Sunny Truck was fitted with a regular (contact points) distributor through October 1989. From there on it was fitted with Electronic Ignition.
Versions
- 22100-G1610 DISTRIBUTOR ASSY 7510-7907
- 22100-W8511 DISTRIBUTOR ASSY 7907-8602
- 22100-G1910 DISTRIBUTOR ASSY 8602-8910
- 22100-95W10 DISTRIBUTOR ASSY 8910-
The late model one is Electronic Ignition
Coils
All used with ballast resistor, except the Electronic Distributor
- 22433-U3100 COIL ASSY-IGNITION [HITACHI] 7510-8910
- 22433-U3110 COIL ASSY-IGNITION [HANSHIN] 7510-8910
- 22433-U3140 COIL ASSY-IGNITION [MITSUBISHI] 8504-8910
- 22433-52A60 COIL ASSY-IGNITION MITSUBISHI
Resistor
- 22460-14606 RESISTOR-IGNITION COIL 7510-8910 Hitachi choice
- Hanshin HP5-13E10 12V-R(ヒタチ センタク シヨウ)
- 22460-14615 RESISTOR-IGNITION COIL 7510-8910 Hanshin choice
- 22460-14645 RESISTOR-IGNITION COIL 8504-8910 Mitsubishi choice
22100-W8511
22100-G1910
22100-95W10
This is fitted to Datsun 1200 trucks from October 1989 through end of production in 1994. It is a nice unit with the transistor unit mounted in the distributor body, under the distributor cap. Late-model Electronic Distributor.
- 22462-52A60 COIL-IGNITION
- 22100-95W10 DISTRIBUTOR ASSY A12S 8910- ミツビシ (Mitsubishi) デストリビユーター (デストリビューター)
- 22100-95W12
- 22020-G5111 TRANSISTOR IGNITION UNIT [fits inside distributor]
- B2235-U7410 TAPE-SEAL, DISTRIBUTOR [a roll of tape] 7510-, 1194- B14U SR20DE,GA16DE
- superceded by 22235-U7400 $3.39 USD
- 22301-95W10 CONTROL ASSY-VACUUM
- 22023-G5110 UNIT-SETTER
- 22201-22010 SCREW 7510- [fixing timing plate to distributor]
- 22180-71200 SEAL-O RING [distributor to engine block] A/L/Z engines $4.25 USD
- 22101-95W10 HOUSING ASSY-DISTRIBUTOR
- Condensor: None used
- ? 22107-95W10 GOVERNOR SET-DISTRIBUTOR
- 22115-95W10 SIGNAL-ROTO ASSY
- 22109-52H60 WEIGHT-GOVERNOR
- 22127-95W10 SPRING-GOVERNOR
- 22136-77A11 PLATE ASSY-BREAKER
- 22132-95W10 CAM SET
- 22229-95W10 SIGNAL SET
Cap & Rotor
- 22162-78A10 CAP ASSY-DISTRIBUTOR B12 1088- GA16I $27.36 USD
- 22185-95W10 PACKING [seal, cap to body]
- ? 04136-00211 SCREW
- 22157-23G15 ROTOR-HEAD $6.88 USD
Cap fits North America models:
- 1988-1990 Nissan Sentra with Mitsubishi distributor
- Oreillys.com E16 or GA16 Sentra
- Master Pro C672
- BWD C672
- Beck/Arnley 1746918
- Niehoff Ultra WA468A; Pro-Power WA468ACS
- Bosch 03320
- Standard Motor Products JH180
- AC/Delco E338A
- 1987-1988 Nissan Pulsar NX
Bosch 03320 CAP fits North America models:
- Nissan 1983-1994
- 1989-1990 Nissan 240SX
- 1990-1994 Nissan Pickup
- 1983-1990 Nissan Pulsar NX
- 1991-1993 Nissan NX
- 1984-1994 Nissan Sentra
- Subaru 1987-1991
- 1988-1989 Subaru DL
- 1990-1994 Subaru Loyale
- 1987-1989 Subaru GL
- 1987-1989 Subaru RX
- 1987-1989 Subaru GL-10
- 1987-1991 Subaru XT
- Suzuki
- 1989-1994 Suzuki Swift
Mitsubishi T4T Family
Mitsubishi T4T series came with points and electronic versions.
- T4T66373 B122
- T4T11071 (22100-K8700 H25 Forklift engine?)
- T4T21693 (22100-K9800)
- T4T66871
- T4T66971
- T4T00571 Vanette Distributor
- T4T05712 Vanette Distributor
- T4T66371 circa 1986 Vanette Distributor AU
- T4T84471 1988 Nissan Sentra CAL (Hitachi D4P83-03)
Also see: Vanette Distributor
Unknown
This looks like T4T electronic distributor. Probably a Vanette since it was found in Austrailia:
