Megasquirt is a relatively low-cost electronic engine controller that several Datsun1200.com club members are using to control their A-series engines. It can control Fuel Injection and ignition (spark) both, although for spark-only the MegaJolt-EDIS product is less expensive and simpler to install. Variations include the original MegaSquirt, MegaSquirt II (MS-II) and the latest MicroSquirt. The MicroSquirt is the same as MS-II but in a small sealed case.
For general info, see: wikipedia:Megasquirt
Comparison
The MegaSquirt controller is a relatively low-cost -- relative to other aftermarket engine computers.
From least expensive to most:
- OEM engine controller (used)
- MegaSquirt solder-together kit
- MegaSquirt completed product
- MegaSquirt II
- MicroSquirt
- HALtech, Wolfe, and other aftermarket "custom" ECU systems
MegaSquirt software has evolved to the point where it is arguably as sophisticated as the more expensive designs.
The newer MegaSquirt-II from 2005 has hardware that matches the more expensive designs, notably:
- Ignition control (distributorless systems)
- CAN-bus support
- 16-bit processor
Club Users
- Finn: MegaSquirt controlling the world's quickest A-series engine
Kit
Many users choose the solder-together MegaSquirt Kit. The Kit is about half the price of an assembled unit.
- If you have ever successfully soldered any electronic kit, even a simple one, you should be able to assemble a MegaSquirt.
- Time to assemble is about
Usage
When do you need a MegaSquirt? If you are using EFI. You will need some kind of controller for it. If you are adapting an OEM fuel injection system, you can use the OEM computer which is cheap at the wreckers. But for highly customized engines, MegaSquirt will give you that fine tuning.
Question:I want to fit crank-trigger or coil-on-pack ignition. Is MegaSquirt for me?
Answer: You can use MegaJolt-EDIS instead. But the MegaSquirt II can also control the ignition, though it is about double the price.
Board Versions
- V1: original board revision, no longer available
- V2.2: V2.2 is printed in the upper left corner of the printed circuit board
- V3: MegaSquirt II
- V3.57: MegaSquirt II surface-mount board (non-kit board)
Parts Needed
- EFI system, your choice of manifold, injectors and throttle body. MegaSquirt can handle most brands of injectors
- Megasquirt unit
- For a kit: you may wish to get the Stimulator to test your board during the put-together phase
- Wires to wire it together
- Oxygen sensor (optional but recommended)
- MAP (vacuum) sensor or TPS (throttle position) sensor. Again, any brand (Ford, GM, Nissan, etc) may be used.
- Air temp sensor
- Water temp sensor
The sensors are usually the General Motors type, although you can recalibrate the controller to use other.
