Unlike the B110 foglamps, fog lights for the B210 bolt into the grille.
NOTE: North American B210s used the grille lamps for the indicators (instead of for fog lamps).
B110-style fog lamps can be fitted to the B210
Early 1973-1975
Late 1976-1978
Late B210 was from late 1975 to 1978. The B210 facelift variant (B211) was produced 1976-1977 in Japan.
- triangular brackets with top bolt offset
- sloping lens with 'NISSAN' in center
- 30W bulb
Late Sedan JDM (B211) & ADM 120Y (B210)
#Type H79 L16-powered (GB211)
Type H79
The Sunny 1600 was the L16 engine-powered version (GB211).
26150-H7926 FOG LAMP KIT for OKINAWA
GX grille came with fog lamps pre-installed
Foglamp bracket top bolt goes into the core support, and also doubles as one of the grille bolts.
Early * H50 RECTANGLE sedan,van * H55 ROUND coupe
Late Rectangle * H74 1200,1400 * H75 1200,1400 Okinawa * H79 1600
Early
EARLY -1975 * H50 RECTANGLE sedan,van * H55 ROUND coupe * #H58 PB210 RECTANGLE
RECTANGLE OPTION Sedan,Van * 26150-H5027 LAMP KIT-fog > 26150-H5025 <> 26150-H5026
ROUND COUPE * 26150-H5527 K-GX K-DX,K-GL OPTION > 26150-H5525 <> 26150-H5526 * 25160-H6001 SWITCH COMP.-lighting with fog
26151-26501 LENS 2 [clear, same as 510] 26152-26500 RIM 2 [same as B110] 25160-H6001 SWITCH ASSY-LIGHTING W/FOG
H58 PB210
サニーエクセレント フォグランプ バルブᴳ PB210 Sunny Excellent 1400
PB210 FOG LAMP GX (op.) DX,GL SEDAN,COUPE [3-bolt bracket with top bolt centered] 1 26150-H5825 LAMP KIT-fog [triangle-top bracket] 25150-H5826 from 1974.1 <> H2825 25150-H5827 * from 1975.4 < H2826 NOTE for 1975 revision parts: unreadable ------------------------------------- Lamp Kit contains the following parts ※ interchangeable only as left and right set ※印 互??は左右セットで? 26150-H5800 LAMP ASS'Y-fog RH 26150-H5801 LAMP ASS'Y-fog RH from 1974.1 26150-H5802*LAMP ASS'Y-fog RH from 1975.4 26155-H5800 LAMP ASS'Y-fog LH 26155-H5801 LAMP ASS'Y-fog LH from 1974.1 26155-H5802*LAMP ASS'Y-fog LH from 1975.4 26151-H5800 LENS-fog lamp RH 2 26156-H5800 LENS-fog lamp LH 3*26154-H5800 BRACKET-fog lamp 2 4 96706-P0105 SCREW GROMMET 2 5 08510-52590 SCREW-tapping 2 6 08513-51623 SCREW-tapping 7*26152-H5800 SPRING-fog lamp 2 ------------------------------------- 8 25160-H6001 SWITCH-COMP.-lighting with fog 26718-26500 BULB 12V-30W (to 1974.12) 26730-S0115 BULB 12V-30W (from 1974.1) reference: PB210 Parts Catalog C-261 revision 1976.11 pages 220-2 to 220-3
Late
LATE 1976- LAMP KIT-FOG 30W bulbs (3-bolt type, sloping lens) * top bolt offset 26250-H7525 S.A14.GX *S.A12,A14-GX *V 26250-H7526 K.A14.GX *K.DX,GL-L16 26250-H7427 *S,V F/OKINAWA [lens differs from non-OKINAWA] 26250-H7428 *K F/OKINAWA 26250-H7925 L16.GX *L16.GL 26250-H7926 *L16 F/OKINAWA 26730-S0115 BULB 12V-30W
25160-H6001 SWITCH ASSY-LIGHTING W/FOG 25160-H5201 SWITCH ASSY-LIGHTING W/FOG&ILLUMI 25160-H5800 SWITCH COMP.-lighting with fog PB210 GX (op.)DX,GL
フォグ ランプ
