620 Wiper Switch
Revision as of 21:37, 5 July 2025; view current revision
<-- back to Wiper Switch
Datsun 620 truck uses a NILES wiper switches look identical to Datsun 1200 switches, except for a spacer.
  • JDM 620 did not light illuminated switches
  • USA starting 1972.09 has illuminated switch
  • USA 1978-1979 Datsun 620 with Deluxe trim have an intermittent wiper switch
Datsun 620 truck uses a NILES wiper switches look identical to Datsun 1200 switches, except for a spacer. Some have black escutcheon.
All 620 wiper switches use Datsun 1200 knobs (type H10 or H70}}
30427.jpgAlbum 30427 30431.jpgAlbum 30431
Main: Knobs
For USA, 1978-1979 Datsun 620 with Deluxe trim have an intermittent wiper switch, which pulls out three clicks (OFF, INT, Low, High). All other use the two-speed switch (OFF, Low, High). So either a 4-position switch with white rectangle connector or a 3-position switch with yellow square connector.
Escutcheon is 26mm diameter
30429.jpgAlbum 30429
Non-intermittent, non-illuminated
30425.jpgAlbum 30425
USA Standard and Intermittent switch pictured both connected to the Fiberscope fiber optic illumination unit
1973-up USA 620 uses a lighted switch as do all USA vehicles starting with the 1973 model year
23373.jpgAlbum 23373 24326.jpgAlbum 24326
Datsun 620 USA catalog COMP-SWITCH,WIPER
25260-B5500 1972 [non-illuminated] [from 1972.08]
25260-B6401 1973-1975 [from 1972.09]
25260-B8060 1976-1978
25260-B8060 1979 except DX
25260-B9300 1979 DX COMP-SWITCH,WIPER (INTERMITENT)
* 28890-B8060 AMP UNIT-INTERMITENT WIPER
* 24018-B9300 HARNESS-WIPER
* 08360-61291 SCREW 2
* 01552-00411 CLIP [zip tie]
25163-B5011 ESCUTCHEON
25265-H1000 KNOB-WIPER SWITCH 1972
25265-H7001 KNOB-WIPER SWITCH 1973-1979
25170-U0500 ASSY-ATTACHMENT WITH ILLUMINATION 1973-1979
* for illumination lamp
* 26261-89900 BULB (12V/3.4W)
* 25170-E7500 SOCKET-BULB
* 08310-40814 SCREW WITH SPRING WASHER
SWITCH-ILLMINATION CONTROL (1973 did not use a switch)
* 25280-B8001 1974-1977
* 25280-B8002 1978-1979
* 25280-B9800 1979 Deluxe
25287-B7900 PROTECTOR-ILLUMINATION SWITCH
KNOB-ILLUMINATION SWITCH
* 25285-P0100 1974-1975
* 25285-B8000 1976-1977
* 25285-R5300 1978-1979
* 25285-U2000 1976-1979
ダットサン トラック 1972 620 Japan catalog C-234 revision 1977.2
25260-B5000 SWITCH COMP.-wiper
25265-H7001 KNOB-wiper switch
ダットサン トラック 620 Japan catalog C-410 revision 1980-05 [1976-1979]
25260-B5000 SWITCH COMP.-wiper -7708
25260-B5005 SWITCH COMP.-wiper 7709- W/INTERMIT
* 28890-B8060 AMP-INTERMITENT WIPER 7709- ALL
* 28890-R4710 AMP-INTERMITENT WIPER -7708 *ALL [option] *PU T,V,OST
25260-B5000
25260-B5000 JDM non-intermittent 'NILES TYPED- JAPAN 091T' (NILES WS-620A)
30425.jpgAlbum 30425 30426.jpgAlbum 30426 30432.jpgAlbum 30432
Wiring appears to be identical to Datsun 1200 standard Wiper Switch
30428.jpgAlbum 30428 30430.jpgAlbum 30430
25260-B6000
rose311sr-img600x450-1229508149e240xk59909.jpg rose311sr-img600x450-1229508149kavvzy59909.jpg rose311sr-img600x450-1229508149rbqid859909.jpg
