60-Series Transmission Parts
Revision as of 13:57, 4 May 2025; view current revision
Category: Transmission
Parts for 60-Series Transmissions are listed below. This includes 4-speeds and 5-speeds from B210 and B310 vehicles. The only non-dogleg 5-speed that Datsun used for A-series engines is the 60A (FS5W60A). The B310 dogleg 5-speed for A14/A15 is the 60L (FS5W60L).
Part Number Prefixes
The applied model part of the Part Number indicates the original use of the part. You'll find that several parts of the 60 gearboxes were originally used by the 56 gearboxes (180 parts), but that many parts are unique (H73 parts).
AMC  MODEL GEARBOX
180 B10 56-series
H73 B210 60-series 4-speed
H90 B310 FS5W60L
H97 B310 FS5W60A
Rebuild Kit
O'Reilly Auto Rebuild Kits
PowerTorque BK173WS w/synchros $254 USD 60A
PowerTorque BK173 w/o synchros $146 USD 60A
PowerTorque BK139 $144 USD F4W60
Timken Rebuild Kits
TRKFN320 F4W60
TRKFN330 FS5W60A
TRKFN340 FS5W60L
Bearing Kit
25681.jpgAlbum 25681
Synchro Kit adds includes five (5) brass BAULK RING. See Synchros
25679.jpgAlbum 25679
Dogleg 5-speed
FS5W60L - dogleg 5-speed
BALL BEARINGS
(1) 32203-H7300  input shaft   Type 206
(1) 32273-H7300  main shaft    Type 305
(1) 32227-H9000  main shaft    Type 205
NEEDLE ROLLER BEARINGS
(1) ? 32219-H9000 cluster shaft, front ?
(?) 32219-H9702 cluster shaft, end
SEALS
(1) 32112-H7300 O-ring input shaft
(1) 32114-Y4000 seal   input shaft
(1) C2136-H5000 seal   output shaft
Non-dogleg 5-speed
FS5W60A - non-dogleg 5-speed
BALL BEARINGS
(1) 32219-H8900  cluster shaft Type 304
(1) 32227-H9700  main shaft    Type 62/22
(1) 32219-H9700 cluster shaft
(1) 32227-H9700 output shaft, rear
SEALS
Bearing Code example: 6206N C3
6 Type = Single-Row Deep Groove Ball Bearing
2 Series = Light duty
06 Bore = 6 x 5mm = 30mm inside diameter
N  = groove
NR = groove and snap-ring
Z  or L  = shielded on one side
ZZ or LL = shielded both sides
D  or RS  = sealed on one side
DD or 2RS = sealed both sides
C3 = clearance greater than normal
20677_56a70a2c20630.jpgPost 475807 20677_56a70a4f2a608.jpgPost 475807
FS5W60L
Parts specifically designed for the 60L use Applied Model Code H90. The 60L also uses a few H73 parts (4-speed parts) such as the main drive input shaft/gear and the bushings, bearings and spacers.
H90     designed for B310 Coupe 1400 & 1500
The 60L 5-speed is unique:
  • The design is a modified 4-speed. 5th gear is added to the front, 1st gear moved to the back. In actuality it uses only a few actual parts from the 4-speed.
  • The newer 60A is a re-designed gearbox, sharing less of the design with the 4-speed
28803.jpgAlbum 28803 26274.jpgAlbum 26274 26275.jpgAlbum 26275
Reverse GEAR/HUB on end of output shaft
(large 1st gear below, small rev/idler gears to right)
26276.jpgAlbum 26276 13609.jpgAlbum 13609
Compared to the 4-speed, reverse is moved further out the shaft and 1st gear placed between REV gear and the adapter plate
174_5c74cc79b5219.jpgPost 490671 174_5c74cc8aca472.pngPost click for topic
Gearset
28801.jpgAlbum 28801
32228M 32228-H9000 RING-SNAP OVERDRIVE BEARING (2)
32230  32230-H9000 GEAR ASSY-1ST
32234  32234-H9000 RETAINER SHIFTING INSERT [incorrect? looks like a washer]
32241  32241-H9001 SHAFT-MAIN
32245  32245-H9000 GEAR-REVERSE, MAIN SHAFT
32246  32246-H7300 WASHER-THRUST
32250  32250-H9000 GEAR ASSY-2ND
32253  32253-H7300 BUSH-1ST GEAR (MAIN SHAFT) (2)
       28802.jpgAlbum 28802
32354  32354-H9000 NUT-HEX (M25 X 1.0)
32258B 32258-H9001 HUB SYNCHRONIZER-1ST & REVERSE
32260  32260-H9000 GEAR ASSY-3RD 27T
32264  32267-H7300 BEARING-(NEEDLE,) MAIN SHAFT
32264M 32264-H7300 BEARING-NEEDLE MAIN SHAFT (2)
32601B 32601-H9001 HUB SYNCHRONIZER-2ND & 3RD
32602  32602-32200 SPRING-SHIFTING INSERT (SYNCHRONIZER INSERT) 3
32603  32603-18000 RING-SYNCHRONIZER (4)
32604  32604-H9000 RING-BAULK (4)
32606  32606-18000 SLEEVE-COUPLING (2)
32608  32608-H9000 INSERT-SHIFTING (9)
32609  32609-18000 INSERT-SHIFTING (6)
32273  32273-H7300 BEARING-(BALL,) MAIN SHAFT
32275  32227-H9000 BEARING-MAIN SHAFT
28800.jpgAlbum 28800
32200  32200-H7300 GEAR ASSY-MAIN DRIVE
32203  32203-H7300 BEARING-MAIN DRIVE
32203E 32214-H7300 RING-MAIN BEARING (2)
32204  32204 Select one RING-SNAP MAIN DRIVE GEAR
32205  32209-H7300 SPACER-BEARING MAIN DRIVE GEAR
32210  32210-H9000 GEAR-COUNTER ASSY
32219  32219-H9000 BEARING-COUNTER SHAFT [Also F460A 7812-]
32219M 32219-H9010 BEARING-COUNTER SHAFT
32220  32220-H9000 GEAR-REVERSE COUNTER
32221M RING-SNAP COUNTER SHAFT select one
       32222-H9003 SELECT T=1.3
       32222-H9004 SELECT T=1.4
32224  32224 Select one WASHER-THRUST COUNTER SHAFT FRONT
32225  32284-H9000 WASHER-THRUST COUNTER SHAFT REAR
32263  32263 RING-SNAP Select one
32272  32272-H7300 BEARING-PILOT MAIN SHAFT (3)
32281  32281-H9000 SHAFT-REVERSE IDLER
32281G 32292-14600 PIN-RETAINING [Also F560A]
32282  32282-H9000 GEAR-REVERSE IDLER
32283  32272-H7300 BEARING-REVERSE IDLER GEAR (2)
32285M 32285-H9000 SPACER-REVERSE IDLER GEAR
32285N 32284-N9000 WASHER-THRUST REVERSE IDLER (2)
32340  32340-H9000 GEAR ASSY-OVERDRIVE
32350  32345-H9000 BEARING-OVERDRIVE GEAR (NEEDLE MAIN SHAFT)
32605B 32601-H9000 HUB SYNCHRONIZER-4TH & 5TH [FS5W60L, 60A]
Bearings
60L 5-speed Bearings/Bushings Buy at RockAuto.com
25684.jpgAlbum 25684
BALL BEARING 32203-H7300 input shaft (main drive)
62x30x11 mm Type 206
25682.jpgAlbum 25682 28806.jpgAlbum 28806
BALL BEARING 32219-H8900 counter shaft, rear
20x52x15 mm Type 304
28807.jpgAlbum 28807
BALL BEARING - MAIN SHAFT, MID
* 32273-H7300
BALL BEARING - MAIN SHAFT END
* 32227-H9000
ENCLOSED BEARING - counter shaft, front
* 32219-H9702 [32219]
NEEDLE CAGE - pilot bearing
* 32272-H7300
32264M BEARING-NEEDLE MAIN SHAFT $38.43 USD
* 32264-H7300
 Rear 60A
 National B1616
 * Cone Bore: 25.400mm, 1.00 inch
 * Outside Diameter: 31.750mm, 1.250 inch
 * Width: 25.400mm, 1.00 inch
28808.jpgAlbum 28808
NEEDLE CAGE -  output shaft, rear
32350 BEARING-overdrive gear
* 32345-H9000 60L 5-speed
* 32345-H9702 60A
32283  32289-H9701 > 32289-H9700 BEARING-REVERSE IDLER GEAR $28.60 USD
* 60L 5-SPEED (2)
* 60A 5-SPEED (1)
FS5W60A
Parts specifically designed for the 60A use Applied Model Code H97. However, the 60A also uses some H73 parts (4-speed parts).
H97     designed for 1980 B310 1400 & 1500
60A 5-speed Gearset
Reverse/idler and overdrive
main shaft gearset
Input shaft, Counter shaft, Reverse/Idle shaft
  00922-12200 SNAP RING
32200  32200-H9700 GEAR ASSY-MAIN DRIVE
32203  #32203-H7300 BEARING-MAIN DRIVE
32204  32204-H7300 RING-SNAP MAIN DRIVE GEAR
            SELECT 1.34-1.76 THICK
32210  32210-H9700 GEAR ASSY-COUNTER
32210A 32225-H9700 NUT
32219  #32219-H9700 BEARING-COUNTER SHAFT
32219M #32219-H7300 BEARING-COUNTER SHAFT
32220  32220-H9700 GEAR-REVERSE COUNTER
32222  32348-H9710 RING-SNAP 2
32224  32224-H702X WASHER-THRUST COUNTER SHAFT FRONT
            SELECT 2.30-2.25 THICK
32228  SELECT: RING-SNAP OVER DRIVE BEARING
       32351-H9700 T=1.72
       32351-H9701 T=1.78
32228M 32228-H9000 RING-SNAP OVER DRIVE BEARING
32230  32230-H9700 GEAR ASSY-1ST
32241  32241-H9703 SHAFT-MAIN
32241G 32720-14600 BALL-STEEL
32241H 32288-H9700 RING-SNAP
32245  32245-H9700 GEAR-REVERSE MAIN SHAFT
32246M 32246-H9700 WASHER-THRUST MAIN SHAFT
32250  32250-H9700 GEAR ASSY-2ND
32253  32253-H7300 BUSH-1ST GEAR 2
32264  #32267-H7300 BEARING-MAIN SHAFT 2
32264M #32264-H7300 BEARING-MAIN SHAFT 2
32273  #32273-H7300 BEARING-MAIN SHAFT
32275  #32227-H9700 BEARING-MAIN SHAFT
32285  32349-H970x SELECT: RING-SNAP T=1.46-1.78
32340  32340-H9700 GEAR ASSY-OVERDRIVE 18T
32350  #23245-H9000 BEARING-OVERDRIVE GEAR
32351  32350-H9700 HOLDER-C RING
23252  32347-H970x WASHER SELECT T=7.87-7.80
32260  32260-H9700 GEAR ASSY-3RD
32263  32268-H730x RING-SNAP
            SELECT 1.60-1.70 THICK
32264M #32264-H7300 BEARING-NEEDLE MAIN SHAFT
32272  #32272-H7300 BEARING-PILOT
32281  32281-H9700 SHAFT-REVERSE IDLER
32282  32282-H9700 GEAR-REVERSE IDLER
32283  #32272-H9700 BEARING-REVERSE IDLER GEAR
32285N 32285-H9000 SPACER-REVERSE IDLER
32285P 32286-H9700 SPACER-REVERSE IDLER
32287  #32265-18000 WASHER-THRUST REVERSE IDLER
32310  32215-H9700 GEAR-OVERDRIVE COUNTER
32318  32287-H9700 WASHER-THRUST
32601  32601-H7301 HUB-SYNCHRONIZER B
32601A 32601-H7300 HUB-SYNCHRONIZER 1ST & 2ND
32605B 32601-H9000 HUB-SYNCHRONIZER 3RD & 4TH
32603  32603-18000 RING-SYNCHRONIZER 4
32604  32604-H9000 RING-BAULK 4
32606  32606-18000 SLEEVE-COUPLING 3
32608  32608-H9700 INSERT-SHIFTING 3
32609  32609-M0102 INSERT-SHIFTING 6
32701B 32720-17600 BALL
Output shaft
1st, 1-2 hub, 2nd
Reverse/Idler Gears
60a-reverse.jpg 60a-reverse-1.jpg 60a-reverse-2.jpg 60a-rev-1.jpg 60a-rev-2.jpg
5th gear bolted to end of cluster shaft
Cluster shaft and free-gears (1st, 2nd, 3rd)
32604-H9700 Synchro BAULK RING & matching gear surface
Input Shaft Bearing
BALL BEARING-MAIN DRIVE (Input shaft)
30x62x16 Type 206
* 32203-H7300
Reverse/Idler Bearing
This bearing fits into the extension housing.
32319-0H700 > 32231-E9000 BEARING-REVERSE IDLER GEAR FS5W60A [32283N] $15.83 USD
16x22x16
* NTN HK1616
* Needle Roller Bearing, Caged Drawn Cup
APPLICATIONS
* FS5W60A reverse/idler
* 71-Series Transmission cluster shaft
Output Shaft Bearing
BALL BEARING - MAIN SHAFT (Output shaft, mid)
25x62x17
* Nissan 32273-H7300
BALL BEARING - MAIN SHAFT (Output shaft, rear)
22x50x14
* Nissan 32227-H9700 [32275]
NEEDLE BEARING - PILOT (input shaft)
18x24x17 mm
* 32272-H7300
NEEDLE BEARING - MAIN SHAFT
* Nissan 32264-H7300 (2) [32264M]
* 32267-H7300 (2) [32264]
NEEDLE BEARING - OVERDRIVE GEAR (input shaft, 5th gear)
* Nissan 32345-H9702 [32350]
32227-H9700
22x50x14
* Nachi 62/22XA1 140827 (22x50x14 ball bearing)
Cluster Bearings
60A 5-speed COUNTER Bearings/Bushings
25683.jpgAlbum 25683
32219 BEARING-COUNTER SHAFT
* #32219-H9700
32219M BALL BEARING-COUNTER SHAFT
* #32219-H7300
32224 WASHER-THRUST COUNTER SHAFT FRONT
* #SELECT USE T=2.30 - T=2.25
32283 BEARING-REVERSE IDLER GEAR
* 60L 5-SPEED (2)
* 60A 5-SPEED (1)
32287 WASHER-THRUST REVERSE IDLER
32265-18000
* F4W56
* FS5W60A
Shift Control
Reverse Checking
16289_52e3aa8d39eb9.jpgPost 450686 16289_52e3c862487b3.pngPost 450692
60A_SHIFT_CONTROL_A328B_140.png GC22.KA24.5F (71C series)
REVERSE CHECKING PARTS
00922-50600 WASHER [per H30 catalog]
08110-61462 BOLT (2)
32180-E9800 REVERSE CHECKING ASSEMBLY
32180H 31933-20300 O-RING
32181-E9800 SLEEVE
32183-E9801 CAM
32184-E9800 SHAFT SET-CAM
32185-E9800 SPRING
The B310 catalog has these parts confused
60A_SHIFT_CONTROL_c.png B310.FS5W60A
Striking Rod Guide
SHIFT LEVER PARTS
* See Shifter Part Numbers
STRIKING ROD GUIDE PARTS
08912-30610 NUT
00933-32800 PLUG
32847-H7300 PIN-STOPPER 60.F4+F5
32850-H9701 GUIDE-STRIKING ROD
32850B 32848-24900 RING-O 56A,60.F4+F5
32850H 32858-U6702 RING-O STRIKING ROD
32851-24900 PLUNGER 56A,60
32852-24901 SPRING-RETURN 56A,60
32853-24900 PLUG-RETURN SPRING 56A,60A,60L.7812-
Striking Rod
STRIKING ROD PARTS
08911-20610 NUT
08915-53610 PLAIN WASHER
08915-13610 LOCK WASHER
32890 STRIKING ROD
  32892-H9700 A13 8011-
              A15 -8010
  32892-H9701 A15 8011-
32896-H9700 STRIKING LEVER
32917-H7200 LOCK PIN 60.4SPD+5SPD
Fork Rods
See also: Shift Forks
00911-11400 RING (2)
32292 PIN-RETAINING
  32293-H9700 L=24 (2) 8011-
  32292-73200 L=21 (3) 8011-
32382-H9700 BRACKET-REVERSE & OVERDRIVE
32801M 32801-H9700 ROD-FORK 1ST & REVERSE
32805M 32819-H9700 FORK-SHIFT 1ST & REVERSE
32809M 32801-H9700 ROD-FORK 2ND & 3RD
32809P 32809-H9700 ROD-FORK 4TH & 5TH
32811M 32805-H9700 FORK-SHIFT 2ND & 3RD
32811P 32805-H9700 FORK-SHIFT 4TH & 5TH
32813-H9700 BRACKET-SHIFT ROD A
32815 32832-18000 PLUNGER-INTERLOCK 56A,60
32829-26760 BALL-CHECK 56A,60
32830-18000 SPRING-POPPET 56A,60
32834-18000 PLUG-CHECKING BALL 56A,60
32835 32834-H7300 PLUG-CHECKING BALL
Shaft Assembly
The main shaft is stepped in diameter to allow assembly of the bearings and splined hubs. Starting from front of shaft, is the largest bearings, going on down in diameter
20677_578d4bc8c77b3.jpgPost click for topic
MAIN SHAFT HUB SIZES & GEAR BEARING SIZES
32601  H7301 3-4 splined hub
32264M H73   3rd gear needle bearing 28.95 mm I.D.
32264M H73   2nd gear needle bearing 28.95 mm I.D.
32601A H73   2-1 splined hub
32264 67-H73 1st gear needle bearing
32273 H73 25mm mid-shaft ball bearing (at sandwich plate)
32264  H73   REV gear needle bearing
32605B H90   splined hub
32350  H90   5th gear needle bearing 22.21 mm I.D.
32275 H97 22mm end-shaft ball bearing
The space is where the mid-shaft bearing goes
20677_578d4bd52673b.jpgPost 479959
F4W60L
Parts specifically designed for the 60L 4-speed use Applied Model Code H73. This gearbox also uses a few 180 parts (56-series parts)
H73     designed for B210 from July 1974
Ratios
rally cross of F4W60L Gear ratio
* 1st: 3.19
* 2nd: 2.38
* 3rd: 1.89
* 4th: 1.00
F4W60 gears - B210 USA CATALOG
32200-H7300 ASSY-GEAR MAIN DRIVE 20T
32210-H7300 GEAR-COUNTER 31-27-20-15T
32220-H7300 GEAR-REVERSE COUNTER 14T
32230-H7300 ASSY-GEAR 1ST SPEED 34T
32250-H7300 ASSY-GEAR 2ND SPEED 28T
32260-H7300 ASSY-GEAR 3RD SPEED 24T
32280-H7300 ASSY-GEAR REVERSE IDLER 22T
32245-H7300 GEAR-REVERSE MAIN SHAFT 34T
Main Drive Gear
32200  32200-H7300 GEAR ASSY-MAIN DRIVE 20T [F4W60L,FS5W60L]
32203E 32214-H7300 RING-MAIN BEARING [all 60]
32205  32209-H7300 SPACER-BEARING MAIN DRIVE GEAR [all 60]
174_5c491154107c1.jpgPost 490420 174_5c491190818af.jpgPost 490420
Counter Gear
00922-12000 RING
32210  32210-H7300 GEAR ASSY-COUNTER
32219M BEARING-COUNTER SHAFT
       32219-H7300 -8010
       32219-H8900 8110-
32220  32220-H7300 GEAR-REVERSE COUNTER 14T
       SELECT USE
Reverse Idle Gear
00022-11800 RING (2)
32281-H7300 SHAFT-REVERSE IDLER
32282-H7300 GEAR-REVERSE IDLER
Main Shaft
32230  32230-H7300 GEAR ASSY-1ST 34T
32241  32241-H7300 SHAFT-MAIN
32241H 32204-18000 RING-SNAP
32245  32245-H7300 GEAR-REVERSE MAIN SHAFT
32246  32246-H7300 WASHER THRUST
32246M 32205-H7300 WASHER-THRUST MAIN SHAFT
32250  32250-H7300 GEAR ASSY-2ND 28T
32253  32253-H7300 BUSH-1ST GEAR [all 60]
32260  32260-H7300 GEAR ASST-3RD 24T
32263  RING SNAP select one
32264M 32264-H7300 BEARING-MAIN SHAFT (2)
32273  32273-H7300 BEARING-MAIN SHAFT
32601A 32601-H7300 HUB-SYNCHRONIZER 1ST & 2ND [all 60]
32603  32603-18000 RING-SYNCHRONIZER (6) [56,60]
32604  32604-H9000 RING-BAULK (4) [56, 60L]
32605A 32601-H7301 HUB-SYNCHRONIZER
32606  32606-18000 SLEEVE-COUPLING (2) [56,60]
32609  32609-18000 INSERT-SHIFTING (6) [56,60L]
NRRT gear set
RACE & RALLY TECHNOLOGY (NRRT) B10 ダートトライアル?用 crossmission TRANSMISSION GEAR SET for 4W60L
32200-NR100 set
32210-NR100 counter gear
32230-NR100 1st 33-tooth
32250-NR100 2nd 29-tooth
32260-NR100 3RD 28-tooth
1st 3.19 3.51
2nd 2.39 2.17
3rd 1.89 1.37
4th 1.00 1.00
Rev 3.76 3.76
174_5caa7050cc054.jpgPost 491128 174_5caa705e39b24.jpgPost 491128
Seals
Front Cover O-ring and Seal
  • The three welch plugs are not normally replaced or even removed
26283.jpgAlbum 26283
Front Cover O-ring
32112M  32112-H7300 RING-O FRONT COVER
APPLICATIONS:
* F4W60
* F5W60L
* F6W60A
* NOTE: 56-series differs
Front Cover Seal
Front Cover Oil Seal for Aichi R4W60L/W60 4-speed, W60L/W60A 5-speed, RS5W60R 5-speed
Nissan 32114-Y4000
* A12/A14/A15,KA20DE/KA24E/KA24DE,TD23/TD25/TD27,NA20
* RD28,RB20,L18/LD20/L20,H20,Z18/Z20,VG20/VG30,FJ20,CA18
* 60-series, 71-series 71B/71C
Specs
* shaft size: 30 mm
* bore size: 45 mm
* seal outer diameter: 45.2 mm
* seal width: 8 mm
* Polyacrylate or Nitrile
RockAuto
TCM 30X45X 10TC-BX
National 1981
Timken 1981
Fits:
* Nissan 32113-Y4000, 32114-20100, 32114-Y4000
* 8942152200
* 8943270620, 8943270621, 8943348450, 8943895931
* 9004310029, 9004311141, 9031130010, 9031130014
* 9031130115, 94215220, 94327062
* Ford EBTZ7052D
* Toyota W55 transmission
* Isuzu 8943270620 camshaft seal
Output Shaft
32150-H7300 4-speed 8110-
4-speed & 5-speed RockAuto.com
* Nissan C2136-H8900 > 32136-H8900 $10.00 USD
* Nissan C2136-H5000 > 32136-H5000 OIL SEAL-REAR EXTENSION $23.87 USD
* Timken 2016
* SKF 11619 (also says it replaces 32136-G1001)
FITS
* 56A,60A,60L
SPECS
* Material        Nitrile
* Shaft Size      1.181" 30mm
* Housing Bore    1.772" 45mm
* Outer Diameter  1.78"  45.2mm
* Flange Diameter 2.441" 62mm
* Width           0.591" 15mm
Snap Rings
32228
32228M
FS5W60L
32228-H9000 RING-SNAP OVER DRIVE BEARING (2)
FS5W60A
32228-H9000 RING-SNAP OVER DRIVE BEARING (1)
        32351-H9700 T=1.72
        32351-H9701 T=1.78
32263
5-speeds 60A & 60L (FS5W60L & FS5W60S)
* 32268-H9000 RING-SNAP SELECT T=1.60
* 32268-H9001 RING-SNAP SELECT T=1.65
* 32268-H9002 RING-SNAP SELECT T=1.70
32204
RING-SNAP MAIN DRIVE GEAR Select only one
* 32204-H7300 RING-SNAP MAIN DRIVE GEAR SELECT T=1.34-1.40
* 32204-H7301 RING-SNAP MAIN DRIVE GEAR SELECT T=1.40-1.46
* 32204-H7302 RING-SNAP MAIN DRIVE GEAR SELECT T=1.46-1.52
* 32204-H7303 RING-SNAP MAIN DRIVE GEAR SELECT T=1.52-1.58
* 32204-H7304 RING-SNAP MAIN DRIVE GEAR SELECT T=1.58-1.64
* 32204-H7305 RING-SNAP MAIN DRIVE GEAR SELECT T=1.64-1.70
* 32204-H7306 RING-SNAP MAIN DRIVE GEAR SELECT T=1.70-1.76
Thrust Washers
32287  32265-18000 WASHER-THRUST REVERSE IDLER [center]
32318  32287-H9700 WASHER-THRUST [REVERSE IDLER, rear]
32285N 32283-H9700 WASHER-THRUST REVERSE IDLER [front]
Used by all 60-series gearboxes
       SELECT USE
       32224-H7200 T=2.30-2.35
       32224-H7201 T=2.35-2.40
       32224-H7202 T=2.40-2.45
       32224-H7203 T=2.45-2.50
       32224-H7204 T=2.50-2.55
       32224-H7205 T=2.55-2.60
       32224-H7206 T=2.25-2.30
       32224-H7207 T=2.20-2.25
Sandwich Plate
32137-H7300 F4 -8010
32137-H7301 F4 8011-
32137-H9000 60L
32137-H9700 60A
With mainshaft center bearing dropped in place + reverse/idler shaft fitted
60A
Case Comparo
B210 F4W60A
* 32100-H7300 ASSY-CASE,TRANSMISSION B210 F4W60A 0974-0776
* 32100-H7302 ASSY-CASE,TRANSMISSION B210 F4W60A 0876-0377
* 32100-H8902 ASSY-CASE,TRANSMISSION B210 F4W60A 0477-
B310 F4W60
* 32100-H8902 CASE COMP-TRANSMISSION B310 F4W60 CANADA
* 32100-H8903 CASE COMP-TRANSMISSION B310 F4W60 0879- USA
* 32100-H9301 CASE COMP-TRANSMISSION B310 F4W60 0879- USA (supercedes 32100-H8903)
B310 FS5W60A
* 32100-H9001 CASE COMP-TRANSMISSION B310 FS5W60A -0779 [FS5W60L, dogleg]
* 32100-H9300 CASE COMP-TRANSMISSION B310 FS5W60A 0879- CAN (supercedes 32100-H9001)
* 32100-H9301 CASE COMP-TRANSMISSION B310 FS5W60A 0879- FED, CAL (supercedes 32100-H9001)
Extension Housing
32160- many EXTENSION ASSY-REAR
Factory Service Manual says:
If rear extension bushing is worn or cracked, replace it as an assembly of bushing and rear extension
Bearings
In addition to the bearings listed for each transmission, here are details on some of the bearings.
32272-H7300
NEEDLE CAGE bearing
* 32272-G3201 > 32272-H7300
18x24x17 mm needle roller bearing
* Nissan 32272-H7300 BEARING-PILOT 32272-G3201 $26.02 USD > 32272-14600
* Koyo RS18/17P
APPLICATIONS
* FS5W60L (1) pilot bearing (2) reverse idler gear
* FS5W60A input shaft pilot bearing
* F4W60L pilot bearing
32267-H7300
* for 22.2 mm shaft
* ?R29/28AP
APPLICATIONS
* 60A fifth gear
32264-H7300
32264-H7300 BEARING-NEEDLE MAIN SHAFT $38.43 USD
* for 29.5 mm shaft
* ?Koyo VP29/28P
APPLICATIONS
* FS5W60L main shaft (2)
* FS5W60A main shaft (2) 3rd, 2nd
32219-H9700
* Nissan 32219-H9702 > 32219-H9700 BEARING-COUNTER SHAFT, FRONT $22 USD
* enclosed needle roller bearing
* NTN 7E-BKS-20X32X20-4 181410 DRAWN CUP NRB CLOSED END (CAGE TYPE needle)
APPLICATIONS
* FS5W60A
* FS5W60L
32203-H7300
BALL BEARING - input shaft (main drive)
62x30x11 mm
* Nissan 32203-H7300 BEARING-MAIN DRIVE $31.78 USA
* Timken 206L
* SUZUKI 08163-62063
* SKF 6206ZNRJ
* Nachi 6206N C3
SPECS
* Inside Diameter: 30 mm, 1.1811 in
* Outside Diameter: 62 mm, 2.4409 in
* Width: 16 mm, 0.6299 in
* C3:radial clearance greater than Normal
APPLICATIONS:
* FS5W60L 5-speed input shaft
* FS5W60A 5-speed input shaft
32219-H7300
32219-H7300 BALL BEARING-COUNTER SHAFT
Type 304WB
Replaced by 32219-H8900
APPLICATIONS
* FS5W50A
* F4W60L -8010
32219-H8900
BALL BEARING - counter shaft, rear
* Nissan 32219-H8900 BEARING-COUNTER SHAFT, REAR $95.28 USD
* Nachi 6304N
* Timken 304WB
* National 304
* Nachi 6304N CE 150525
* NTN 6304N
SPECS
* Bore  20mm, 0.787"
* OD    52mm, 2.047"
* Width 15mm, 0.591"
APPLICATIONS
* FS5W60L
* FS5W60A
* F4W60L
32273-H7300
BALL BEARING - Main Shaft (Output shaft, middle)
25x62x17 Type 305
* Nissan 32273-H7300 BEARING-(BALL,) MAIN SHAFT, MID
* NSK 6305NR
* SKF 43305C
* Nachi 6305 N C3 150314
* Timken 305L
APPLICATIONS
* FS5W60L
* FS5W60A
* F4W60
* F4W56A
32227-H9000
BALL BEARING - Main Shaft end
25x52x15 Type 205
* Nissan 32227-H9000 BEARING-(BALL,) MAIN SHAFT END
* Timken 205S
* Nachi 6205
APPLICATIONS
* FS5W60L
Straight-cut Gears
Straight-cut gears are not as strong as the quiet-mesh gears, but are more efficient (use less power, so more power gets to the wheels) and most importantly takes the side-torque off the geartrain, so it's easier on the case.
Hybrid conversion
7488.jpgAlbum 7488
FS5W60A Factory Service manual PDF - http://032516d.netsolhost.com/transmission_book_300dpi.pdf&nbsp;&nbsp;
