GX unique parts
Also see:
- A12GX Engine
- Hitachi Twin Carb (A12T and A14T engines)
Comparison
Cylinder Heads
- 11041-H2300,11041-H2301,11041-H2302 HEAD ASSY-CYLINDER A12 GX B110
- 11041-H5702 HEAD ASS'Y-cylinder A12T B210
- 11041-M0801 HEAD ASSY-CYLINDER A12T E10
- 11041-M2460 HEAD ASSY-CYLINDER A14T B210, F10
Engine
- 11010-H2300 BLOCK ASS'Y-cylinder
- 10001-H2350 ENGINE ASS'Y-with clutch (High Gas)
- 10001-H2355 ENGINE ASS'Y-with clutch (Reg Gas)
- 10001-H2351 ENGINE ASS'Y-with clutch (????) (High Gas) op.
- 10001-H2356 ENGINE ASS'Y-with clutch (????) (Reg Gas) op.
- 10001-H7205 ENGINE ASS'Y-with clutch (High Gas) GX-5
- 10001-H7255 ENGINE ASS'Y-with clutch (Reg Gas) GX-5
- 10001-H7251 ENGINE ASS'Y-with clutch (????) (High Gas) GX-5 op.
- 10001-H7256 ENGINE ASS'Y-with clutch (????) (Reg Gas) GX-5 op.
- 10100-H4250 ENGINE ASS'Y-with drive plate (Reg Gas) GX-A
- 10102-H2300 ENGINE ASS'Y-bare (High Gas)
- 12010-18021 PISTON SET-with piston pin (std size) (High Gas)
- 21045-H2300 PIPE-suction, water pump
- 13001-H2300 CAMSHAFT ASS'Y
- 10102-H2305 ENGINE ASS'Y-bare (Reg Gas)
- 10103-H2300 ENGINE ASS'Y-short (High Gas)
- 10103-H2305 ENGINE ASS'Y-short (Reg Gas)
- 10101-H2325 ENGINE GASKET KIT GX
- 10101-H2326 ENGINE GASKET KIT-(from '72-6) GX
- 10101-H2327 ENGINE GASKET KIT-(from '73-4) GX
- 30411-H5000 PLATE-engine rear, GX-5
- 08110-62010 BOLT-fixing oil pan (1 of the 12 bolts is different from regular engine)
- OIL PUMP -- same as regular engine
Cylinder Head and Valve Cover
- 13264-H2300 COVER ASS'Y-valve rocker GX
- 11041-H2300 HEAD ASS'Y-cylinder GX
- 13201-H2300 VALVE-intake 4
- 13203-H2300 SPRING-valve outer 8
- 13204-H2301 SPRING-valve inner 8
- 13204-M0820 HIGH-PERFORMANCE VALVE SPRING/INNER (8) Datsun Competition
- same as 12109-M0820(?)
- 13205-H2300 SEAT-valve spring 8
- 13207-H2300 SEAL-oil valve 8
- 13207-H2301 SEAL-oil valve (from '72-7) 8 GX
- 13207-H2310 SEAL-oil valve (from '72-8) 8 GX
- 13202-H2300 VALVE-exhaust 4
- DELETE FROM GX: 13219-H1000 SHROUD-inner valve (from '73-4) 8
- 11041-H2301 HEAD ASS'Y-cylinder (from '73-3)
- 13212-H2310 GUIDE-valve, intake GX
- 13213-H2310 GUIDE-valve, exhaust GX
- 08213-82810 STUD-manifold (same as standad, but with 2 extra studs)
- 11044-H2300 GASKET-cylinder head GX
- 11044-H2325 GASKET-cylinder head GX (from '72-6)
- 11045-H2300 RING "O" (from '72-6, goes with new type head gasket)
- 11056-H2301 BOLT-cylinder head (9 total)
- 11057-H2301 BOLT-cylinder head, center (1 total)
- 10005-H2301 SLINGER-engine front (from '73-3)
- [10005-H230x is in the Cherry catalog, not listed in 1200 catalog]
- 10005-H2300 SLINGER-engine front
Manifold
- 1 14003-H2330 MANIFOLD-intake
- 1974 Nissan Cherry catalog lists 14003-H5731 for A12T engine
- 2 00933-11800 PLUG-welch 2
- 3 00933-12000 PLUG-welch 1
- 4 08931-30200 PLUG-taper 1
- 5 14059-H2300 CONNECTOR-water hose 1
- 6 08213-82810 STUD-carburetor fixing 4 (same as manifold-to-head studs)
- 7 14004-H2300 MANIFOLD-exhaust
- 8 08213-82800 STUD-fixing exhaust tube 3
- 9 08911-10810 NUT-fixing manifold 11
- 10 08915-13810 WASHER-lock, fixing manifold 7
- 11 14037-32200 YOKE-manifold 4
- 12 14035-H2300 GASKET-manifold, (steel best)
- 13 14055-H2301 HOSE-manifold water
- 14 08723-12000 CLAMP-hose 2
- 15 14330-H2301 PLATE-heat shield
- 14330-H2302 PLATE-heat shield (from '72-11)
- 16 16174-H2300 INSULATOR-carburetor 2
- 17 16175-A5100 GASKET-insulator 2
- 18 11810-A3500 VALVE ASS'Y-crank case emission control
- 19 11826-H2300 HOSE-rocker cover to control valve
- 20 16572-10801 CLAMP-hose
- 21 16572-H1000 CLAMP-hose
Nissan Competition
Source: 1984 Nissan Competition Catalog
- 16010-H2336 38MM SU CARB (FRONT)
- 16010-H2337 38MM SU CARB (REAR)
- 14003-H2330 GX INTAKE MANIFOLD
- 11826-H2300 BLOCK TO MANIFOLD HOSE
- 14035-H2300 MANIFOLD GASKET
- 14033-H2300 GX HEAT SHIELD
- 16031-H2300 OVERFLOW TUBE/FRONT
- 16031-H2301 OVERFLOW TUBE/REAR
- 16174-H2300 INSULATOR (2)
- 16175-A5100 INSULATOR GASKET (2)
- 16361-H2300 THROTTLE SHAFT ASSY
- 16376-H2300 ACCELERTOR CABLE BRACKET
- 17523-H2302 FUEL TUBE
- 18410-H2302 CHOKE CABLE
Carburetor
Three variations were used in the 1970-1972 B110 JDM GX model run. All are dome-tops:
- Original
- 16010-H2332 CARBURETOR ASS'Y-twin, front
- 16010-H2333 CARBURETOR ASS'Y-twin, rear
- November 1971
- 16010-H2334 CARBURETOR ASS'Y-twin, front (from '71-11)
- 16010-H2335 CARBURETOR ASS'Y-twin, rear (from '71-11)
- January 1973
- 16010-H2336 CARBURETOR ASS'Y-twin, front (from '73-1)
- 16010-H2337 CARBURETOR ASS'Y-twin, rear (from '73-1)
- 1 16122-H2310 SHAFT ASS'Y-throttle
- 2 16324-H2310 FILTER ASS'Y-piston
- 3 16144-H2310 NUT ASS'Y-idle adjusting
- 16144-H2311 NUT ASS'Y-idle adjusting (from '71-11)
- 4 16145-H2310 SPRING-idle adjusting screw 2
- 5 16355-H2310 NOZZLE ASS'Y
- 16355-H2310 NOZZLE ASS'Y (from '71-11)
- (6) 16127-H2310 PLATE ASS'Y-throttle adjusting, front
- 6 16127-H2311 PLATE ASS'Y-throttle adjusting, rear
- (7) 16277-H2312 LEVER ASS'Y-first idle, front
- 7 16277-H2313 LEVER ASS'Y-first idle, rear
- 16277-H2315 LEVER ASS'Y-first idle, rear (from '71-11)
- 16134-H2310 LEVER ASS'Y-throttle, front
- 8 16134-H2313 LEVER ASS'Y-throttle, rear
- 9 16083-58000 SLEEVE 2
- 10 16214-25610 NUT (8 radius) 2
- 11 16116-H2310 SLEEVE 2
- 12 16190-10401 SPRING-starter, return (B)
- 12 16190-74310 SPRING-starter, return (A)
- 13 16147-14611 PLATE-cam (B)
- 13 16147-74311 PLATE-cam (A)
- 14 16116-14610 SLEEVE (B)
- 15 16157-14610 SPRING-connecting (B)
- 15 16157-74310 SPRING-connecting (A)
- 16 16238-H2310 LEVER ASS'Y-choke, front
- 16 16238-H2311 LEVER ASS'Y-choke, rear
- 17 16147-H2310 PLATE-connection, front
- 17 16147-H2311 PLATE-connection, rear
- 18 16227-H2300 ADAPTER-front
- 18 16227-H2311 ADAPTER-rear
- 19 16322-E3210 BOLT (8Ø) (2)
- 20 16356-25610 PIPE-rubber, fuel (2)
- 21 16358-E4310 CLIP-fuel pipe (4)
- 22 16061-10400 FLOAT
- 23 16101-H1000 VALVE ASS'Y-needle
- 16101-18010 VALVE ASS'Y-needle (from '71-11)
- 24 16062-10400 LEVER-float (up to '71-10) (2)
- from '71-11
- 16062-H2310 LEVER-float, front (from '71-11) (1)
- 16062-H2710 LEVER-float, rear (from '71-11) (1)
- 25 16066-25610 SHAFT-float
- 26 16331-10400 SCREW-nipple set
- 27 16098-25710 FILTER
- 28 16554-H2310 JET-needle
- 28 16554-H2316 JET-needle (from '71-11)
- 29 16031-A8710 PLUG-drain
- 30 16148-H2310 CLAMP-choke, front
- 30 16149-H2310 CLAMP-choke, rear
- 16149-H2311 CLAMP-choke, rear (from '71-11)
- 31 16346-10615 SPRING-suction
- 32 16341-25610 NUT ASS'Y-oil cap
- 33 16194-H2310 SPRING-throttle
- 16194-H2311 SPRING-throttle (from '71-11)
- 16194-H2312 SPRING-throttle (from '73-1)
GASKET SET
- 16455-H2310 GASKET SET
- A 16335-14610 PACKING (10Ø) (4) [for inlet banjo]
- B GASKET-float chamber (2)
- C WASHER (8Ø) (2) [for fuel drain plug]
- D PACKING (18Ø) (2)
- E WASHER (10Ø) (2) [for fuel needle & seat ASSY]
SCREW & WASHER "B" SET
- 16475-H2310 SCREW & WASHER "B" SET
- PACKING (12.5Ø) (2)
- WASHER (7Ø) (4)
- WASHER (5Ø) (2)
- WASHER (4Ø) (2)
- PIN-cotter (1Ø) (2)
- WASHER-thrust (2)
- BOLT (5Ø) (2)
- BOLT (5Ø) (2)
- WASHER-lock (7Ø) (2)
- SCREW-set, needle jet (2)
SCREW & WASHER "A" SET
- 16465-H2310 SCREW & WASHER "A" SET
- SCREW (5Ø x 16) (16)
- SCREW (5Ø x 12) (2)
- SCREW (4Ø x 10) (2)
- SCREW (4Ø x 8) (4)
- WASHER-lock (8Ø) (4)
- WASHER-lock (5Ø) (18)
- WASHER-lock (4Ø) (2)
Carburetor Linkage
- 4 16361-H2300 SHAFT ASS'Y-throttle
- 5 16376-H2300 BRACKET-accelerator cable
- 6 08915-13510 WASHER-lock,fixing accelerator cable bracket 2
- 7 08460-51000 SCREW-fixing accelerator cable bracket 2
- 8 16031-H2300 TUBE-over flow, front
- 9 16031-H2301 TUBE-over flow, rear
16031-15801 TUBE-over flow, (Vinyl 6 x 9 x 160) 2
Choke Linkage
- 18410-H2301 WIRE COMP,-choke control GX
- 18410-H2302 WIRE COMP,-choke control (from '72-12) GX
- 24250-89929 GROMMET
- 18415-H2300 KNOB ASS'Y-choke control
- 18415-H1000 KNOB ASS'Y-choke control (from '72-12)
Air Cleaner
- 1 16500-H2300 CLEANER ASS'Y-air (for twin)
- 2 16526-H2300 COVER ASS'Y-upper
- 3 16536-H2300 PACKING
- 4 16546-H2300 ELEMENT ASS'Y-paper
- 5 16528-H2300 COVER ASS'Y-lower
- 6 16536-H2300 PACKING
- 7 16523-12200 GASKET (carburetor to air cleaner) 2
- 8 16548-22000 PACKING
- 9 16568-08000 PACKING
- 10 16516-H2300 BOLT ASS'Y-center 2
- 11 08120-81662 BOLT (fixing air cleaner to carburetor) 4
- 12 11828-H2300 HOSE-air cleaner to pipe connector
- 13 16572-H1000 CLAMP-hose
- 16572-10801 CLAMP-hose
AIR CLEANER (HOT AIR TYPE) - Optional
- 16500-H2310 CLEANER ASS'Y-air
- 14 16590-H2310 COVER-manifold
- 15 16530-H2310 DUCT-cover to air cleaner
- 16 14896-C0600 BAND-hose
Fuel Piping
- 14 17523-H2302 TUBE-fuel pump to carburetor
- 15 17106-H2300 CLAMP-fuel tube
- 16 17107-H2300 CLAMP-fuel tube
- 17 17108-H2300 CLAMP-fuel tube
- 18 08740-08020 HOSE-fuel (l=80mm) 3
- 19 08723-11400 CLAMP-hose 6
Fuel Pump
- 17010-H2302 PUMP ASS'Y-fuel GX
- 17010-H2303 PUMP ASS'Y-fuel (ISO hose) (from '71-11) GX
- 21060-A4600 FAN-cooling
Engine Electrical
HITACHI
- 22100-H2300 DISTRIBUTOR ASS'Y-(D407-54) (High Gas)
- 22110-14600 SPRING SET-governor (High Gas)
- 22132-14605 CAM-ASS'Y (High Gas)
- DELETE (?) 22301-H1000 CONTROL ASS'Y-vacuum (except GX-H)
- 22100-18006 DISTRIBUTOR ASS'Y-(D412-53K) (Reg Gas)
- 22110-18001 SPRING SET-governor (Reg Gas)
- 22132-18005 CAM-ASS'Y (Reg Gas)
MITSUBISHI
- 22100-H18016 DISTRIBUTOR ASS'Y-(TVA-4F2L) (Reg Gas)
- 22127-18010 SPRING-governor (Reg Gas) 2
- 22318-E3001 TUBE-distributor vacuum advance (l = 480 mm)
- GX RESISTOR IGNITION COIL
- 22401-A4616 PLUG-spark (N.G.K.=BP6ES) 4 [regular A12 is BP5ES]
- 22401-A4705 PLUG-spark (??=L45PW) 4 (Hitachi)
Transmission
CLUTCH for GX is same with regular models
- 31063-H3410 CONNECTOR-vacuum tube GXA
- 32865-H2300 KNOB-control lever 4-speed
- 32010-H7251 TRANSMISSION ASS'Y (17/5) GX-5
- 32865-H7200 KNOB-control lever GX-5
- 11322-H7200 MEMBER-engine mounting, rear
- 11322-H7201 MEMBER-engine mounting, rear (from '72-10)
- 11323-H7200 STOPPER-engine mounting, rear
- 24033-H7200 CABLE-reverse lamp switch GX-5
Misc
- 17501-H7210 TUBE-fuel (fuel tank to engine) Coupe GX-5
- 24103-H7200 [Wiring] HARNESS-instrument GX-5
- 24043-H2025 CABLE SET-clock (for console box)
- 24043-H2001 CABLE-clock, front
- 24044-H2000 CABLE-clock, rear
See Also:
- 26350-89906 BUZZER-back warning GX-5
- 26351-H7200 BRACKET-buzzer GX-5
- 08513-51012 SCREW-stopping (for buzzer bracket) GX-5
- 26380-H2300 ARM ASS'Y-wiper 2
- 26381-H2300 NUT-wiper arm 2
- 28360-H2300 BLADE ASS'Y-wiper 2
- 26370-A4001 BLADE ASS'Y-wiper 2 GX-5 (op. on all other models)
- 54611-H2300 BAR-torsion, front stabilizer [antiswaybar]
- 54617-H2300 BUSHING-stabilizer
- 40315-H1900 CAP-road wheel [hubcap]
GX and GL use a different wheel than STD and DX. Slightly different to fit over disc brakes?
- 46280-H7201 TUBE ASS'Y-brake master cylinder to rear brake hose GX-5
- 46280-H7201 TUBE ASS'Y-brake master cylinder to rear brake hose (from '73-5) GX-5
Exhaust Piping
- 20010-H2301 TUBE ASS'Y-exhaust, front - GX 4-speed
- 20010-H3400 TUBE ASS'Y-exhaust, front - GXA (GX Automatic)
- 20010-H7200 TUBE ASS'Y-exhaust, front - GX-5
- 20603-H2300 GASKET-exhaust tube - GX and GX-5
- 20602-27700 NUT-fixing, tube end - GX-5
- 08915-13810 WASTHER-spring lock (3) - GX-5
- 20321-H2500 FINISHER-exhaust - GL, GX [chrome extension]
Radiator
- 21400-H2300 RADIATOR ASS'Y
- 21506-H2301 HOSE ASS'Y-radiator, lower
