The fuel pump is located on the right side of the engine block. Original pumps are made by 京三電機株式会社 (Kyosan Denkiᴳ) the fuel pump specialists, a member of Denso Group since 1969.
- All 1966-1973 pumps interchange (front distributor engines)
- All 1974-2007 A12/A14/A15 pumps interchange (mid-distributor engines)
- A10/A12 pumps are lower pressure output (2.6-2.8 psi)
- A14-A15 pumps and some A12 are 3.0 psi
A10/Early A12 pump single-bolt top
A12 revised pump 5-bolt cast top
Triangle-top mid-1970s A Engine Redesign A12/A13/A14/A15 three screw top
Sealed top late 1970s
Original Datsun 1200 (1970-1973) * 2.6 psi * 450 ml/minute minimum flow rate
That's good for 96 hp.
Late pumps: * 2.8-3.0 psi * 1300 ml/minute minimum flow rate
Testing
Repair
The original fuel pump is easy to repair. You can generally take them apart, clean it, then put back together using the original gasket.
Nissan repair kit comes with new diaphragm & valves
Leaks
A low pressure value might be due to a leaking gasket. It will definitely cause a fuel smell.
Finger-tighten these bolts in case they are loose:
Note that early A-series and late A-series fuel pumps differ:
Pumps with the long arm fit 1974 and newer A12/A13/A12A/A14 and A15. Pumps with the short arm only fit A10 & A12 front-distributor engines (1966-1973).
Electric Fuel Pump
An electric fuel pump can be fitted if the stock mechanical pump goes bad.
Fuel Pump Blank
Nissan part is commonly available and inexpensive.
EFI Fuel Pump
Electronic Fuel Injection generally requires a medium-pressure or high-pressure pump.
Original 1200 fuel pumps are rebuildable and have five screws holding the cast top to the chamber
Top left: late-A12 original style,5 bolt top
Top right: triangular top mid-1970s
Bottom left: early A12 (short arm), 1-bolt top
Bottom right: non-rebuildable circa 1980
B10 Japan 17010-18010 from E/# A10-211302 17010-H1001 from 1969 November > 17010-18010 17010-H1002 from 1970 April <> 17010-H1002
B110 USA * 17010-H1904 ASSY-PUMP FUEL
B110 JDM * 17010-H1003 PUMP ASS'Y-fuel * 17010-H1004 PUMP ASS'Y-fuel (ISO ネジ screw) (from '71-10) * 17010-H2302 PUMP ASS'Y-fuel GX * 17010-H2303 PUMP ASS'Y-fuel (ISO ネジ screw) (from '71-11) GX ** ISO ネジ = ISO screw
B210 introduced the A Engine Redesign, pump rod may be different from previous years.
B210 USA with A13 (1974 model year, to 0873) * 17010-H6226 ASSY-FUEL PUMP WITH GASKET Superceded 17010-H6225 ASSY-FUEL PUMP WITH GASKET * 17010-H6200 ASSY-FUEL PUMP -0873 * 17010-H6201 ASSY-FUEL PUMP 0973- * 17010-H6202 ASSY-FUEL PUMP
B210 USA with A14 engine (from 0974) * 17010-H7201 ASSY-FUEL PUMP 0974-0776 * 17010-H7261 ASSY-FUEL PUMP 0876-1276 [new lower body] * 17010-H7262 ASSY-FUEL PUMP 0177-1276
B210 JDM early * 17010-H5000 PUMP ASSY-fuel (?成部品未記?) A12S * 17010-H5010 PUMP ASSY-fuel A12S * 17010-H5001 PUMP ASSY-fuel (from '73-8) [top disc: central bolt + four screws * 17010-H5701 PUMP ASSY-fuel (from '73-10)
B210 JDM A12T * 17010-H5700 PUMP ASSY-fuel A12T * 17010-H5701 PUMP ASSY-fuel (from '73-10) A12T
B210 JDM late * 17010-H5026 PUMP ASSY-FUEL A12 VAN [3-bolt top disc] * 17010-H7226 PUMP ASSY-FUEL A12S, V A14S, K [central bolt top-disc]
B120 JDM * 17010-H2025 PUMP ASSY-FUEL 7510-7612 * 17010-H2026 PUMP ASSY-FUEL 7701-8503 * 17010-G1925 PUMP ASSY-FUEL 8504-8910 * 17010-G3426 PUMP ASSY-FUEL 8910-
B310 JDM * 17010-H7226 PUMP ASSY-FUEL A12S, A14S S, K+AT -8010 * 17010-G3425 PUMP ASSY-FUEL A13S, A15S 8011- * 17010-H5026 PUMP ASSY-FUEL V
B310 JDM Electric Pump (EFI) * 17011-Y8000 A14E -8010 * 17011-N4205 A15E 8011- Replaced by 17011-P7211 $286.12 USD 82-85 Datsun 280ZX
B310 USA * 17010-H7285 PUMP ASSY-FUEL A12A/A14/A15 -0780 * 17010-H7286 PUMP ASSY-FUEL A12A/A14/A15 0880-
Spacer
* Beck/Arnley 039-2002
A-series/R16 Roadster/U20/L-series/J-series/Z-series
Gasket
Beck/Arnley 039-2008 1978-1987 Chrysler/Mitsubishi 2.6 1976-1985 Mazda 808/GLC 1983-1989 Mitsubishi 2.6 Nissan A/L/J/Z/U/R Toyota 1971-1990, various models
A10 Fuel Pump
A10 fuel pump has one central screw fastening the stamped-steel disc-top -- same as early A12
- Early A10 pump (type 180) has press-in fuel fittings (while A12 uses screw-in fittings). Otherwise the same with identical pressure and valves
- Later A10 is the same as early A12 (type H10)
B210 Fuel Pump
For A engine redesign
Kyosan Denki NP-918ᴳ sealed top is non-rebuildable
Kyosan Denki
w/GASKET PUMP KYOSAN DENKI No.
17010-G1925 NP918
17010-G2725 17010-G2760 NP836 C120 A13,A15
17010-G3426 17010-G3401 NP835 B120,C120 A13,A15 82-
17010-G5125 17010-G5100 NP812 VANETTE SERENA A12,A15 87-
17010-H5025 17010-H5002 NP918 SUNNY 1200/1400CC B120 74-
17010-H5010 3-port type A14,B210
17010-H5026 17010-H5002 NP918 SUNNY 1200/1400CC A12,B120 74-
17010-H5010 A14,B210
17010-H5325 17010-H5300 NP918 SUNNY(EXP) A12,B120 74-
17010-H5326 17010-H5302 B210,B310
17010-H5303
17010-H5304
17010-H6200 17010-H5000 NP918 also 17010-H6226/17010-H6227
17010-H5700
17010-H6201
17010-H6203
17010-H5000
17010-H7225 17010-H7200 NP918 also 17010-H7226/17010-H7227/17010-H7287
17010-H7201
17010-H7202
17010-H7202
17010-H9525 17010-H9560 NP820 A ENGINE 66-70
NP606 5-bolt top [USA] 76-
NP-606 5-bolt top, screw-in ports
