The rear license plate was illuminate by lamps either above plate, below plate or on both sides.
Japan-market Round Headlight Rear Plate below bumper Square Headlight Rear Plate above bumper Large Bumper Rear Plate above bumper
Round Headlight Plate below bumper, lamps above plate (tucked up under bumper)
all VB310 are round headlight models
Square Headlight Plate above bumper, lamps in top of bumper
Plate above bumper, side lamps OPTION S/K(A14)
Large Bumper Plate above bumper, lamps on either side of plate
* Large Bumper standard equipment all WB310
option Sedan/Coupe
Early: top-illuminated
Late: bottom-illuminated
side-illuminated (OPTION Sedan/Coupe)
Van: bottom-illuminated
Large Bumper Models
Large bumper models had no number plate lamp in the bumper -- both early and late models placed the Number Plate and its lamps above the bumper.
Sedan/Coupe side-illuminated twin lamps either side Wagon top-illuminated twin-bulbs under chrome trim
Late Large Bumper (has rubber strip along face)
Sedan and Coupe Mid
7812-7909 with Shock Absorbing Bumper
Sedan and Coupe Late
Wagon
For WB310 (Sunny California, etc.)
Small Bumper Models
Vans used bottom-illuminated type: Two small button-type lamps on the top edge of the bumper.
Europe | Japan
Early had top-illuminated plate with lamp tucked up under bumper
Late bottom-illuminated | side-illuminated
Late Sedan bottom-illuminated (two small lamps on bumper) GL | DX
Late Sedan side-illuminated like 1973 B110
Van
Sedan and Coupe Early
Early sedan & coupe had top-illuminated plate with lamp tucked up under bumper. It used a single lamp of the same type as B110 coupe and B120 ute.
1200 coupe/ute lamp
Wagon
WB310 sport wagon had the rear number plate lamp above the plate under a trim piece.
Chrome trim | Sunny California plastic trim
WB310 vs VB110 - similar number plate lighting
Type H85 KB110 style lamp shining down (early bumper) Type H88 Cherry style lamps on top of bumper (late bumper) Type H856 lamps on either side of plate Type H87/H89 ""
Lamp
LICENCE LAMP ASSY RH 26510-H8500ᴳ K,S -7811 26510-H8560ᴳ K,S 7910-8010 IKI 26510-H8565ᴳ *S.A14 7910-8010 F/SHOCK AB BUMPER IKI K.GS,ES S+K.GX,RSE 26510-H8700ᴳ *K 7812-7909 F/SHOCK AB BUMPER IKI 26510-H8765ᴳ *K.A14 7910-8010 F/SHOCK AB BUMPER IKI 26510-H8800ᴳ S,K 7812-7909 IKI 26510-H8900ᴳ *S 7812-7909 F/SHOCK AB BUMPER IKI 26510-H9400ᴳ V 26510-H9800ᴳ W 7812-
LICENCE LAMP ASSY LH 26515-H8565ᴳ *S.A14 7910-8010 K.GS,ES 8011- S 8011- 26515-H8700ᴳ *K 7812-7909 F/SHOCK AB BUMPER IKI 26515-H8765ᴳ *K.A14 7910-8010 F/SHOCK AB BUMPER IKI 26515-H8900ᴳ *S 7812-7909 F/SHOCK AB BUMPER IKI
Lens
26511 LENS-LICENCE PLATE LAMP RH レンズ、ライセンス ランプ 26511-H5000ᴳ S,K -7909 [similar to KB110 license lamp ] 26511-H8700ᴳ *K 7812-7909 SHOCK AB BUMPER IKI 2 26511-H8900ᴳ *S 7812-7909 SHOCK AB BUMPER IKI 2 *S,K.A14 7910- SHOCK AB BUMPER 26511-H9800ᴳ W 7812- 26511-M0200ᴳ S,K 7910- V
Applied Model Code
M02: designed for E10RT Nissan Cherry/Datsun 100A
26511-M0200 REAR NUMBER PLATE LAMP LENS, IKI 6101
