The engine cooling fan is attached to the water pump. Datsun 1200 uses a tough plastic 4-blade fan of 310 mm diameter (12.2 inch), which are strong and not known to break. Some newer A14 used the same diameter fan but with a negative offset and was used with a spacer. Datsun 1200 used no spacer, but used a longer water pump. Some newer A-series engines used a 330mm fan with spacer. 330mm fan was Datsun 1200 OPTION FOR TROPICAL USE. Datsun 1000 used a metal 4-blade fan.
Contents[hide] |
Pulley ratio: 1.08 * Fan pulley: 129 mm * Crankshaft Pulley: 139 mm
Comparison
There are five diameter of fans for RWD A-series engines:
- Small #Steel Fan: 280 mm metal 4-blade used on Datsun 1000
- #Plastic Fan: 310 mm diameter plastic (used on A10/A12/A13/A14/A15)
- #Large Plastic Fan: 330 mm diameter plastic (also B110 OPTION)
- #Electric Fan: 320 mm diameter, steel 5-blade (some 1980-1982 B310s)
- #Thermo Fan: B310 OPTION and PB310 (A15): 350 mm diameter , 7 blades
In USA, A/C 1200s got a flexi-fan (fibreglas blades), while B210/B310 used #2 above.
Generic metal blade fan (holes slotted for different engines)
Steel Fan
Datsun B10 used a small 280mm fan, consisting of two steel blades both bolted to the pulley/hub thus making a four-blade fan assembly.
Plastic Fan
Datsun B110 standard specification は標準仕様 is a tough plastic 4-blade fan.
310 mm Plastic fan * 3.82 diameter center section * 310 mm (12.2 inch) diameter blades * 1.28" thick * bolt pattern: 1.970" * hub locating hole: 1.24" * Bolts: (4) 10mm hex head, M6x1 threads 08120-6201Fᴳ 08120-62010 BOLT 4 [20mm long] * 21069-21000ᴳ WASHER-lock 2 * flat strips that are bent up over 2 bolts
Early B110 used regular lock washers, later ones use metal strips and bent the up to lock the bolts.
310 mm fans came with these offsets:
Deep Dish Fan (B110) used with H10 long water pump: flange from back: 0.84" (20mm), from front: 0.35" (9mm). No spacer is used
Unknown Fan: flange from back: 5mm (reported)
Shallow Fan used with H72 short water pump: flange from back: 10mm, from front: about 1+". Requires spacer/adapter to match the pump bolt pattern
2007 Bakkie used the same fan
Large Plastic Fan
OPTION fan. Just like regular 310mm fan but with longer blades
21060-A4605 FAN-COOLING D=330 FOR TROPICAL USA (330 mm diameter) OP CRANK > 21060-N0100 * B110 21060-N0110 FAN-COOLING OP.COOLER 7804-8109 <x> 21060-G1210 21060-G1210 FAN-COOLING OP.COOLER 8110- 21060-H5700 FAN-COOLING (330 X 4) * B210 USA A13(1974), A14 (1974-1978) * B310 USA A14, A15 (1979-1982) * Datsun 720 * 1979-1980 Datsun C120 Vanette A12/A14 * 1986-1998 Nissan C22 Vanette A12 * 1989-1994 Nissan TC22 Vanette Truck A12/A15
NOTE * unknown if the hub offset is same for all these * A46 part number is from 1970 P510 L16 engine * N01 part number is from 1971 P510 L16 engine * G12 part number is from 1971 B120 * H57 part number is from B210 A12T (twin carb) engine
Thermo Fan
For the thermo-switched electric fan, see Electric Fan
Newer A-series engines (B310, C22, etc) -- especially those with aircon -- use a thermostatically controlled clutch fan.
350 mm diameter 21060-W5000ᴳ < 21060-W500A 7 blades * Datsun B310 OPTION * Nissan C22 Vanette A15 * Nissan C23 Serena LD23 diesel bolts to: Thermo clutch
B310 with aircon and PB310 (A15)
Thermo fan uses the short H72 water pump with no spacer
Electric Fan
Nissan items, From USA catalogs: 21060-H1001 FAN-COOLING(310 X 4) * A12 [standard B110 fan] * B210 A13 (1974) * B210 A14 GFU models * B310 A12A, A14/A15 KFU 21060-H9920 FAN-COOLING(310 X 4) A15 Manual from 018021060-A4605 FAN-COOLING D=330 FOR TROPICAL USA (330 mm diameter) OP CRANK > 21060-N0100 21060-H5700 FAN-COOLING(330 X 4) A13, A14, A15 (1974-1982) 21060-W5000 FAN-COOLING(350 X 7) (FOR AIR-CON) B310 A14, A15, OPTION JAP.A12
Spacer/Adapters B110 - no spacer 21064-H5000 SPACER-FAN A13 [looks to be a thin spacer] 21064-H7200 SPACER-FAN A14 to 0779 [thin spacer] 21064-H9900 SPACER-FAN all From 0879 [thick spacer adapter] NOTE: HB210 used B110 pulley but with thin spacer
A12A with A/C 11720-H9911 BELT-FAN(977)(FOR AIR CON) OP A12 CAL from 0879 11721-H7210,11721-H7200 BELT-FAN(970)(FOR AIR CON) FED
A14 With A/C 21082-H7200 ASSY-COUPLING,FAN FOR AIR CONDITIONER A14 to 0776 * 11721-69900 BELT-FAN FOR AIR CONDITIONER(960M M) 21082-H7201 ASSY-COUPLING,FAN FOR AIR CONDITIONER A14 0876-up * 11721-H7200 BELT-FAN FOR AIR CONDITIONER(970M M)
21082-H9920 COUPLING ASSY-FAN (FOR AIR-CON) A15 from 0180 21082-H9100 COUPLING ASSY-FAN (FOR AIR-CON) OP A14,A15(CAL) 21082-H9300 TEMP COUPLING ASSY-FAN (FOR AIR CON) OP A14,A15(FED)
