Datsun 1200 came with an ashtray in the center of the dashboard below the ventilator controls. Rear passenger ash trays were an Option.
Front
Image Search: ashtrayᴵ 画像検索: サニー B110 アッシュトレイᴵ
The front ash tray is named the "Instrument Panel Ash Tray".
Interior Colors Black 1970-1978 96500-H1000 Blue 96500-H2600 PB110 GL option Brown 96500-H2700 PBB10 GX option Brown 96500-G1060 1978.04 to 1989.10 Gray 96500-95W00 1989.10 to 1994.3 NOTE: Sedan, Coupe, Van, Truck same part number including 1972 facelift models and PB110 fixing ash tray 08510-70112 SCREW 3 08915-43710 WASHER-plain 1 08913-10710 NUT-lock 3
The tray may be re-colored with vinyl spray paint.
PB110 Sunny Excellent 1400
New
Buy from Bprojects
B210 front ash tray looks similar. However, the upper piece is very different.
B110 two side-fastening screws B210 two front-fastening screws
26738A 26261-89905 BULB 7702- FOR ASHTRAY LAMP 68196 68425-H7416 BRACKET A 7702- FOR ASH TRAY 68425C 68425-H5000 GROMMET-SCREW 96501 ASHTRAY-INSTRUMENT 96500-H5000 BLACK -7701 96500-H5900 GB211 (Brown) 96500-H7400 Black 1977.2- 96500-H7401 Black 1977.2- with Illumination 96500-H7900 Brown 1977.2- with Illumination GB211 96501A 01451-00191 SCREW 3
Rear
Deluxe B110s came with one of these in the back seat area (below the side window). Two are fitted — one on each side — except for STD sedan and STD van 4-door which only have one. B210 & B310 used the same ashtrays.
96502-H1001 ASSY-ASH TRAY, REAR 2 (1 STD, except Van 2-door) * B110, including PB110 * B210 * B310 08520-51210 SCREW (fixing ash tray, one per ashtray)
The same rear ashtrays were used by Sedan, Coupe and Van.
These were fitted to the interior side trim (2-door sedan, 2-door coupe) or to the rear door cards (4-door models).
4-door sedan - rear door card (ドア内張)
2-door sedan - rear inside trim
アッシュトレイ
