FJ engine swap
Revision as of 08:43, 8 January 2024; view current revision
Categories: Engine Modifications | Engine Swaps | Nissan Engines
The Nissan FJ Engine was basically a detuned race engine, a bit heavy but possibly Nissan's strongest ever engine. The stock engine can take massive boost and survive, while turning out incredible horsepower. Originally designed as the FJ24 for use in 240RS racing cars, it was in mass production as the FJ20 engine fitted to the DR30 Nissan Skyline. The FJ engine is very heavy with the turbo version at 366 lbs, heavier than the 318 lb Rover V8 Engine/Buick V8 3.5 liter engine and 36 pounds heavier than the SR20 turbo. The FJ engine was produced in three variations: 1) FJ24E 2) FJ20E 3) FJ20ET.
Aside from the very strong block which can survive massive power, the reason the FJ was so powerful was the 4-valve-per-cylinder head. It was Nissan's first mass produced 16-valve four-cylinder engine, a spiritual successor to the 1969 Skyline GT-R S20 4-valve six-cylinder. In 1985 the CA18DE would replace the FJ, being Far, far lighter and more suitable for a range of roadgoing car, and yet with a block still capable of surviving 400hp. In turn, a larger displacement engine, the SR20, replaced the CA18DE.
For general information, see: http://fj20.com
PRO12T and FJ20ET Turbo
579.jpgAlbum 579 400px-FJ20ET.jpgWIKI click for photo
The mighty FJ20E makes 148 HP from 2-liters, and with a turbo the FJ20ET makes up to 203 HP in stock form.
5471.jpgAlbum 5471 5328.jpgAlbum 5328 4895.jpgAlbum 4895 5326.jpgAlbum 5326
The only FJ 1200 in Japan
16136.jpgAlbum 16136
Although it is heavier than a GM 3800 V6, the FJ fits somewhat better into a 1200's engine bay. It looks most excellent, doesn't it?
17207.jpgAlbum 17207 17208.jpgAlbum 17208
Sources
FJ Engine Source:
  • 1982-1983 Nissan Silvia BS110 '240RS' 240 HP, Works 275 HP
    400px-Nissan_Silvia_S110.jpgWIKI click for photo 4117.jpgAlbum 4117
  • 1983-1988 Nissan Silvia S12 FJ20E 150 PS, FJ20ET 190 PS, FJ20ET inter-cooled 205 PS
    400px-Nissan_200sx_SE.jpgWIKI click for photo
  • 1982-1985 Nissan Skyline DR30 '2000RS' FJ20E 110kw
    3322.jpgAlbum 3322 4678.jpgAlbum 4678
  • 1983-1984 Nissan Skyline DR30 '2000RS Turbo' or 'RS-X Turbo' FJ20ET 140kw
  • 1984-1985 Nissan Skyline DR30 'RS-X Turbo C' FJ20E 151 kw
    400px-LD4C4288.jpgWIKI click for photo 400px-LD4C4250.jpgWIKI click for photo
Which is better? FJ20 or SR20?
Both:
  • make about the same HP in stock form (SR20DE 140-169HP, F20E 148 HP)
  • In turbo versions, both are too large for as 1200 (too large for normal engineering process) in Australian. In this country, the CA18DET is better than SR20DET or FJ20ET for street cars.
FJ20DET
  • In stock condition, can take more boost than SR20DET, thus more HP without opening the engine up
SR20
  • Lighter, so won't be as detrimental to handling
  • More were produced, so prices are lower
Build-Ups
  • FJ20 has all the usual build-up parts, same as SR20. However as less FJs were produced, so too the market for FJ parts is more expensive than SR parts.
FJ-powered 1200s
34 PSI
Pooley's POST 34 PSI
Blake's Coupe
4186.jpgAlbum 4186 4187.jpgAlbum 4187 4188.jpgAlbum 4188 4189.jpgAlbum 4189
Collingrove Coupe
Collingrove hill climb
9449.jpgAlbum 9449 9464.jpgAlbum 9464
dattofj20guy
POST And my story begins
6577.jpgAlbum 6577
FJ1200
Santo Di Pietro's ute out of New South Wales with FJ power.
Fast Fours November 2014
26601.jpgAlbum 26601 26600.jpgAlbum 26600
Hot4s 257
Hot4s-257-2b.jpg 26540.jpgAlbum click to view 26541.jpgAlbum click to view
Sandy's fj1200
22627.jpgAlbum 22627 22890.jpgAlbum 22890 22628.jpgAlbum click to view 22629.jpgAlbum click to view 22630.jpgAlbum click to view 22626.jpgAlbum click to view 18032.jpgAlbum click to view 17521.jpgAlbum click to view 17520.jpgAlbum click to view 17519.jpgAlbum click to view 17518.jpgAlbum click to view 17426.jpgAlbum click to view 17423.jpgAlbum click to view 17242.jpgAlbum click to view 17241.jpgAlbum click to view 17240.jpgAlbum click to view 17239.jpgAlbum click to view 13921.jpgAlbum click to view 13911.jpgAlbum click to view 10750.jpgAlbum click to view 10749.jpgAlbum click to view 10748.jpgAlbum click to view 10747.jpgAlbum click to view 10746.jpgAlbum click to view 10745.jpgAlbum click to view 10744.jpgAlbum click to view
FJ1200
24235.jpgAlbum click to view 24234.jpgAlbum click to view 24233.jpgAlbum click to view 22891.jpgAlbum click to view 22890.jpgAlbum click to view 22889.jpgAlbum click to view 22888.jpgAlbum click to view
HYP014
14630.jpgAlbum 14630 14636.jpgAlbum 14636 14634.jpgAlbum click to view 14629.jpgAlbum click to view 14628.jpgAlbum click to view 14631.jpgAlbum click to view 14632.jpgAlbum click to view
Joshh
POST Joshh's FJ20et 1200 ute FJ2020
FJ2020 on Simmons FR
FJ2020 on Convo rims
post-21145-1224492028870042089.jpg post-21145-12244926481162724260.jpg post-21145-1224492236759208526.jpg post-21145-122449203635452681.jpg post-21145-12244920306959542.jpg
1197.jpgAlbum 1197 1198.jpgAlbum 1198 1199.jpgAlbum 1199 2932.jpgAlbum 2932
kegs
13081.jpgAlbum 13081 13082.jpgAlbum 13082 13083.jpgAlbum 13083 13084.jpgAlbum 13084
Montery Park Coupe
NIS15L
YAW871
3932.jpgAlbum 3932 3933.jpgAlbum 3933 6508.jpgAlbum 6508
Pink Ute
2910.jpgAlbum 2910 2911.jpgAlbum 2911 2987.jpgAlbum 2987 14937.jpgAlbum 14937 14938.jpgAlbum 14938
Racingfuji's Coupe
12537.jpgAlbum 12537 12538.jpgAlbum 12538
SLUG
White FJ20 1200 Ute at 2011 DATNATS
22901.jpgAlbum 22901 22902.jpgAlbum 22902 23041.jpgAlbum 23041
OFJ020 "SLUG" at 2008 SUMMERNATS
15108.jpgAlbum 15108 15109.jpgAlbum 15109
SLUG at 2010 Powercruise 23
21542.jpgAlbum 21542
orange OFJ020
1210.jpgAlbum 1210
Stanek
Paul Stanek's IPC Turbo Charging B110 Coupe
SuPeR
POST SuPeR's ute
TIG20T
Main: TIG20T
TUF120
POST TUF120
post-209-1229235530122510236.jpg post-41355-1235745893325587072.jpg post-209-12292354781993449952.jpg
YAQ70Z
5976.jpgAlbum 5976 5827.gifAlbum 5827 5828.gifAlbum 5828 5981.jpgAlbum 5981
YFJ20T
FJ-powered wagon 'YFJ20T'
1342.jpgAlbum 1342 1343.jpgAlbum 1343 1344.jpgAlbum 1344 18332.jpgAlbum 18332 17207.jpgAlbum 17207 17208.jpgAlbum 17208
FJ-powered B210
George Fury 120Y
Jamie Drummond-built Datsun 120Y "Grunt20Y" that was driven by George Fury during the 1980s.
POST George Fury 120 Y /FJ24
http://youtube.com/results?search_query=george+fury+120Y
 V I D E O  George Fury Datsun 120Y Rally (click to view)
 V I D E O  George Fury Datsun 120Y @ WRC Coff Harbour (click to view)
Graeme Adair
FJ20 twin carbed 120Y coupe race car
174_5a03e9213b19a.jpgPost 486691 174_5a03e925caa74.jpgPost 486691 174_5a03e92cb5199.jpgPost 486691 174_5a03e9441ffa2.jpgPost 486691
Sleeper 120Y Sedan
Sleeper 120Y 'YAF49U' spotted at 2005 South Coast Nationals
Sleeper.jpgPost click for topic Sleeper1.jpgPost click for topic SleeperDatto.jpgPost click for topic
7550.jpgAlbum 7550
Y Be Normal Coupe
Y4's FJ-powered B210 'QLS216' NSW: Y Be Normal! -Datsun 120y (As Featured in Hot 4's No.27)
120Ys were a bit of a lemon, but the only lemon thing about this one is the paint
2047.jpgAlbum 2047 2048.jpgAlbum 2048 2046.jpgAlbum 2046 2044.jpgAlbum 2044 2045.jpgAlbum 2045
  • EXTERIOR: Lemon yellow tinter paintwork, 15x8" Dragway Carma wheels and 205/50 tyres
  • INTERIOR: Maxrob steering wheel, Razo pedals and autometer gauges, 3 tone retrimmed velour interior
  • ENGINE: FJ20ET turbo
3448.jpgAlbum 3448 3451.jpgAlbum click to view 3450.jpgAlbum click to view
FJ-powered B310
datman55's FJ20T in Datsun B310
2509.jpgAlbum 2509 2514.jpgAlbum 2514 2699.jpgAlbum 2699 3109.jpgAlbum 3109 6779.jpgAlbum 6779
183hp at the rear wheels with 850lb of torque, at 6,000rpm with a 36mm restrictor and 15 psi boost
5613.jpgAlbum 5613 5717.jpgAlbum 5717 5400.jpgAlbum 5400 5395.jpgAlbum 5395
more photos
2510.jpgAlbum 2510 3108.jpgAlbum 3108
Dry sump FJ
9297.jpgAlbum 9297 5328.jpgAlbum 5328
Fire Rings
4896.jpgAlbum 4896 9793.jpgAlbum 9793
510 Swaps
Datsun 510 Bluebird
rx2capella
1082.jpegAlbum 1082 1081.jpegAlbum 1081
11120_49e67a0ff2d8a.jpgUpload click to view 11120_49e67a195c1f0.jpgUpload click to view 11120_49e67a2307c39.jpgUpload click to view
PRO 510 in Australia
11120_49e67a2bc1a65.jpgPost 251105 11120_49e67a344a000.jpgPost 251105 5877.jpgAlbum 5877 5874.jpgAlbum 5874 5875.jpgAlbum 5875 5876.jpgAlbum 5876 5878.jpgAlbum 5878 5879.jpgAlbum 5879 6998.jpgAlbum 6998 5182.jpgAlbum 5182 3497.jpgAlbum 3497
11120_49e67a8cd5acd.jpgUpload click to view 11120_49e67a9a45c60.jpgUpload click to view 11120_49e67b447298f.jpgUpload click to view 11120_49e67f66cde6a.jpgUpload click to view 11120_49e67f87add4d.jpgUpload click to view 4114.jpgAlbum 4114 9398.jpgAlbum 9398 6915.jpgAlbum 6915
810 Swaps
Datsun 810 Bluebird
3498.jpgAlbum 3498
8154.jpgAlbum 8154 8155.jpgAlbum 8155 8156.jpgAlbum 8156 8157.jpgAlbum 8157 8158.jpgAlbum 8158 8159.jpgAlbum 8159
Swap Notes
Distributor
The FJ distributor uses Nissan Optical CAS for EFI computer signaling. See FJ CAS.
If converting to carbureted, use a standard distributor. The distributor from a Datsun A12 engine fits into the FJ20 engine block, but you need to change drive gear from A12 to FJ20 drive gear.
If the distributor is missing, use an A12 Datsun or Austin mini distributor. An A12 electronic ignition distributor is preferred so you can use the output to an aftermarket ECU.
22100 DISTRIBUTOR ASSY
R30 (8108-9003) FJ20E & FJ20T
22100-R2000 8110-8206 ハーネス L=410 MM [FJ20E only]
22100-R2007 8206-8308 ハーネス L=580 MM マイナー マ デ
22100-R2001 8308-8601 Hitachi マイナ ゴ センヨウ
22100-R2002 8601-8612 Hitachi
22100-R2003 8612-9003 Hitachi
22100-R2007 DR7 type
FJ20 timing plate
