Idler Arm
Revision as of 15:31, 9 March 2025; view current revision
Category: Steering System
The Idler Arm is part of the Steering Linkage, and is the counterpoint to the Steering Gear Arm.
The idler arm has replaceable #bushings. When these wear out it causes the infamous double-knock sound when going over bumps.
The Idler Arm bolts to the subframe rail on opposite side from the steering gearbox.
Steering_Linkage: #1 Idler Arm
4932.jpgAlbum 4932
The bolts go through the Front Side Member (front chassis rail).
4It fastens to the chassis via two long bolts.
48530-H1000_d.jpg 48530-H1000_e.jpg 24332.jpgAlbum 24332
RHD
RHD Idler Arm is the same for all 1200s: ute/wagon/sedan/coupe — even the 1994 Sunny Truck uses the same part number.
48530-H1000 1970-1994
48530-H1000_1A.jpg 48530-H1000_1B.jpg 22793.jpgAlbum 22793
555 was original OEM
48530-H1000_c.jpg 48530-H1000_555a.jpg 48530-H1000_555b.jpg 48530-H1000_555c.jpg
LHD
LHD assembly part number differs from RHD. All the sub-parts (including the arm crank) are the same. However, the bracket looks like the RHD part turned upside down.
24331.jpgAlbum 24331
Idler Arm LHD
* 48530-H1600 ASSY-IDLER STEERING [LHD]
* RockAuto.com
* TRW 18778 through 7/72
Bushing
The same bushing set is used by RHD and LHD.
Nissan Retail Price: $8.25 (2016 prices)
26304.jpgAlbum 26304
Idler Arm Bushing
* 48544-H1000 BUSH-IDLER
* Beck/Arnley 1013851 (2 per idler arm) at http://rockauto.com
Fits:
** Mitsubishi/Chrysler 1983-1993 various models
** Nissan B110, B310, S110, 1979-1981 S130, A10, 1980-1982 720, 1977-1980 810
Idler Arm Repair Kit (includes 2 bushes, washer & lock nut)
* Raybestos 4501067
* ACDelco 45C1067 or 88911321 $8.41
Rockauto.com
7181.jpgAlbum 7181
Comparison
B10 vs 1200 vs 510
48530-18001 RHD Datsun 1000
48530-21000 RHD
PB110(L14)
PB210(L14),GB210(L16)
510/610 Bluebird
710 Violet
S10 Silvia
ステアリング アイドラ アーム
