!
B10
B10 sedan and VB10 wagon uses the same lap as 1200 ute. IKI brand (市川, Ichikawa).
26410-04100 ASS'Y-LAMP, room STD IKI 26410-04400 ASS'Y-LAMP, room DELUXE IKI
521 Lamp
Datsun 521 pickup (USA) uses the same Room Lamp as a 1200 Pickup. IKI brand.
26400-04100 ASS'Y-LAMP, room 26410-04400 ASS'Y-LAMP, room * 26411-04100 LENS * 26715-89900 BULB (12V 6W) * 5-10813-1 SCREW-machine (2)
510 Lamp
510 lamp is a different style and bolts into B210, so may fit B110.
26410-23100 ASSY-LAMP ROOM -0968 EXC CAN <x> 26410-23101 * 1968 CANADA used dual rectangular side lamps 26410-A0800 ASSY-LAMP ROOM 0968-
Door Switch
The door switch connects the Room Lamp circuit. It also connects the Key Warning Buzzer.
- The 1200 door switch is a single wire unit that grounds the wire when the door is opened
- The 1973 USA door switch is a double-switch (with an extra wire)
25360-89900 SWITCH-DOOR DELUXE(OP STD) 25360-89915 SWITCH-DOOR USA 0172-
The room lamp has one side of the lamp (RL wire) always hot from the L wire of the fuse box (Fuse 'C'). The switch has three positions:
* Off * Auto (center) * On
In the auto position, the light is grounded by the Door Switch (BR wire in A-pillar). Usually only the driver's side door has a switch. In the ON position, it is grounded through the ground wire in the headliner (or with standard switch, via the attaching screws).
Dash harness has the door switch/room lamp wiring
Black Ground Black/red Ground from door switch Red/blue Always Hot
- 12V is supplied by 'C' fuse in Fuse Box (C: Cigarette, Room, Radio)
- Ground wire out of Lamp may be a short wire that bolts to the roof metal
- Early truck lamps have no Ground wire (black wire) but ground through the lamp screws. This is for use without a door switch
- 1973 used a relay, but with the same wire colors. The 1973 door switch is a double-switch (with an extra wire)
7804- wiring with 2-wire room lamp (can use optional door switch)
-7804 truck with 1-wire room lamp (no option for door switch)
1971 USA Wiring - with buzzer
1973 USA Wiring - with buzzer, warning light, IGN interlock
