Timing Cover
Revision as of 21:21, 19 November 2025; view current revision
Category: Engine Mechanical
The Timing Cover is the aluminum part on the front of the engine that covers the Timing Chain. It also has a timing mark on the cover and houses the crankshaft pulley seal.
The Timing Cover bolts to the front of the engine block and covers the Timing Chain. The Water Pump bolts to the timing cover.
Timing Cover with water pump bolted on
Early 1200 cover - single timing mark
Late 1200 cover - multiple timing marks
Water pump bolts to the timing cover. And the cover bolts to the front of the block, and passes water through two ports (the square hole, and the round hole).
1562.jpgAlbum 1562 1870.jpgAlbum 1870 5056.jpgAlbum 5056 20448.jpgAlbum 20448 14385.jpgAlbum 14385
Matched Set
Depending on the country, 1971 or 1972 saw newer timing covers which differ from earlier covers. Each one matches a certain pulley.
724.JPGAlbum 724 730.jpgAlbum 730
Japan got the Timing Cover change in June 1970. North America: all A-series engines from 1972.
Early Set
Multiple-mark Crankshaft Pulley
Single-mark Timing Cover
Late Set
Single-mark Crankshaft Pulley
Multiple-mark Timing Cover
The same covers are used by A10, A12, A12A, A13, A14 and A15, except for the first type:
1. Original Datsun 1000 timing cover, for single-row timing chain
   13035-18000 ASSY-COVER TIMING CHAIN
2. to June 1970, with single timing mark (pulley has multiple marks)
   13035-18001 ASSY-COVER TIMING CHAIN
   [updated to fit Double timing chain & pressure tensioner]
3. from June 1970, with multiple timing marks (pulley has single mark)
   13035-H1000 (or from second source: 13035-H1010)
   [Fits all A10 blocks]
Interchange is same for same. The last two will interchange if the complete set (matching pulley & cover) is used.
Early A10 Engine
Many A10 engine have a single-row timing chain. The cover is shallower and includes bossed for a chain guide
31254.jpgAlbum 31254 31253.jpgAlbum 31253 31255.jpgAlbum 31255 24939.jpgAlbum 24939
Gasket
* Nissan 13044-18001 GASKET-TIMING CHAIN COVER
  Fits all A-series timing covers A10/A12/A13/A14/A15
* NOTE: Does not include oil pan gasket, water pump gasket or pulley seal
A timing cover gasket set typically includes the front Crankshaft Pulley seal and Water pump seal. NOTE: The oil pan needs to be partially dropped to change the timing cover, requiring a new oil pan gasket.
Felpro include part of the oil pan gasket
RockAuto.com
* CORTECO 14308
* FEL-PRO TCS24531 $6.74
* BECK/ARNLEY 0380071
* VICTOR REINZ JV917
Seal
The Timing Cover gasket set includes a front crank seal.
Also see: Crankshaft Seal
Corrosion
Click each photo to read about corrosion of the timing cover.
21238.jpgAlbum 21238 21239.jpgAlbum 21239 21240.jpgAlbum 21240 21257.jpgAlbum 21257 21258.jpgAlbum 21258
Tach Drive
Race engines sometimes use a mechanical tachometer drive off the camshaft, with the Timing Cover modified to suit.
See main article: Tach Drive
Customized
Tachometer drive
683.jpgAlbum 683 864.jpgAlbum 864
Access cover for adjustable timing gear
23382.jpgAlbum 23382 23383.jpgAlbum 23383
Chrome-plated
24859.jpgAlbum 24859
Nissan 13035-H1000 $102.77 USD
Bprojects E-G-0190 ¥10,800 yen
timing_cover_a.jpg timing_cover_b.jpg timing_cover_c.jpg timing_cover_d.jpg timing_cover_e.jpg timing_cover_f.jpg timing_cover_g.jpg timing_cover_h.jpg
