The Differential must be adjusted to specifications when changing the bearings, the Ring & Pinion (Crown Wheel & Pinion) or when rebuilding it. Yet, in USA and Australia it is faster and less expensive — and more reliable — to replace with a good used differential than it is to rebuild one. Many rebuilds have not turned out well. However, if you are good with detail, have the proper measuring tools, or use an expert mechanic a rebuild can be done.
Contents[hide] |
NOTE: "pinion bearing adjust spacer" (crush sleeve) is NLA, yet needed for a proper rebuild — even for just changing the gears.
Side Bearing Shims
The Ring and the Pinion are both marked with variation numbers. These are A, B, C, D and H' in the figures below. The numbers are used to calculate the shim selections. After assembly, the gear backlash is measured with a micrometer, and if necessary, shims are moved from side to side to bring the backlash into specification.
Setting and adjusting side bearing shims
1. Place an approximately 2.5 kg (5.5 lb) weight on the side bearing, and measure bearing thickness
Standard side bearing width: 17.5 mm (0.689 in)
Note: With the weight placed on the side bearing, turn the bearing two to three turns, and measure thickness.
ST3250S000 Fig. PD-25 Measuring for bearing
2. Side bearing adjusting shim thickness calculating formula
Left side (drive gear side) T1=(A-C+D-H')× 0.01 +0.2 + E (mm) Right side (pinion mate side) T2=(B-D+H)×0.01+0.2+F (mm)
Figures for A, B, C, D and H' are dimensional variations in a unit of 1/100 mm against each standard measurement. Where A = The figure marked on the left side bearing housing of gear carrier. B = The figure marked on the right side bearing housing of gear carrier. C&D = The figure marked on the differential case. E&F = These are differences in width of left or right side bearing against the standard width 17.5 mm (0.6890 in). Figure is given in a unit of 1/100 mm.
Fig. PD-26 Thickness of shim on left side Thickness of shim on right side
H' = The figure marked on the ring gear.
Example of calculation
A=1 B= 2 C=- 2 D=3 E=+0.02 mm F =- 0.01 mm H' =+1
Left side
T1=(1-2+3-1)×0.01+0.2+0.02= 0.23 mm
Right side
T2=(2-3+1)×0.01+0.2-0.01=0.19 mm
Apply a 0.23 mm shim and 0.19 mm shim respectively to the left and right, and fit the side bearing using Differential Side Bearing Drift ST33220000.
Side bearing adjusting shims Thickness mm (in) 0.05 (0.0020) 0.07 (0.0028) 0.10 (0.0039) 0.20 (0.0079) 0.50 (0.0197)
3. Install the differential case assembly, together with the side bearing outer race, on the final drive housing.
Note: Be careful not to confuse the right and left sides of the side bearing housing.
4. Install the bearing cap, and tighten the installation bolt to the rated tightening torque.
Bearing cap tightening torque: 5 to 6 kg-m (36.2 to 43.4 ft-lb)
Note: Be sure to align match mark put before disassembly correctly.
5. Measure "L" dimension (between left and right bearing cap edges) by a micrometer.
"L" dimension: 153.40 to 153.55 mm (6.0394 to 6.0453 in)
6. Upon completion of reassembly, measure drive pinion/ring gear backlash. When backlash is less than the rated value, move the side bearing adjusting shim from the left side (ring gear side) to the right side. When backlash is more than the rated value, move the side bearing from the right to left contrarily.
Backlash: 0.10 to 0.15 mm (0.0039 to 0.0059 in)
Fig. PD-28 Measuring backlash
7. Existence of foreign matter between the drive gear and differential case is considered when backlash fluctuates considerably. Measure drive gear back deflection.
8. Check the run-out of ring gear side is within 0.05 mm (0.0020 in) total indicator reading.
Fig. PD-29 Measuring run-out of ring gear
9. When run-out of ring gear is normal and fluctuation of backlash is considerable, replace the gear set. Before replacing the gear set, be sure to measure companion flange deflection. Fluctuation of backlash may be considerable due to deflection of pinion bearing.
Limit of deflection: A portion: Less than 0.05 mm (0.0020 in) B portion: Less than 0.05 mm (0.0020 in)
Fig. PD-30 Measuring place
10. At the same time, check bearing preload. Bearing preload should read 8 to 15 kg-cm (6.95 to 13.03 in-lb) of rotating torque [2.3 to 4.3 kg (5.1 to 9.5 lb) at companion flange bolt hole].
If preload does not accord with this specification, adjust it with side bearing shims.
11. Check and adjust the tooth contact pattern of ring gear and drive pinion.
(1) Thoroughly clean ring and drive pinion gear teeth. (2) Paint ring gear teeth lightly and evenly with a mixture of powdered red lead and oil of a suitable consistency to produce a contact pattern. (3) Rotate pinion through several revolutions in the forward and reverse direction until a definite contact pattern is developed on ring gear. (4) When contact pattern is incorrect, readjust thickness of adjust shim.
Be sure to wipe out red lead completely upon completion of adjustment.
(5) Incorrect contact pattern of teeth can be adjusted in the following manner.
a. Heel contact To correct, increase thickness of drive pinion adjusting washer in order to bring drive pinion close to ring gear.
Fig. PD-3 Heel contact
b. Toe contact To correct, reduce thickness of drive pinion adjusting washer in order to make drive pinion go away from ring gear.
Fig. PD-32 Toe contact
c. Flank contact Adjust in manner similar to b.
Fig. PD-33 Flank contact
d. Face contact Adjust in manner similar to a.
Fig. PD-34 Face contact
e. Correct tooth contact
Fig. PD-35 Correct contact
Note: Change in thickness of adjusting washer is accompanied by change in backlash. Check it when installing gear.
Common Problems
Whining
I would not worry about a slight humming from the differential. Many of them do that. As long as you keep the oil level full, it should get no worse.
However, severe humming (whining) caused by a loss of oil will not go away. After you add oil, the diff will work OK but will never be quiet again. It can last for years making a bit noise. It may help to reset the gearset to the proper clearance, which won't stop the whine but will bring the backlash back into tolerance.
Whining could be a wheel bearing:
- wheel bearing: the whining get louder when turning one direction, and goes away in the other direction
- diff bearing: whining changes with the load. When slightly accelerating, it whines. When coasting the whine lessens
Knocking/Grinding
Knocking is caused by a worn part (probably a bearing) which must be replaced. It could be a side bearing or the pinion bearing.
It could also be caused by a chipped gear tooth.
To isolate this from a bad transmission bearing, drive at varying speeds. Put the gear lever in neutral temporarily. Does the knock occur in neutral? Then it is likely to be in the differential.
